path: root/arch/arm/boot/dts/omap4-sdp.dts
2013-06-03ARM: dts: omap4-panda|sdp: Fix mux for twl6030 IRQ pin and msecure lineKevin Hilman
Earlier commits ensured proper muxing of pins related to proper TWL6030 behavior: see commit 265a2bc8 (ARM: OMAP3: TWL4030: ensure sys_nirq1 is mux'd and wakeup enabled) and commit 1ef43369 (ARM: OMAP4: TWL: mux sys_drm_msecure as output for PMIC). However these only fixed legacy boot and not DT boot. For DT boot, the default mux values need to be set properly in DT. Special thanks to Nishanth Menon for the review and catching some major flaws in earlier versions. Tested on OMAP4430/Panda and OMAP4460/Panda-ES. Cc: Nishanth Menon <nm@ti.com> Cc: Tony Lindgren <tony@atomide.com> Signed-off-by: Kevin Hilman <khilman@linaro.org> Acked-by: Grygorii Strashko <grygorii.strashko@ti.com> [benoit.cousson@linaro.org: Slightly change the subject to align board name with file name] Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-05-08ARM: dts: Configure and fix the McSPI pins for 4430sdpTony Lindgren
The bootloader configures the pins, but has pull bits set without pull enable bits. While this is harmless, and won't do anything, it seems to cause confusion at least for me every time looking at the pin configuration. Fix it for DT based boot. Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-05-08ARM: dts: OMAP4: Fix ethernet IRQ for OMAP4 boardsJon Hunter
Commit ff5c9059 (ARM: dts: OMAP3+: Correct gpio #interrupts-cells property) updated the number of interrupt cells required for configuring gpios as interrupts for other devices (such as ethernet controllers). This update allowed the interrupt type (edge, level, etc) to be configured via device-tree (as described in the Documentation/devicetree/bindings/gpio/gpio-omap.txt). This broke ethernet support on the OMAP4 SDP board that defines a gpio as the ethernet IRQ because the interrupt type (level, edge, etc) was not getting configured correctly. This board use the ks8851 ethernet chip which has an active low interrupt. Fix this by defining the gpio interrupt as active-low in the device-tree binding. Please note that the OMAP4-VAR-SOM also uses the same ethernet controller and it is expected it will have the same problem. So the same fix is also applied to this board. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-04-09ARM: dts: OMAP443x: Add CPU OPP tableNishanth Menon
Add DT OPP table for OMAP443x family of devices. This data is decoded by OF with of_init_opp_table() helper function. OPP data here is based on existing opp4xxx_data.c Since the omap4460 OPP tables would be different from OMAP443x, introduce an new omap443x.dtsi for 443x specific entries and use existing omap4.dtsi as the common dtsi file for all OMAP4 platforms. This is in preparation to use generic cpufreq-cpu0 driver for device tree enabled boot. Legacy non device tree enabled boot continues to use omap-cpufreq.c and opp4xxx_data.c. Signed-off-by: Nishanth Menon <nm@ti.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Jon Hunter <jon-hunter@ti.com> Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Keerthy <j-keerthy@ti.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-04-09ARM: dts: OMAP: Add usb_otg and glue data to OMAP3+ boardsKishon Vijay Abraham I
Add usb otg data node in omap4/omap3 device tree file. Also update the node with board specific setting in omapx-<board>.dts file. The dt data specifies among others the interface type (ULPI or UTMI), mode which is mostly OTG, power that specifies the amount of power this can supply when in host mode. The information about usb otg node is available @ Documentation/devicetree/bindings/usb/omap-usb.txt Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-04-09ARM: dts: omap4-sdp: Add I2c pinctrl dataSourav Poddar
Booting 3.8-rc6 on omap 4430sdp results in the following error omap_i2c 48070000.i2c: did not get pins for i2c error: -19 [ 1.024261] omap_i2c 48070000.i2c: bus 0 rev0.12 at 100 kHz [ 1.030181] omap_i2c 48072000.i2c: did not get pins for i2c error: -19 [ 1.037384] omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz [ 1.043762] omap_i2c 48060000.i2c: did not get pins for i2c error: -19 [ 1.050964] omap_i2c 48060000.i2c: bus 2 rev0.12 at 100 kHz [ 1.056823] omap_i2c 4807a000.i2c: did not get pins for i2c error: -19 [ 1.064025] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz This happens because omap4 dts file is not adapted to use i2c through pinctrl framework. Populating i2c pinctrl data to get rid of the error. Tested on omap4430 sdp with 3.8-rc6 kernel. Signed-off-by: Sourav Poddar <sourav.poddar@ti.com> Reported-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-04-09ARM: dts: omap4-sdp: Add support for pwm-backlightPeter Ujfalusi
Section to describe the backlight for the LCD panels. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-04-09ARM: dts: omap4-sdp: Add support for pwm-leds (keypad and charging LED)Peter Ujfalusi
