commit 287897f9aaa2ad1c923d9875914f57c4dc9159c8 upstream.
The MMC card detection GPIO polarity is active low on TAO3530, like in many
other similar boards. Now the card is not detected and it is unable to
mount rootfs from an SD card.
Fix this by using the correct polarity.
This incorrect polarity was defined already in the commit 30d95c6d7092
("ARM: dts: omap3: Add Technexion TAO3530 SOM omap3-tao3530.dtsi") in v3.18
kernel and later changed to use defined GPIO constants in v4.4 kernel by
the commit 3a637e008e54 ("ARM: dts: Use defined GPIO constants in flags
cell for OMAP2+ boards").
While the latter commit did not introduce the issue I'm marking it with
Fixes tag due the v4.4 kernels still being maintained.
Fixes: 3a637e008e54 ("ARM: dts: Use defined GPIO constants in flags cell for OMAP2+ boards")
Cc: linux-stable <stable@vger.kernel.org> # 4.4+
Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
Based on 2 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation
published by the free software foundation #
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 4122 file(s).
Reviewed-by: Enrico Weigelt <info@metux.net>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de
"usb-nop-xceiv" is using the phy binding, but is missing #phy-cells
property. This is probably because the binding was the precursor to the phy
binding.
Fixes the following warning in OMAP dts files:
Warning (phys_property): Missing property '#phy-cells' in node ...
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: "Benoît Cousson" <bcousson@baylibre.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Cc: Javier Martinez Canillas <javier@dowhile0.org>
Cc: linux-omap@vger.kernel.org
Replace deprecated "vmmc_aux" with the generic "vqmmc" binding for
MMC IO supply.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Property 'enable-active-low' does not exist. Only 'enable-active-high' is
valid, and when this property is absent the gpio regulator will act as
active low by default.
So remove the unexisting 'enable-active-low' property.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Add compatible id, GPMC register resource and interrupt
resource to NAND controller nodes.
The GPMC node will provide an interrupt controller for the
NAND IRQs.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Many OMAP2+ DTS are not using the defined constants to express
the GPIO polarity. Replace these so the DTS are easier to read.
This patch just move content of file omap34xx-hs.dtsi into omap3-tao3530.dts.
There is no code change, patch is just preparation for removing -hs file.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Acked-by: Pavel Machek <pavel@ucw.cz>
ti,codec property is not used (parsed) in omap-twl4030 driver. The ti,twl4030-audio
which ti,codec points by phandle is mfd driver and device for ASoC codec is created
w/o DT compatible string. Removing all references in DT files.
Signed-off-by: Marek Belisko <marek@goldelico.com>
Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
The GPMC binding is obviously very confusing as the values
are all over the place. People seem to confuse the GPMC partition
size for the chip select, and the device IO size within the GPMC
partition easily.
The ranges entry contains the GPMC partition size. And the
reg entry contains the size of the IO registers of the
device connected to the GPMC.
Let's fix the issue according to the following table:
Device GPMC partition size Device IO size
connected in the ranges entry in the reg entry
NAND 0x01000000 (16MB) 4
16550 0x01000000 (16MB) 8
smc91x 0x01000000 (16MB) 0xf
smc911x 0x01000000 (16MB) 0xff
OneNAND 0x01000000 (16MB) 0x20000 (128KB)
16MB NOR 0x01000000 (16MB) 0x01000000 (16MB)
32MB NOR 0x02000000 (32MB) 0x02000000 (32MB)
64MB NOR 0x04000000 (64MB) 0x04000000 (64MB)
128MB NOR 0x08000000 (128MB) 0x08000000 (128MB)
256MB NOR 0x10000000 (256MB) 0x10000000 (256MB)
Let's also add comments to the fixed entries while at it.
Acked-by: Roger Quadros <rogerq@ti.com>
The Technexion TAO3530 is a OMAP3530 based SOM. This patch adds the
basic support for it as an dtsi file which can be included by
baseboard equipped with this SOM. E.g. the Technexion Thunder
baseboard.
Cc: Thorsten Eisbein <thorsten.eisbein@head-acoustics.de>
Cc: Tapani Utriainen <tapani@technexion.com>
