[ Upstream commit 2d59bb602314a4b2593fde267734266b5e872dd0 ]
Otherwise we can get the following errors occasionally on some devices:
mmc1: tried to HW reset card, got error -110
mmcblk1: error -110 requesting status
mmcblk1: recovery failed!
print_req_error: I/O error, dev mmcblk1, sector 14329
I have one device that hits this error almost on every boot, and another
one that hits it only rarely with the other ones I've used behave without
problems. I'm not sure if the issue is related to a particular eMMC card
model, but in case it is, both of the machines with issues have:
# cat /sys/class/mmc_host/mmc1/mmc1:0001/manfid \
/sys/class/mmc_host/mmc1/mmc1:0001/oemid \
/sys/class/mmc_host/mmc1/mmc1:0001/name
0x000045
0x0100
SEM16G
and the working ones have:
0x000011
0x0100
016G92
Note that "ti,non-removable" is different as omap_hsmmc_reg_get() does not
call omap_hsmmc_disable_boot_regulators() if no_regulator_off_init is set.
And currently we set no_regulator_off_init only for "ti,non-removable" and
not for "non-removable". It seems that we should have "non-removable" with
some other mmc generic property behave in the same way instead of having to
use a non-generic property. But let's fix the issue first.
Fixes: 7e2f8c0ae670 ("ARM: dts: Add minimal support for motorola droid 4
xt894")
Cc: Marcel Partap <mpartap@gmx.net>
Cc: Merlijn Wajer <merlijn@wizzup.org>
Cc: Michael Scott <hashcode0f@gmail.com>
Cc: NeKit <nekit1000@gmail.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Sebastian Reichel <sre@kernel.org>
Add vibrator to Droid4's device tree.
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
Devices using an external encoder, ESD protection and level shifter
such as tpd12s015 or ip4791cz12 have the CEC pull in the encoder
chip. And on var-som-om44, there is external pull up resistor R30.
So the internal CEC pull-up resistor needs to be disabled as otherwise
the external and internal pull are parallel making the pull value
much smaller than intended. This leads into the CEC not working as
reported by Hans Verkuil <hverkuil@xs4all.nl>.
Reported-by: Hans Verkuil <hverkuil@xs4all.nl>
Cc: Dmitry Lifshitz <lifshitz@compulab.co.il>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Motorola Droid 4 uses a WL1285C, so use proper compatible value.
To avoid regressions while support for the new compatible value
is added to the Linux kernel, the old compatible value is preserved
as fallback.
The Droid 4 has a isl29030 to measure ambient light (e.g. for
automatically adapting display brightness) and proximity.
Droid 4 has WL 1285C connected to the OMAP's UART4 port, which is
used for Bluetooth and most likely can also be used for controlling
the FM radio and GPS receivers.
Reviewed-by: Rob Herring <robh@kernel.org>
I disabled SRAM and GPMC originally when seeing errors with
omap_barriers_init(). But that is no longer happening probably
because the memory range is now properly configured to 1021 MB
instead of 1024 MB. So let's enable SRAM and GPMC so we get
omap_barriers_init() working and can idle the GPMC.
Cc: Michael Scott <michael.scott@linaro.org>
There's a typo, it should be GPIO176 and not GPIO106.
And it seems I messed up the regulators at some point while trying
to figure out what devices the regulators are used. The correct
regulator for MMC1 is vwlan2.
Fixes: 0d4cb3ccee58 ("ARM: dts: Configure regulators for droid 4")
Reported-by: Sebastian Reichel <sre@kernel.org>
Reviewed-by: Sebastian Reichel <sre@kernel.org>
Tested-by: Sebastian Reichel <sre@kernel.org>
Droid 4 has two modems, mdm6600 and w3glte. Both are on the HCI USB
controller.
Let's add a configuration for the HCI so the modems can be enabled.
Note that the modems still need additional GPIO based configuration.
Cc: devicetree@vger.kernel.org
[tony@atomide.com: left out url]
The LCD panel on droid 4 is a command mode LCD. The binding follows
the standard omapdrm binding and the changes needed for omapdrm command
mode panels are posted separately.
Tested-By: Sebastian Reichel <sre@kernel.org>
We can get HDMI working as long as the 5V regulator is on. There is
probably an encoder chip there too, but so far no idea what it might be.
Let's keep the 5V HDMI regulator always enabled for now as otherwise we
cannot detect the monitor properly.
