path: root/arch/arm/boot/dts/omap3xxx-clocks.dtsi
2016-04-11ARM: dts: omap3: fix clock node definitions to avoid build warningsTero Kristo
Upcoming change to DT compiler is going to complain about nodes which have a reg property, but have not defined the address in their name. This patch fixes following type of warnings for OMAP3 clock nodes: Warning (unit_address_vs_reg): Node /ocp/cm@48004000/clocks/dpll3_m2_ck has a reg or ranges property, but no unit name Signed-off-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-03-31ARM: dts: omap3: add minimal l4 bus layout with control module supportTero Kristo
This patch creates an l4_core interconnect for OMAP3, and moves some of the generic peripherals under it. System control module nodes are moved under this new interconnect also, and the SCM clock layout is changed to use the renamed SCM node as the clock provider. Signed-off-by: Tero Kristo <t-kristo@ti.com> Reported-by: Tony Lindgren <tony@atomide.com>
2014-08-21ARM: dts: set 'ti,set-rate-parent' for dpll4_m5x2 clockStefan Herbrechtsmeier
Set 'ti,set-rate-parent' property for the dpll4_m5x2_ck clock, which is used for the ISP functional clock. This fixes the OMAP3 ISP driver's clock rate configuration on OMAP34xx, which needs the rate to be propagated properly to the divider node (dpll4_m5_ck). Signed-off-by: Stefan Herbrechtsmeier <stefan@herbrechtsmeier.net> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Tero Kristo <t-kristo@ti.com> Cc: <linux-media@vger.kernel.org> Cc: <linux-omap@vger.kernel.org> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Tero Kristo <t-kristo@ti.com>
2014-05-16ARM: dts: set 'ti,set-rate-parent' for dpll4_m5 pathLaurent Pinchart
Set 'ti,set-rate-parent' property for the dpll4_m5x2_mul_ck clock, which is used for the ISP functional clock. This fixes the OMAP3 ISP driver's clock rate configuration, which needs the rate to be propagated properly to the divider node (dpll4_m5_ck). Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Tero Kristo <t-kristo@ti.com>
2014-05-16ARM: dts: use ti,fixed-factor-clock for dpll4_m5x2_mul_ckLaurent Pinchart
We need to use set-rate-parent for dpll4_m5 clock path, so use the ti,fixed-factor-clock version which supports set-rate-parent property. The set-rate-parent flag itself is set in the following patch, this one just changes the clock driver to ti,fixed-factor-clock without any other changes. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Tero Kristo <t-kristo@ti.com>
2014-03-19ARM: dts: set 'ti,set-rate-parent' for dpll4_m4 pathTomi Valkeinen
Set 'ti,set-rate-parent' property for clocks in the dpll4_m4 clock path, which is used for DSS functional clock. This fixes DSS driver's clock rate configuration, which needs the rate to be propagated properly to the divider node (dpll4_m4_ck). Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Tested-by: Christoph Fritz <chf.fritz@googlemail.com> Tested-by: Marek Belisko <marek@goldelico.com> Acked-by: Tony Lindgren <tony@atomide.com>
2014-03-19ARM: dts: use ti,fixed-factor-clock for dpll4_m4x2_mul_ckTomi Valkeinen
We need to use set-rate-parent for dpll4_m4 clock path, so use the ti,fixed-factor-clock version which supports set-rate-parent property. The set-rate-parent flag itself is set in the following patch, this one just changes the clock driver to ti,fixed-factor-clock without any other changes. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Tested-by: Christoph Fritz <chf.fritz@googlemail.com> Tested-by: Marek Belisko <marek@goldelico.com> Acked-by: Tony Lindgren <tony@atomide.com>
2014-01-17ARM: dts: omap3 clock dataTero Kristo
This patch creates a unique node for each clock in the OMAP3 power, reset and clock manager (PRCM). Signed-off-by: Tero Kristo <t-kristo@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
