path: root/arch/arm/boot/dts/omap3-overo-tobiduo.dts
2015-07-14ARM: dts: Add DTS for Gumstix TobiDuo expansion boardAsh Charles
The Gumstix "Tobi-Duo" expansion board [1] can be used with either OMAP3 Overo or Overo Storm COMs. It provides two NICs using LAN9221 chips. It is necessary to duplicate the interface information for the second SMSC9221 chip as discussed [2]. [1] https://store.gumstix.com/index.php/products/241/ [2] http://www.spinics.net/lists/linux-omap/msg115282.html Signed-off-by: Ash Charles <ashcharles@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
