This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
This patch fixes the following DTC warnings for omap4-sdp.dtb
and omap4-sdp-es23plus.dtb:
"encoder@0 has a unit name, but no reg property"
"endpoint@0 has a unit name, but no reg property"
"connector@0 has a unit name, but no reg property"
The twl6040 codec is generating the pdmclk, which is used by the McPDM as
functional clock.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Use the pinmux IOPAD macros to define the register as an offset from
the padconf physical address instead of the offset from padconf base.
This makes the DTS easier to read since matches the addresses listed
in the Technical Reference Manual.
Many OMAP2+ DTS are not using the defined constants to express
the GPIO polarity. Replace these so the DTS are easier to read.
Pull ARM DT updates from Olof Johansson:
"As always, this tends to be one of our bigger branches. There are
lots of updates this release, but not that many jumps out as something
that needs more detailed coverage. Some of the highlights are:
- DTs for the new Annapurna Labs Alpine platform
- more graphics DT pieces falling into place on Exynos, bridges,
clocks.
- plenty of DT updates for Qualcomm platforms for various IP blocks
- some churn on Tegra due to switch-over to tool-generated pinctrl
data
- misc fixes and updates for Atmel at91 platforms
- various DT updates to add IP block support on Broadcom's Cygnus
platforms
- more updates for Renesas platforms as DT support is added for
various IP blocks (IPMMU, display, audio, etc)"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (231 commits)
ARM: dts: alpine: add internal pci
Revert "ARM: dts: mt8135: Add pinctrl/GPIO/EINT node for mt8135."
ARM: mvebu: use 0xf1000000 as internal registers on Armada 370 DB
ARM: dts: qcom: Add idle state device nodes for 8064
ARM: dts: qcom: Add idle states device nodes for 8084
ARM: dts: qcom: Add idle states device nodes for 8974/8074
ARM: dts: qcom: Update power-controller device node for 8064 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8084 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8074 Krait CPUs
devicetree: bindings: Document qcom,idle-states
devicetree: bindings: Update qcom,saw2 node bindings
dt-bindings: Add #defines for MSM8916 clocks and resets
arm: dts: qcom: Add LPASS Audio HW to IPQ8064 device tree
arm: dts: qcom: Add APQ8084 chipset SPMI PMIC's nodes
arm: dts: qcom: Add 8x74 chipset SPMI PMIC's nodes
arm: dts: qcom: Add SPMI PMIC Arbiter nodes for APQ8084 and MSM8974
arm: dts: qcom: Add LCC nodes
arm: dts: qcom: Add TCSR support for MSM8960
arm: dts: qcom: Add TCSR support for MSM8660
arm: dts: qcom: Add TCSR support for IPQ8064
Replace all the pdata-quirks for setting wl12xx/wl18xx
platform data with proper DT definitions.
Signed-off-by: Eliad Peller <eliad@wizery.com>
Acked-by: Javier Martinez Canillas <javier@dowhile0.org>
Acked-by: Enric Balletbo i Serra <eballetbo@gmail.com>
Tested-by: Nikita Kiryanov <nikita@compulab.co.il>
Tested-by: Tony Lindgren <tony@atomide.com>
Acked-by: Kalle Valo <kvalo@codeaurora.org>
OMAP4/5 has been (ab)using the gic_arch_extn to provide
wakeup from suspend, and it makes a lot of sense to convert
this code to use stacked domains instead.
This patch does just this, updating the DT files to actually
reflect what the HW provides.
BIG FAT WARNING: because the DTs were so far lying by not
exposing the WUGEN HW block, kernels with this patch applied
won't have any suspend-resume facility when booted with old DTs,
and old kernels with updated DTs won't even boot.
