Add cpu_thermal zone.
Signed-off-by: Keerthy <j-keerthy@ti.com>
Drivers using pinctrl-single,pins have #pinctrl-cells = <1>, while
pinctrl-single,bits need #pinctrl-cells = <2>.
Note that this patch can be optionally applied separately from the
driver changes as the driver supports also the legacy binding without
#pinctrl-cells.
Acked-by: Rob Herring <robh@kernel.org>
This patch fixes the following DTC warnings for many boards:
"Node /ocp has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
This patch fixes the following DTC warnings:
"bandgap has a reg or ranges property, but no unit name"
Driver for omap3 with documentation is there since v4.4-rc1.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Acked-by: Pavel Machek <pavel@ucw.cz>
Tested-by: Pavel Machek <pavel@ucw.cz>
[tony@atomide.com: added thermal-sensor-cells as suggested by Roger]
As pointed out by Stephen Rothwell, commit e52117638b79 ("ARM: dts:
omap3: Add DT entries for OMAP 3 ISP") conflicts with b8845074cfbb
("ARM: dts: omap3: add minimal l4 bus layout with control module support")
in non-obvious ways, causing a build failure when both patches
are present.
This merges the two branches that introduce the respective changes
into the next/late branch to resolve the way that Stephen suggested,
as confirmed by Tony.
Link: https://lkml.org/lkml/2015/4/6/436
The resources the ISP needs are slightly different on 3[45]xx and 3[67]xx.
Especially the phy-type property is different.
Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
[tony@atomide.com: use omap3_scm_general instead of scm_conf for now]
Add SSI device tree data for OMAP3 and Nokia N900.
Signed-off-by: Sebastian Reichel <sre@kernel.org>
Reviewed-by: Pavel Machek <pavel@ucw.cz>
Tested-By: Ivaylo Dimitrov <ivo.g.dimitrov.75@gmail.com>
Add DT data for OMAP3 display subsystem, which contains the following
blocks:
dss - the wrapper/glue for the display modules
dispc - display controller
dsi - MIPI DSI encoder
rfbi - MIPI DBI encoder
venc - analog TV encoder
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
OMAP3630 DPLL4 is different than on OMAP3430, in that it doesn't have
the x2 multiplier for its outputs. This is not currently reflected in
the clock DT data.
Fix the issue by setting the clock multiplier to 1 (instead of 2) for the
DPLL4 output clocks.
Tested-by: Christoph Fritz <chf.fritz@googlemail.com>
Tested-by: Marek Belisko <marek@goldelico.com>
Acked-by: Tero Kristo <t-kristo@ti.com>
Add ABB device node for OMAP36xx family of devices. Data is based on
OMAP36XX Technical Reference Manual revision AB (Dec 2012).
[nm@ti.com: co-developer]
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Andrii.Tseglytskyi <andrii.tseglytskyi@ti.com>
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
git://git.linaro.org/people/mike.turquette/linux
Pull more clock framework changes from Mike Turquette:
"The second half of the clock framework pull requeust for 3.14 is
dominated by platform support for Qualcomm's MSM SoCs, DT binding
updates for TI's OMAP-ish processors and additional support for
Samsung chips.
Additionally there are other smaller clock driver changes and several
last minute fixes. This pull request also includes the HiSilicon
support that depends on the already-merged arm-soc pull request"
[ Fix up stupid compile error in the source tree with evil merge - Grumpy Linus ]
* tag 'clk-for-linus-3.14-part2' of git://git.linaro.org/people/mike.turquette/linux: (49 commits)
clk: sort Makefile
clk: sunxi: fix overflow when setting up divided factors
clk: Export more clk-provider functions
dt-bindings: qcom: Fix warning with duplicate dt define
clk: si5351: remove variant from platform_data
clk: samsung: Remove unneeded semicolon
clk: qcom: Fix modular build
ARM: OMAP3: use DT clock init if DT data is available
ARM: AM33xx: remove old clock data and link in new clock init code
ARM: AM43xx: Enable clock init
ARM: OMAP: DRA7: Enable clock init
ARM: OMAP4: remove old clock data and link in new clock init code
ARM: OMAP2+: io: use new clock init API
ARM: OMAP2+: PRM: add support for initializing PRCM clock modules from DT
ARM: OMAP3: hwmod: initialize clkdm from clkdm_name
ARM: OMAP: hwmod: fix an incorrect clk type cast with _get_clkdm
ARM: OMAP2+: clock: use driver API instead of direct memory read/write
ARM: OMAP2+: clock: add support for indexed memmaps
ARM: dts: am43xx clock data
ARM: dts: AM35xx: use DT clock data
This patch creates a unique node for each clock in the OMAP3 power,
reset and clock manager (PRCM).
Signed-off-by: Tero Kristo <t-kristo@ti.com>
Signed-off-by: Mike Turquette <mturquette@linaro.org>
The omap3_pmx_core pinmux device in the device tree handles the system
controller module (SCM) PADCONFS fonction. Its control registers are
split in two distinct areas, with other SCM registers in-between. Those
other registers can't thus be requested by other drivers as the memory
region gets reserved by the pinmux driver.
Split the omap3_pmx_core device tree node in two for the two memory
regions. The second region address and size depends on the SoC model.
The change in omap3.dtsi fixes an "external abort on non-linefetch" when
doing
cat /sys/kernel/debug/pinctrl/.../pins
on a Nokia N900.
Note that the core2 padconf region is different for 3430 vs 3630,
and does not exist on 3517 as noted by Nishanth Menon <nm@ti.com>.
Reported-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-By: Sebastian Reichel <sre@debian.org>
[tony@atomide.com: updated for 3430 vs 3630 core2 based on Nishant's patch]
Looks like omap3 is still relying on hwmod data for some basic
device tree information. Let's add the information to omap3.dtsi
so we can remove the related hwmod data once omap3 is DT only.
Acked-by: Benoit Cousson <bcousson@baylibre.com>
Replace /include/ by #include for OMAP2+ DT, in order to use the
C pre-processor, making use of #define features possible.
Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
commit 3027e26 (ARM: dts: OMAP36xx: Add CPU OPP table)
introduced wrong OPP voltages per OPP by mistake. Sync the OPP
tables with existing OMAP36xx OPP data in
arch/arm/mach-omap2/opp3xxx_data.c
Add DT OPP table for OMAP36xx/37xx family of devices. This data is
decoded by OF with of_init_opp_table() helper function.
OPP data here is based on existing opp3xxx_data.c
This is in preparation to use generic cpufreq-cpu0 driver for device
tree enabled boot. Legacy non device tree enabled boot continues to
use omap-cpufreq.c and opp3xxx_data.c.
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Jon Hunter <jon-hunter@ti.com>
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Shawn Guo <shawn.guo@linaro.org>
Cc: Keerthy <j-keerthy@ti.com>
The extra serial port is not available on 34xx. And the current
omap3-beagle.dts file is for omap3-beagle-xm.dts as it lists 512MB
of memory.
Please somebody submit a new omap3-beagle.dts for the original 34xx
BeagleBoard after testing it properly.
Cc: Benoit Cousson <b-cousson@ti.com>
Cc: devicetree-discuss@lists.ozlabs.org
