path: root/arch/arm/boot/dts/omap36xx-am35xx-omap3430es2plus-clocks.dtsi
2016-04-11ARM: dts: omap3: fix clock node definitions to avoid build warningsTero Kristo
Upcoming change to DT compiler is going to complain about nodes which have a reg property, but have not defined the address in their name. This patch fixes following type of warnings for OMAP3 clock nodes: Warning (unit_address_vs_reg): Node /ocp/cm@48004000/clocks/dpll3_m2_ck has a reg or ranges property, but no unit name Signed-off-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-03-19ARM: dts: fix omap3 dss clock handle namesTomi Valkeinen
The DSS fclk and iclk handles are named differently on OMAP3430 ES1 than on later OMAP revisions. The ES1 has handles 'dss1_alwon_fck_3430es1' and 'dss_ick_3430es1', whereas later revisions have similar names but ending with 'es2'. This means we don't have one clock handle to which we could refer to when defining the DSS clocks. However, as the namespaces are separate for ES1 and ES2+ OMAPs, we can just rename the handles to 'dss1_alwon_fck' and 'dss_ick' for both ES1 and ES2+, removing the issue. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Tested-by: Christoph Fritz <chf.fritz@googlemail.com> Tested-by: Marek Belisko <marek@goldelico.com> Acked-by: Tero Kristo <t-kristo@ti.com> Acked-by: Tony Lindgren <tony@atomide.com>
2014-01-17ARM: dts: omap3 clock dataTero Kristo
This patch creates a unique node for each clock in the OMAP3 power, reset and clock manager (PRCM). Signed-off-by: Tero Kristo <t-kristo@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