On a platform with this patch applied, the system looks like
this:
root@bacon-fat:~# cat /proc/interrupts
CPU0 CPU1
16: 0 0 WUGEN 37 gp_timer
19: 233799 155916 GIC 27 arch_timer
23: 0 0 WUGEN 9 l3-dbg-irq
24: 1 0 WUGEN 10 l3-app-irq
27: 282 0 WUGEN 13 omap-dma-engine
44: 0 0 4ae10000.gpio 13 DMA
294: 0 0 WUGEN 20 gpmc
297: 506 0 WUGEN 56 48070000.i2c
298: 0 0 WUGEN 57 48072000.i2c
299: 0 0 WUGEN 61 48060000.i2c
300: 0 0 WUGEN 62 4807a000.i2c
301: 8 0 WUGEN 60 4807c000.i2c
308: 2439 0 WUGEN 74 OMAP UART2
312: 362 0 WUGEN 83 mmc2
313: 502 0 WUGEN 86 mmc0
314: 13 0 WUGEN 94 mmc1
350: 0 0 PRCM pinctrl, pinctrl
406: 35155709 0 GIC 109 ehci_hcd:usb1
407: 0 0 WUGEN 7 palmas
409: 0 0 WUGEN 119 twl6040
410: 0 0 twl6040 5 twl6040_irq_ready
411: 0 0 twl6040 0 twl6040_irq_th
IPI0: 0 1 CPU wakeup interrupts
IPI1: 0 0 Timer broadcast interrupts
IPI2: 95334 902334 Rescheduling interrupts
IPI3: 0 0 Function call interrupts
IPI4: 479 648 Single function call interrupts
IPI5: 0 0 CPU stop interrupts
IPI6: 0 0 IRQ work interrupts
IPI7: 0 0 completion interrupts
Err: 0
Link: https://lkml.kernel.org/r/1426088629-15377-8-git-send-email-marc.zyngier@arm.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
We've had deeper idle states working on omaps for few years now,
but only in the legacy mode. When booted with device tree, the
wake-up events did not have a chance to work until commit
3e6cee1786a1 (pinctrl: single: Add support for wake-up interrupts)
that recently got merged. In addition to that we also needed commit
79d9701559a9 (of/irq: create interrupts-extended property) and
9ec36cafe43b (of/irq: do irq resolution in platform_get_irq) that
are now also merged.
So let's fix the wake-up events for some selected omaps so devices
booted in device tree mode won't just hang if deeper power states
are enabled, and so systems can wake up from suspend to the serial
port event.
Note that there's no longer need to specify the wake-up bit in
the pinctrl settings, the request_irq on the wake-up pin takes
care of that.
Cc: devicetree@vger.kernel.org
Cc: "Benoît Cousson" <bcousson@baylibre.com>
Cc: Kevin Hilman <khilman@linaro.org>
Cc: Nishanth Menon <nm@ti.com>
Cc: Paul Walmsley <paul@pwsan.com>
Cc: Tero Kristo <t-kristo@ti.com>
[tony@atomide.com: updated comments, added board LDP]
Add DT data for OMAP4 SDP board. The board has the following displays:
lcd0: a command mode DSI panel connected to OMAP DSI1 encoder
lcd1: a command mode DSI panel connected to OMAP DSI2 encoder
hdmi: OMAP HDMI output with TPD12S015 ESD/level shifter
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
All audio nodes has been set to disabled state in omap4.dtsi file.
Attach the pinctrl nodes to their respective device node:
mcbsp1, mcbsp2, dmic, mcpdm and twl6040.
Mux mode for wlan/sdmmc5 should be MODE0 in pinmux_wl12xx_pins and
Enable Pull up on sdmmc5_clk to detect SDIO card.
This fixes WLAN on omap4-sdp that got broken in v3.10 when we
moved omap4 to boot using device tree only as I did not have
the WL12XX card in my omap4 SDP to test with. The commit that
attempted to make WL12XX working on omap4 SDP was 775d2418f309
(ARM: dts: Fix muxing and regulator for wl12xx on the SDIO
bus for blaze).
Signed-off-by: Balaji T K <balajitk@ti.com>
[tony@atomide.com: updated comments for the regression]
dtsi file
The OMAP4 SoC family uses specially-designed PMIC (power management IC)
companion chip for power management needs: TWL6030/TWL6032.
Therefore there is a typical connection of PMIC to OMAP4 so we can
move it into separate .dtsi file and do not duplicate over
board-specific files.
Tested on OMAP4 SDP board and Pandaboard ES2.
Signed-off-by: Ruslan Bilovol <ruslan.bilovol@ti.com>
Signed-off-by: Benoit Cousson <bcousson@baylibre.com>
Commit 76787b3b (ARM: OMAP2+: Remove board-4430sdp.c)
removed legacy booting in favor of device tree based booting
for 4430sdp. That caused the WLAN to stop working as the
related .dts entries fell through the cracks.
