The CEC pin was always pulled up, making it impossible to use it.
Change to PIN_INPUT so it can be used by the new CEC support.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Reviewed-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Use the pinmux IOPAD macros to define the register as an offset from
the padconf physical address instead of the offset from padconf base.
This makes the DTS easier to read since matches the addresses listed
in the Technical Reference Manual.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Currently we claim that omap4-panda and omap4-panda-es are essentially
the same, but they are not since PandaBoard-ES uses OMAP4460 and
PandaBoard uses OMAP4430.
So, split the common definition and make the model name available.
Signed-off-by: Nishanth Menon <nm@ti.com>
Do not reset GPIO1 at boot-up because GPIO 7 in GPIO1 block is used on
OMAP4460 PandaBoard-ES to select voltage register in TPS62361 which
supplies VDD_MPU.
Without this, OMAP4460 PandaBoard-ES boards fail to boot-up because
MPU voltage switches over to VSET0 voltage value (boot voltage) which
is not sufficient to operate the device at OPP100.
Signed-off-by: Benoit Cousson <bcousson@baylibre.com>
The GPIO for LED D1 on the omap4-panda a1-a3 rev and the omap4-panda-es
are different.
A1-A3 = gpio_wk7
ES = gpio_110
There is no change to LED D2
Abstract away the pinmux and the LED definitions for the two boards into
the respective DTS files.
Signed-off-by: Dan Murphy <dmurphy@ti.com>
Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
Using constants for pinctrl allows a better readability, and removes
redundancy with comments.
Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Replace /include/ by #include for OMAP2+ DT, in order to use the
C pre-processor, making use of #define features possible.
PandaBoard, PandaBoard-A4 revisions use OMAP4430.
PandaBoard-ES version of the board uses OMAP4460.
Move the original panda dts file into a common dtsi used by all panda
variants. This allows us to introduce SoC variation for PandaBoard ES
without impacting other PandaBoard versions that are supported.
As part of this change, since OMAP4460 adds on to OMAP4430, add
omap4.dtsi to omap4460.dtsi.
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Jon Hunter <jon-hunter@ti.com>
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Shawn Guo <shawn.guo@linaro.org>
Cc: Keerthy <j-keerthy@ti.com>
Add PMU nodes for OMAP2, OMAP3 and OMAP4460 devices.
Please note that the node for OMAP4460 has been placed in a separate
header file for OMAP4460, because the node is not compatible with
OMAP4430. The node for OMAP4430 is not included because PMU is not
currently supported on OMAP4430 due to the absence of a cross-trigger
interface driver.
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
Add the pinmux configuration for HDMI and TPD12S015A. Configure the
gpios for the TPD12S015A and SDA, SCL and CEC for HDMI.
Signed-off-by: Ricardo Neri <ricardo.neri@ti.com>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
Rename the files to have names consistent across OMAP boards.
Update the Makefile to use the new name.
