path: root/arch/arm/boot/dts/omap4-panda-es.dts
2017-05-16ARM: dts: omap4: enable CEC pin for Pandaboard A4 and ESHans Verkuil
The CEC pin was always pulled up, making it impossible to use it. Change to PIN_INPUT so it can be used by the new CEC support. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Reviewed-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-11-30ARM: dts: omap4-panda-es: Use OMAP4_IOPAD pinmux macroJavier Martinez Canillas
Use the pinmux IOPAD macros to define the register as an offset from the padconf physical address instead of the offset from padconf base. This makes the DTS easier to read since matches the addresses listed in the Technical Reference Manual. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-03ARM: dts: omap4-panda: Fix model and SoC family detailsNishanth Menon
Currently we claim that omap4-panda and omap4-panda-es are essentially the same, but they are not since PandaBoard-ES uses OMAP4460 and PandaBoard uses OMAP4430. So, split the common definition and make the model name available. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-10-20ARM: dts: omap4-panda-es: Do not reset gpio1Nishanth Menon
Do not reset GPIO1 at boot-up because GPIO 7 in GPIO1 block is used on OMAP4460 PandaBoard-ES to select voltage register in TPS62361 which supplies VDD_MPU. Without this, OMAP4460 PandaBoard-ES boards fail to boot-up because MPU voltage switches over to VSET0 voltage value (boot voltage) which is not sufficient to operate the device at OPP100. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Benoit Cousson <bcousson@baylibre.com>
2013-06-18ARM: dts: omap4-panda: Update the LED support for the pandaDan Murphy
The GPIO for LED D1 on the omap4-panda a1-a3 rev and the omap4-panda-es are different. A1-A3 = gpio_wk7 ES = gpio_110 There is no change to LED D2 Abstract away the pinmux and the LED definitions for the two boards into the respective DTS files. Signed-off-by: Dan Murphy <dmurphy@ti.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-06-18ARM: dts: OMAP2+: Use pinctrl constantsFlorian Vaussard
Using constants for pinctrl allows a better readability, and removes redundancy with comments. Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-06-18ARM: dts: OMAP2+: Use #include for all device treesFlorian Vaussard
Replace /include/ by #include for OMAP2+ DT, in order to use the C pre-processor, making use of #define features possible. Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-04-09ARM: dts: omap4-panda: move generic sections to panda-commonNishanth Menon
PandaBoard, PandaBoard-A4 revisions use OMAP4430. PandaBoard-ES version of the board uses OMAP4460. Move the original panda dts file into a common dtsi used by all panda variants. This allows us to introduce SoC variation for PandaBoard ES without impacting other PandaBoard versions that are supported. As part of this change, since OMAP4460 adds on to OMAP4430, add omap4.dtsi to omap4460.dtsi. Signed-off-by: Nishanth Menon <nm@ti.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Jon Hunter <jon-hunter@ti.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Keerthy <j-keerthy@ti.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-04-09ARM: dts: OMAP2+: Add PMU nodesJon Hunter
Add PMU nodes for OMAP2, OMAP3 and OMAP4460 devices. Please note that the node for OMAP4460 has been placed in a separate header file for OMAP4460, because the node is not compatible with OMAP4430. The node for OMAP4430 is not included because PMU is not currently supported on OMAP4430 due to the absence of a cross-trigger interface driver. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2012-11-07ARM: dts: omap4-panda: Add pinmux configuration for HDMIRicardo Neri
Add the pinmux configuration for HDMI and TPD12S015A. Configure the gpios for the TPD12S015A and SDA, SCL and CEC for HDMI. Signed-off-by: Ricardo Neri <ricardo.neri@ti.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Benoit Cousson <b-cousson@ti.com>
2012-10-29ARM: dts: OMAP: Rename pandaES and var_som for consistencyBenoit Cousson
Rename the files to have names consistent across OMAP boards. Update the Makefile to use the new name. Signed-off-by: Benoit Cousson <b-cousson@ti.com>