I don't have the "1283 PG 2.21 connectivity device" on my 4430sdp,
but the earlier version of this patch was tested by Luciano
Coelho. This version has left out the input logic for MMC CLK
line compared to the earlier version as that is not bidirectional,
and should be safe to do.
Cc: Rajendra Nayak <rnayak@ti.com>
Cc: Luciano Coelho <luca@coelho.fi>
Cc: Ruslan Bilovol <ruslan.bilovol@ti.com>
Using constants for pinctrl allows a better readability, and removes
redundancy with comments.
Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
Use the constants defined in include/dt-bindings/interrupt-controller/
to enhance readability.
Use standard GPIO constants to enhance the readability of DT GPIOs.
Replace /include/ by #include for OMAP2+ DT, in order to use the
C pre-processor, making use of #define features possible.
Earlier commits ensured proper muxing of pins related to proper
TWL6030 behavior: see commit 265a2bc8 (ARM: OMAP3: TWL4030: ensure
sys_nirq1 is mux'd and wakeup enabled) and commit 1ef43369 (ARM:
OMAP4: TWL: mux sys_drm_msecure as output for PMIC).
However these only fixed legacy boot and not DT boot. For DT boot,
the default mux values need to be set properly in DT.
Special thanks to Nishanth Menon for the review and catching some
major flaws in earlier versions.
Tested on OMAP4430/Panda and OMAP4460/Panda-ES.
Cc: Tony Lindgren <tony@atomide.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
Acked-by: Grygorii Strashko <grygorii.strashko@ti.com>
[benoit.cousson@linaro.org: Slightly change the subject to align
board name with file name]
The bootloader configures the pins, but has pull bits
set without pull enable bits. While this is harmless,
and won't do anything, it seems to cause confusion at
least for me every time looking at the pin configuration.
Fix it for DT based boot.
Commit ff5c9059 (ARM: dts: OMAP3+: Correct gpio #interrupts-cells
property) updated the number of interrupt cells required for configuring
gpios as interrupts for other devices (such as ethernet controllers).
This update allowed the interrupt type (edge, level, etc) to be
configured via device-tree (as described in the
Documentation/devicetree/bindings/gpio/gpio-omap.txt).
This broke ethernet support on the OMAP4 SDP board that defines a gpio
as the ethernet IRQ because the interrupt type (level, edge, etc) was
not getting configured correctly. This board use the ks8851 ethernet
chip which has an active low interrupt. Fix this by defining the gpio
interrupt as active-low in the device-tree binding.
Please note that the OMAP4-VAR-SOM also uses the same ethernet
controller and it is expected it will have the same problem. So the
same fix is also applied to this board.
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
Add DT OPP table for OMAP443x family of devices. This data is
decoded by OF with of_init_opp_table() helper function.
OPP data here is based on existing opp4xxx_data.c
Since the omap4460 OPP tables would be different from OMAP443x,
introduce an new omap443x.dtsi for 443x specific entries and use
existing omap4.dtsi as the common dtsi file for all OMAP4 platforms.
This is in preparation to use generic cpufreq-cpu0 driver for device
tree enabled boot. Legacy non device tree enabled boot continues to
use omap-cpufreq.c and opp4xxx_data.c.
Signed-off-by: Nishanth Menon <nm@ti.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Jon Hunter <jon-hunter@ti.com>
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Shawn Guo <shawn.guo@linaro.org>
Cc: Keerthy <j-keerthy@ti.com>
Add usb otg data node in omap4/omap3 device tree file. Also update
the node with board specific setting in omapx-<board>.dts file.
The dt data specifies among others the interface type (ULPI or UTMI),
mode which is mostly OTG, power that specifies the amount of power
this can supply when in host mode.
The information about usb otg node is available @
Documentation/devicetree/bindings/usb/omap-usb.txt
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Booting 3.8-rc6 on omap 4430sdp results in the following error
omap_i2c 48070000.i2c: did not get pins for i2c error: -19
[ 1.024261] omap_i2c 48070000.i2c: bus 0 rev0.12 at 100 kHz
[ 1.030181] omap_i2c 48072000.i2c: did not get pins for i2c error: -19
[ 1.037384] omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz
[ 1.043762] omap_i2c 48060000.i2c: did not get pins for i2c error: -19
[ 1.050964] omap_i2c 48060000.i2c: bus 2 rev0.12 at 100 kHz
[ 1.056823] omap_i2c 4807a000.i2c: did not get pins for i2c error: -19
[ 1.064025] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
This happens because omap4 dts file is not adapted to use i2c through pinctrl
framework. Populating i2c pinctrl data to get rid of the error.