Add tmp105 sensor for droid 4. This can be used with modprobe
lm75.ko and running sensors from lm-sensors package. Note that
the lm75.c driver does not yet support alert interrupt but
droid 4 seems to be wired for it.
Droid 4 has a GPIO line that we can use with CONFIG_POWER_RESET_GPIO.
It is probably connected to the CPCAP PMIC, and seems to power down
the whole device taking power consumption to zero based on what
I measured.
The TI LMU driver has not yet been merged, but the device
tree binding for TI LMU drivers has been acked already
earlier by Rob Herring <robh+dt@kernel.org>. So it should
be safe to apply to cut down the number of pending patches.
Cc: Rob Herring <robh+dt@kernel.org>
Acked-by: Milo Kim <milo.kim@ti.com>
Droid4's touchscreen can be used with mainline's maxtouch driver. The
touchscreen's lower area is used for four soft buttons (KEY_MENU,
KEY_HOME, KEY_BACK, KEY_SEARCH), but that does not seem to be currently
supported by the mainline kernel.
The mxt224 configuration can be saved with "mxt-app" for the kernel
to load. It can be saved after the first boot with:
# mxt-app -d i2c-dev:1-004a --save /lib/firmware/maxtouch.cfg
Where the mxt-app can be found at:
https://github.com/atmel-maxtouch/mxt-app
The firmware for the droid 4 mxt224 comes with GPLv2 license in the
Motorola Linux kernel sources. This firmware can be dumped out with
"droid4-touchscreen-firmware" program at:
https://github.com/tmlind/droid4-touchscreen-firmware
The related LCD patches are still pending, but when merged,
the touchscreen can be rotated in X with something like:
# xrandr --output DSI-1 --rotate right
# xinput set-prop 6 'Coordinate Transformation Matrix' \
0 1 0 -1 0 1 0 0 1
For now, we rely on a gpio-hog but later on we can add the reset
gpio handling to the driver and have it load the maxtouch.cfg and
maxtouch.fw on boot.
This patch is based on combined similar patches done by me and
Sebastian.
Signed-off-by: Sebastian Reichel <sre@kernel.org>
Add accelerometer.
Add compass.
On Droid 4 "Volume Down" and "Keypad Slide" keys are
connected via SoC GPIOs, "Power Key" via CPCAP and
all other keys via SoC keypad Matrix. This adds the
GPIO keys.
[tony@atomide.com: updated to apply on omap4-keypad patch]
With drivers/mfd/motorola-cpcap.c and drivers/regulator/cpcap-regulator.c
we can now configure proper regulators for droid 4.
Let's add regulator voltages and switch over MMC, eMMC and WLAN to use
the CPCAP regulators.
Let's configure the keypad in a way where it's usable out of the
box for Linux console use. We want to have the keyboard usable with
Linux console for example when stuck into an initramfs during boot,
for when installing a distro.
As we need to need to have keys mapped in the user space anyways
for some of the keys to match the labels, this non-standard mapping
or usability should be OK.
Some keys don't match the labels either as they don't follow the PC
keyboard style. For example we have "shift + ," produce "<", and
"shift + ." produce ">" instead of ";" and ":".
So let's follow the standard PC keyboard layout for ctrl, shift and
alt keys:
Ctrl = what is labeled as shift
Alt = what is labeled as SYM
Shift = what is lableled as caps lock
This way we have Ctrl key for console use. Who knows where they got
the caps lock idea.. Probably from some focus group popularity vote
or something.
For the OK key, let's keep it as the useless KEY_OK unless we can
come up with some standard mapping for it we can stick with.
We have at least Esc, Delete, Meta, and Page Down keys missing, but
none of them seem to be better than others. PC keyboard often has
Page Down in that location. Esc would be probably the most usable
one when installing a Linux distro but is the opposite of OK.
Note that the LCD keys are just touchscreen hot spots, so I'm not
sure if the driver or hardware allows setting them up as keys for
the console.
Anyways, the rest can be mapped in the user space.
Cc: Mark Rutland <mark.rutland@arm.com>
Let's add minimal support for droid 4 with MMC and WLAN working.
It can be booted with appended dtb using kexec to a state where
MMC and WLAN work with currently no support for it's PMIC or
display.
Note that we are currently using fixed regulators as we don't
have support for it's cpcap PMIC. I'll be posting regmap_spi
based minimal cpcap patches later on for USB and the debug
UART on droid 4 multiplexed with the USB connector.