Sections to describe the pwm-leds in the system. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2012-11-07ARM: dts: omap4-sdp: Add pinmux configuration for HDMIRicardo Neri
Add the pinmux configuration for HDMI and TPD12S015A. Configure the gpios for the TPD12S015A and SDA, SCL and CEC for HDMI. Signed-off-by: Ricardo Neri <ricardo.neri@ti.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Benoit Cousson <b-cousson@ti.com>
2012-10-29ARM: dts: Add twl6030-usb dataKishon Vijay Abraham I
Add twl6030-usb data node in twl6030 device tree file. twl6030-usb is the comparator driver for USB that detects VBUS and ID events. The dt data is comprised of two interrupts, one for ID and one for VBUS and a phandle to the regulator. Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Benoit Cousson <b-cousson@ti.com>
2012-10-08ARM/dts: omap4-sdp: pinmux configuration for audioPeter Ujfalusi
u-boot stopped configuring 'non essential' pins recently. The kernel needs to configure the mux for audio needs. Since the pinmux for these IPs are static let pinctrl to handle the mux configuration for. Configuring the mux for: twl6040 (audpwron, irq), McPDM, DMIC, McBSP1 and McBSP2. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-10-08ARM/dts: omap4-sdp: Disable unused McBSP3Peter Ujfalusi
McBSP3 is not usable on OMAP4 SDP/Blaze (the pins used for McPDM). Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-10arm/dts: Mux uart pins for omap4-sdpTony Lindgren
Mux uart pins for the serial ports. Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-07ARM: dts: EMIF and LPDDR2 device tree data for OMAP4 boardsAneesh V
Device tree data for the EMIF sdram controllers in OMAP4 and LPDDR2 memory devices attached to OMAP4 boards. Reviewed-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Aneesh V <aneesh@ti.com> [santosh.shilimkar@ti.com: Rebased against 3.6-rc] Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> [b-cousson@ti.com: Use label in board to access EMIF nodes] Signed-off-by: Benoit Cousson <b-cousson@ti.com>
2012-09-07ARM: dts: omap4-sdp: Add keypad dataSourav Poddar
Add keypad data node in omap4 device tree file. Also fill the device tree binding parameters with the required value in "omap4-sdp" dts file. Signed-off-by: Sourav Poddar <sourav.poddar@ti.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Felipe Balbi <balbi@ti.com> Signed-off-by: Benoit Cousson <b-cousson@ti.com> [b-cousson@ti.com: Re-align the entries and the comments]
2012-08-30arm/dts: Cleanup regulator naming and remove @0,1Rajendra Nayak
regulators do not have a 'reg' property, hence the regulator@0, regulator@1 do not make sense. get rid of it. Reported-by: David Brown <davidb@codeaurora.org> Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-07-23Merge tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc device tree description updates from Arnd Bergmann: "This branch contains two kinds of updates: Some platforms in the process of getting converted to device tree based booting, and the platform specific patches necessary for that are included here. Other platforms are already converted, so we just need to update the actual device tree source files and the binding documents to add support for new board and new drivers. In the future we will probably separate those into two branches, and in the long run, the plan is to move the device tree source files out of the kernel repository, but that has to wait until we have completed a much larger portion of the binding documents." Fix up trivial conflicts in arch/arm/mach-imx/clk-imx6q.c due to newly added clkdev registers next to a few removed unnecessary ones. * tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (119 commits) ARM: LPC32xx: Add PWM to base dts file ARM: EXYNOS: mark the DMA channel binding for SPI as preliminary ARM: dts: Add nodes for spi controllers for SAMSUNG EXYNOS5 platforms ARM: EXYNOS: Enable platform support for SPI controllers for EXYNOS5 ARM: EXYNOS: Add spi clock support for EXYNOS5 ARM: dts: Add nodes for spi controllers for SAMSUNG EXYNOS4 platforms ARM: EXYNOS: Enable platform support for SPI controllers for EXYNOX4 ARM: EXYNOS: Fix the incorrect hierarchy of spi controller bus clock ARM: ux500: Remove PMU platform registration when booting with DT ARM: ux500: Remove temporary snowball_of_platform_devs enablement structure ARM: ux500: Ensure vendor specific properties have the vendor's identifier pinctrl: pinctrl-nomadik: Append sleepmode property with vendor specific prefixes ARM: ux500: Move rtc-pl031 registration to Device Tree when enabled ARM: ux500: Enable the AB8500 RTC for all DT:ed DB8500 based devices ARM: ux500: Correctly reference IRQs supplied by the AB8500 from Device Tree ARM: ux500: Apply ab8500-debug node do the db8500 DT structure ARM: ux500: Add a ab8500-usb Device Tree node for db8500 based devices ARM: ux500: Add db8500 Device Tree node for misc/ab8500-pwm ARM: ux500: Add db8500 Device Tree node for ab8500-sysctrl ARM: ux500: Enable LED heartbeat functionality on Snowbal via DT ...