Tested on omap4430 sdp with 3.8-rc6 kernel.
Signed-off-by: Sourav Poddar <sourav.poddar@ti.com>
Reported-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Section to describe the backlight for the LCD panels.
Sections to describe the pwm-leds in the system.
Add the pinmux configuration for HDMI and TPD12S015A. Configure the
gpios for the TPD12S015A and SDA, SCL and CEC for HDMI.
Signed-off-by: Ricardo Neri <ricardo.neri@ti.com>
Signed-off-by: Benoit Cousson <b-cousson@ti.com>
Add twl6030-usb data node in twl6030 device tree file. twl6030-usb is the
comparator driver for USB that detects VBUS and ID events. The dt data is
comprised of two interrupts, one for ID and one for VBUS and a phandle to the
regulator.
u-boot stopped configuring 'non essential' pins recently. The kernel needs
to configure the mux for audio needs.
Since the pinmux for these IPs are static let pinctrl to handle the mux
configuration for.
Configuring the mux for: twl6040 (audpwron, irq), McPDM, DMIC, McBSP1 and
McBSP2.
McBSP3 is not usable on OMAP4 SDP/Blaze (the pins used for McPDM).
Mux uart pins for the serial ports.
Device tree data for the EMIF sdram controllers in OMAP4
and LPDDR2 memory devices attached to OMAP4 boards.
Reviewed-by: Grant Likely <grant.likely@secretlab.ca>
Tested-by: Lokesh Vutla <lokeshvutla@ti.com>
Signed-off-by: Aneesh V <aneesh@ti.com>
[santosh.shilimkar@ti.com: Rebased against 3.6-rc]
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
[b-cousson@ti.com: Use label in board to access EMIF nodes]
Add keypad data node in omap4 device tree file.
Also fill the device tree binding parameters
with the required value in "omap4-sdp" dts file.
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Felipe Balbi <balbi@ti.com>
[b-cousson@ti.com: Re-align the entries and the comments]
regulators do not have a 'reg' property, hence the regulator@0,
regulator@1 do not make sense. get rid of it.
Reported-by: David Brown <davidb@codeaurora.org>
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Pull arm-soc device tree description updates from Arnd Bergmann:
"This branch contains two kinds of updates: Some platforms in the
process of getting converted to device tree based booting, and the
platform specific patches necessary for that are included here.
Other platforms are already converted, so we just need to update the
actual device tree source files and the binding documents to add
support for new board and new drivers.
In the future we will probably separate those into two branches, and
in the long run, the plan is to move the device tree source files out
of the kernel repository, but that has to wait until we have completed
a much larger portion of the binding documents."
Fix up trivial conflicts in arch/arm/mach-imx/clk-imx6q.c due to newly
added clkdev registers next to a few removed unnecessary ones.
* tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (119 commits)
ARM: LPC32xx: Add PWM to base dts file
ARM: EXYNOS: mark the DMA channel binding for SPI as preliminary
ARM: dts: Add nodes for spi controllers for SAMSUNG EXYNOS5 platforms
ARM: EXYNOS: Enable platform support for SPI controllers for EXYNOS5
ARM: EXYNOS: Add spi clock support for EXYNOS5
ARM: dts: Add nodes for spi controllers for SAMSUNG EXYNOS4 platforms
ARM: EXYNOS: Enable platform support for SPI controllers for EXYNOX4
ARM: EXYNOS: Fix the incorrect hierarchy of spi controller bus clock
ARM: ux500: Remove PMU platform registration when booting with DT
ARM: ux500: Remove temporary snowball_of_platform_devs enablement structure
ARM: ux500: Ensure vendor specific properties have the vendor's identifier
pinctrl: pinctrl-nomadik: Append sleepmode property with vendor specific prefixes
ARM: ux500: Move rtc-pl031 registration to Device Tree when enabled
ARM: ux500: Enable the AB8500 RTC for all DT:ed DB8500 based devices
ARM: ux500: Correctly reference IRQs supplied by the AB8500 from Device Tree
ARM: ux500: Apply ab8500-debug node do the db8500 DT structure
ARM: ux500: Add a ab8500-usb Device Tree node for db8500 based devices
ARM: ux500: Add db8500 Device Tree node for misc/ab8500-pwm
ARM: ux500: Add db8500 Device Tree node for ab8500-sysctrl
ARM: ux500: Enable LED heartbeat functionality on Snowbal via DT
On OMAP4 SDP the audio setup includes the twl6040 codec and digital
microphones.
