The gpmc ranges property for NAND at CS0 was being overridden by later
includes that defined gpmc ethernet nodes, effectively breaking NAND on
these systems:
omap-gpmc 6e000000.gpmc: /ocp/gpmc@6e000000/nand@0,0 has
malformed 'reg' property
Instead of redefining the NAND range in every such dtsi, define all
currently used ranges in omap3-overo-base.dtsi.
Fixes: 98ce6007efb4 ("ARM: dts: overo: Support PoP NAND")
Cc: stable <stable@vger.kernel.org> # 4.3
Signed-off-by: Johan Hovold <johan@kernel.org>
Summit and Tobi expansion boards have a HDMI connector with a TFP410
encoder. Add a common include file for this configuration, and then
use it for Summit and Tobi.
Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
The LIS33DE accelerometer is used on several Gumstix expansion boards,
thus add the DT node to omap3-overo-common-peripherals.dtsi.
For the boards that do not have the accelerometer (like Tobi), mark the
status as disabled.
Gumstix expansion boards share a couple of peripherals:
- uart3 is used for the console
- AT24C01 EEPROM on i2c3
Use this file for overo-tobi.
UART3 is used by expansion boards to get a tty console. Thus, the
pinmux should be defined by expansion boards, instead of being
imposed by the processor board.
Add the AT24C01 EEPROM node populated on most Gumstix expansion board.
Use the timings provided by omap-gpmc-smsc9221. This does not change
the timings, but it avoids code duplication.
Add missing pinctrl entries:
- i2c3
Currently, overo-related include files are organized as follow:
omap3-overo.dtsi
omap34xx.dtsi omap3-overo-tobi-common.dtsi omap36xx.dtsi
omap3-overo-tobi.dts omap3-overo-storm-tobi.dts
This is unpractical when one has to deal with SoC-specific pinmux
belonging to the omap3_pmx_core2 (defined in omap34xx/omap36xx),
for pins related to the processor board. With the current
hierarchy, such pinmux has to be defined in the expansion board's
.dts, which is not logical.
This patches reorganizes the files to add (yet another) abstraction
layer between the processor and the expansion boards.
omap34xx.dtsi omap3-overo-base.dtsi omap36xx.dtsi
omap3-overo.dtsi omap3-overo-storm.dtsi
| omap3-overo-tobi-common.dtsi |
Unfortunatly the device tree for older OMAP35xx Overo cannot be used
with newer OMAP36xx and vice-versa. To address this issue, move most of
the Tobi DTS to a common include file, and create model-specific Tobi
DTS.
Tested-by: Kevin Hilman <khilman@linaro.org>
Acked-by: Nishanth Menon <nm@ti.com>
