Based on 2 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation
published by the free software foundation #
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 4122 file(s).
Reviewed-by: Enrico Weigelt <info@metux.net>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de
Currently we claim that omap4-panda and omap4-panda-es are essentially
the same, but they are not since PandaBoard-ES uses OMAP4460 and
PandaBoard uses OMAP4430.
So, split the common definition and make the model name available.
Signed-off-by: Nishanth Menon <nm@ti.com>
Replace /include/ by #include for OMAP2+ DT, in order to use the
C pre-processor, making use of #define features possible.
Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
PandaBoard, PandaBoard-A4 revisions use OMAP4430.
PandaBoard-ES version of the board uses OMAP4460.
Move the original panda dts file into a common dtsi used by all panda
variants. This allows us to introduce SoC variation for PandaBoard ES
without impacting other PandaBoard versions that are supported.
As part of this change, since OMAP4460 adds on to OMAP4430, add
omap4.dtsi to omap4460.dtsi.
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Jon Hunter <jon-hunter@ti.com>
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Shawn Guo <shawn.guo@linaro.org>
Cc: Keerthy <j-keerthy@ti.com>
Add DT OPP table for OMAP443x family of devices. This data is
decoded by OF with of_init_opp_table() helper function.
OPP data here is based on existing opp4xxx_data.c
Since the omap4460 OPP tables would be different from OMAP443x,
introduce an new omap443x.dtsi for 443x specific entries and use
existing omap4.dtsi as the common dtsi file for all OMAP4 platforms.
This is in preparation to use generic cpufreq-cpu0 driver for device
tree enabled boot. Legacy non device tree enabled boot continues to
use omap-cpufreq.c and opp4xxx_data.c.
Add usb otg data node in omap4/omap3 device tree file. Also update
the node with board specific setting in omapx-<board>.dts file.
The dt data specifies among others the interface type (ULPI or UTMI),
mode which is mostly OTG, power that specifies the amount of power
this can supply when in host mode.
The information about usb otg node is available @
Documentation/devicetree/bindings/usb/omap-usb.txt
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Booting 3.8-rc6 on omap4 panda results in the following error
[ 0.444427] omap_i2c 48070000.i2c: did not get pins for i2c error: -19
[ 0.445770] omap_i2c 48070000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.473937] omap_i2c 48072000.i2c: did not get pins for i2c error: -19
[ 0.474670] omap_i2c 48072000.i2c: bus 1 rev0.11 at 400 kHz
[ 0.474822] omap_i2c 48060000.i2c: did not get pins for i2c error: -19
[ 0.476379] omap_i2c 48060000.i2c: bus 2 rev0.11 at 100 kHz
[ 0.477294] omap_i2c 48350000.i2c: did not get pins for i2c error: -19
[ 0.477996] omap_i2c 48350000.i2c: bus 3 rev0.11 at 400 kHz
[ 0.483398] Switching to clocksource 32k_counter
This happens because omap4 panda dts file is not adapted to use i2c through
pinctrl framework. Populating i2c pinctrl data to get rid of the error.
Tested on omap4460 panda with 3.8-rc6 kernel.
Signed-off-by: Sourav Poddar <sourav.poddar@ti.com>
Reported-by: Luciano Coelho <coelho@ti.com>
Add the pinmux configuration for HDMI and TPD12S015A. Configure the
gpios for the TPD12S015A and SDA, SCL and CEC for HDMI.
Signed-off-by: Ricardo Neri <ricardo.neri@ti.com>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
Add twl6030-usb data node in twl6030 device tree file. twl6030-usb is the
comparator driver for USB that detects VBUS and ID events. The dt data is
comprised of two interrupts, one for ID and one for VBUS and a phandle to the
regulator.
u-boot stopped configuring 'non essential' pins recently. The kernel needs
to configure the mux for audio needs.
Since the pinmux for these IPs are static let pinctrl to handle the mux
configuration for.
Configuring the mux for: twl6040 (audpwron, irq), McPDM and McBSP1.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
McBSP2, McBSP3 and DMIC is not usable on PandaBoard (not connected, no
external pins provided for them).
Device tree data for the EMIF sdram controllers in OMAP4
and LPDDR2 memory devices attached to OMAP4 boards.
Reviewed-by: Grant Likely <grant.likely@secretlab.ca>
Tested-by: Lokesh Vutla <lokeshvutla@ti.com>
Signed-off-by: Aneesh V <aneesh@ti.com>
[santosh.shilimkar@ti.com: Rebased against 3.6-rc]
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
[b-cousson@ti.com: Use label in board to access EMIF nodes]
Pull arm-soc device tree description updates from Arnd Bergmann:
"This branch contains two kinds of updates: Some platforms in the
process of getting converted to device tree based booting, and the
platform specific patches necessary for that are included here.
Other platforms are already converted, so we just need to update the
actual device tree source files and the binding documents to add
support for new board and new drivers.
In the future we will probably separate those into two branches, and
in the long run, the plan is to move the device tree source files out
of the kernel repository, but that has to wait until we have completed
a much larger portion of the binding documents."