Since OMAP4 SDP is a reference board it has all possible audio interfaces
connected. This information is passed via the ti,audio-routing
property.
The twl6040 provides the audio and vibra support on OMAP4 SDP boards.
It is connected to i2c1 bus with 0x4b address.
There are devices connected to VBAT.
This patches fixes some status = "disable" strings to "disabled", the correct
way of disabling nodes in the devicetree.
Just the OMAP part here, the rest goes via other patches and trees.
Signed-off-by: Roland Stigge <stigge@antcom.de>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Acked-by: Benoit Cousson <b-cousson@ti.com>
Pull arm-soc driver specific updates from Olof Johansson:
"These changes are specific to some driver that may be used by multiple
boards or socs. The most significant change in here is the move of
the samsung iommu code from a platform specific in-kernel interface to
the generic iommu subsystem."
Fix up trivial conflicts in arch/arm/mach-exynos/Kconfig
* tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (28 commits)
mmc: dt: Consolidate DT bindings
iommu/exynos: Add iommu driver for EXYNOS Platforms
ARM: davinci: optimize the DMA ISR
ARM: davinci: implement DEBUG_LL port choice
ARM: tegra: Add SMMU enabler in AHB
ARM: tegra: Add Tegra AHB driver
Input: pxa27x_keypad add choice to set direct_key_mask
Input: pxa27x_keypad direct key may be low active
Input: pxa27x_keypad bug fix for direct_key_mask
Input: pxa27x_keypad keep clock on as wakeup source
ARM: dt: tegra: pinmux changes for USB ULPI
ARM: tegra: add USB ULPI PHY reset GPIO to device tree
ARM: tegra: don't hard-code USB ULPI PHY reset_gpio
ARM: tegra: change pll_p_out4's rate to 24MHz
ARM: tegra: fix pclk rate
ARM: tegra: reparent sclk to pll_c_out1
ARM: tegra: Add pllc clock init table
ARM: dt: tegra cardhu: basic audio support
ARM: dt: tegra30.dtsi: Add audio-related nodes
ARM: tegra: add AUXDATA required for audio
This patch unifies the current DT MMC bindings documentation and code,
adds generic MMC DT bindings documentation, and updates .dts files for
consistency.
[cjb: typo fixes, addition of max-frequency property]
Signed-off-by: Chris Ball <cjb@laptop.org>
Add the debug LEDs nodes for an OMAP4 SDP/Blaze.
Add OMAP mmc related device tree data for OMAP4.
Currenly limited to only omap4-panda and omap4-sdp
boards.
Add an ethernet SPI chip in the OMAP4 SDP/Blaze board DTS file.
Add a fixed regulator node controlled by a GPIO line to supply
the ethernet chip.
Based on original code from Rajendra.
Update DTS file with required clock frequencies
for the i2c client devices existing on sdp4430.
Add the twl6030 node inside the i2c1 controller node.
This is the minimal support needed to boot OMAP4 boards
without any crash.
The support for all the features included in this MFD will be
added later.
Add the RTC submodule inside the twl node.
Add tmp105 temperature sensor in i2c3
Add bh1780 Ambient Light Sensor in i2c3
Add hmc5843 3-Axis Digital Compass in i2c4
Since 3.2, the CONFIG_ARM_ATAG_DTB_COMPAT config allows
an old bootloader to still use ATAG to provide cmdline.
Remove chosen/bootargs from the DTS board files.
Add the SDP/Blaze (Software Development Board) support with
device tree.
That file is based on the omap4-panda.dts.
Cc: G, Manjunath Kondaiah <manjugk@ti.com>
