path: root/arch/arm/boot/dts/omap3-overo-storm.dtsi
2014-03-12ARM: dts: omap3-overo: Add HSUSB PHYFlorian Vaussard
Add the High-Speed USB PHY. Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch> Acked-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-03-12ARM: dts: omap3-overo: Enable WiFi/BT comboFlorian Vaussard
MMC2 is used by the on-board WiFi module populated on some boards (based on Marvell Libertas 8688 SDIO). The Bluetooth is connected to UART2. Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-03-12ARM: dts: overo: reorganize include filesFlorian Vaussard
Currently, overo-related include files are organized as follow: omap3-overo.dtsi | | omap34xx.dtsi omap3-overo-tobi-common.dtsi omap36xx.dtsi | | | | --------------- --------------- | | omap3-overo-tobi.dts omap3-overo-storm-tobi.dts This is unpractical when one has to deal with SoC-specific pinmux belonging to the omap3_pmx_core2 (defined in omap34xx/omap36xx), for pins related to the processor board. With the current hierarchy, such pinmux has to be defined in the expansion board's .dts, which is not logical. This patches reorganizes the files to add (yet another) abstraction layer between the processor and the expansion boards. omap34xx.dtsi omap3-overo-base.dtsi omap36xx.dtsi | | | | --------------- --------------- | | omap3-overo.dtsi omap3-overo-storm.dtsi | | -------- ------ | omap3-overo-tobi-common.dtsi | | | | | --------------- --------------- | | omap3-overo-tobi.dts omap3-overo-storm-tobi.dts Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch> Signed-off-by: Tony Lindgren <tony@atomide.com>