Fix up trivial conflicts in arch/arm/mach-imx/clk-imx6q.c due to newly
added clkdev registers next to a few removed unnecessary ones.
* tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (119 commits)
ARM: LPC32xx: Add PWM to base dts file
ARM: EXYNOS: mark the DMA channel binding for SPI as preliminary
ARM: dts: Add nodes for spi controllers for SAMSUNG EXYNOS5 platforms
ARM: EXYNOS: Enable platform support for SPI controllers for EXYNOS5
ARM: EXYNOS: Add spi clock support for EXYNOS5
ARM: dts: Add nodes for spi controllers for SAMSUNG EXYNOS4 platforms
ARM: EXYNOS: Enable platform support for SPI controllers for EXYNOX4
ARM: EXYNOS: Fix the incorrect hierarchy of spi controller bus clock
ARM: ux500: Remove PMU platform registration when booting with DT
ARM: ux500: Remove temporary snowball_of_platform_devs enablement structure
ARM: ux500: Ensure vendor specific properties have the vendor's identifier
pinctrl: pinctrl-nomadik: Append sleepmode property with vendor specific prefixes
ARM: ux500: Move rtc-pl031 registration to Device Tree when enabled
ARM: ux500: Enable the AB8500 RTC for all DT:ed DB8500 based devices
ARM: ux500: Correctly reference IRQs supplied by the AB8500 from Device Tree
ARM: ux500: Apply ab8500-debug node do the db8500 DT structure
ARM: ux500: Add a ab8500-usb Device Tree node for db8500 based devices
ARM: ux500: Add db8500 Device Tree node for misc/ab8500-pwm
ARM: ux500: Add db8500 Device Tree node for ab8500-sysctrl
ARM: ux500: Enable LED heartbeat functionality on Snowbal via DT
PandaBoard uses twl6040 connected via McPDM for audio.
This patches fixes some status = "disable" strings to "disabled", the correct
way of disabling nodes in the devicetree.
Just the OMAP part here, the rest goes via other patches and trees.
Signed-off-by: Roland Stigge <stigge@antcom.de>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Acked-by: Benoit Cousson <b-cousson@ti.com>
Pull arm-soc driver specific updates from Olof Johansson:
"These changes are specific to some driver that may be used by multiple
boards or socs. The most significant change in here is the move of
the samsung iommu code from a platform specific in-kernel interface to
the generic iommu subsystem."
Fix up trivial conflicts in arch/arm/mach-exynos/Kconfig
* tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (28 commits)
mmc: dt: Consolidate DT bindings
iommu/exynos: Add iommu driver for EXYNOS Platforms
ARM: davinci: optimize the DMA ISR
ARM: davinci: implement DEBUG_LL port choice
ARM: tegra: Add SMMU enabler in AHB
ARM: tegra: Add Tegra AHB driver
Input: pxa27x_keypad add choice to set direct_key_mask
Input: pxa27x_keypad direct key may be low active
Input: pxa27x_keypad bug fix for direct_key_mask
Input: pxa27x_keypad keep clock on as wakeup source
ARM: dt: tegra: pinmux changes for USB ULPI
ARM: tegra: add USB ULPI PHY reset GPIO to device tree
ARM: tegra: don't hard-code USB ULPI PHY reset_gpio
ARM: tegra: change pll_p_out4's rate to 24MHz
ARM: tegra: fix pclk rate
ARM: tegra: reparent sclk to pll_c_out1
ARM: tegra: Add pllc clock init table
ARM: dt: tegra cardhu: basic audio support
ARM: dt: tegra30.dtsi: Add audio-related nodes
ARM: tegra: add AUXDATA required for audio
This patch unifies the current DT MMC bindings documentation and code,
adds generic MMC DT bindings documentation, and updates .dts files for
consistency.
[cjb: typo fixes, addition of max-frequency property]
Signed-off-by: Chris Ball <cjb@laptop.org>
Add the debug LEDs nodes for an OMAP4 PandaBoard.
Add OMAP mmc related device tree data for OMAP4.
Currenly limited to only omap4-panda and omap4-sdp
boards.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Update pandaboard dts file with required clock frequencies
for the i2c client devices existing on pandaboard.
Add the twl6030 node in i2c1 controller.
This is the minimal support needed to boot OMAP4 boards
without any crash.
The support for all the features included in this MFD will be
added later.
Add a generic i2c EEPROM entry.
Since 3.2, the CONFIG_ARM_ATAG_DTB_COMPAT config allows
an old bootloader to still use ATAG to provide cmdline.
Remove chosen/bootargs from the DTS board files.
Cc: Grant Likely <grant.likely@secretlab.ca>
Based on the original omap4-panda.dts file from Manju.
http://www.spinics.net/lists/linux-omap/msg55836.html
Add memory information and a default bootargs to allow
a boot from RAMDISK.
Cc: G, Manjunath Kondaiah <manjugk@ti.com>