2012-07-09arm/dts: omap4-sdp: Enable audio support via device treePeter Ujfalusi
On OMAP4 SDP the audio setup includes the twl6040 codec and digital microphones. Since OMAP4 SDP is a reference board it has all possible audio interfaces connected. This information is passed via the ti,audio-routing property. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-07-09arm/dts: omap4-sdp: Add support for twl6040Peter Ujfalusi
The twl6040 provides the audio and vibra support on OMAP4 SDP boards. It is connected to i2c1 bus with 0x4b address. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-07-09arm/dts: omap4-sdp: Add fixed regulator to represent VBATPeter Ujfalusi
There are devices connected to VBAT. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-06-21ARM: OMAP: Fix dts files w/ status property: "disable" -> "disabled"Roland Stigge
This patches fixes some status = "disable" strings to "disabled", the correct way of disabling nodes in the devicetree. Just the OMAP part here, the rest goes via other patches and trees. Signed-off-by: Roland Stigge <stigge@antcom.de> Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Benoit Cousson <b-cousson@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-05-26Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc driver specific updates from Olof Johansson: "These changes are specific to some driver that may be used by multiple boards or socs. The most significant change in here is the move of the samsung iommu code from a platform specific in-kernel interface to the generic iommu subsystem." Fix up trivial conflicts in arch/arm/mach-exynos/Kconfig * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (28 commits) mmc: dt: Consolidate DT bindings iommu/exynos: Add iommu driver for EXYNOS Platforms ARM: davinci: optimize the DMA ISR ARM: davinci: implement DEBUG_LL port choice ARM: tegra: Add SMMU enabler in AHB ARM: tegra: Add Tegra AHB driver Input: pxa27x_keypad add choice to set direct_key_mask Input: pxa27x_keypad direct key may be low active Input: pxa27x_keypad bug fix for direct_key_mask Input: pxa27x_keypad keep clock on as wakeup source ARM: dt: tegra: pinmux changes for USB ULPI ARM: tegra: add USB ULPI PHY reset GPIO to device tree ARM: tegra: don't hard-code USB ULPI PHY reset_gpio ARM: tegra: change pll_p_out4's rate to 24MHz ARM: tegra: fix pclk rate ARM: tegra: reparent sclk to pll_c_out1 ARM: tegra: Add pllc clock init table ARM: dt: tegra cardhu: basic audio support ARM: dt: tegra30.dtsi: Add audio-related nodes ARM: tegra: add AUXDATA required for audio ...
2012-05-15mmc: dt: Consolidate DT bindingsArnd Bergmann
This patch unifies the current DT MMC bindings documentation and code, adds generic MMC DT bindings documentation, and updates .dts files for consistency. [cjb: typo fixes, addition of max-frequency property] Signed-off-by: Chris Ball <cjb@laptop.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-05-09arm/dts: omap4-sdp: Add LEDs supportBenoit Cousson
Add the debug LEDs nodes for an OMAP4 SDP/Blaze. Signed-off-by: Benoit Cousson <b-cousson@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-03-14arm/dts: OMAP4: Add mmc controller nodes and board dataRajendra Nayak
Add OMAP mmc related device tree data for OMAP4. Currenly limited to only omap4-panda and omap4-sdp boards. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Benoit Cousson <b-cousson@ti.com>
2012-03-12arm/dts: omap4-sdp: Add ks8851 ethernet SPI deviceBenoit Cousson
Add an ethernet SPI chip in the OMAP4 SDP/Blaze board DTS file. Add a fixed regulator node controlled by a GPIO line to supply the ethernet chip. Based on original code from Rajendra. Signed-off-by: Benoit Cousson <b-cousson@ti.com> Signed-off-by: Rajendra Nayak <rnayak@ti.com> Acked-by: Rob Herring <rob.herring@calxeda.com>
2012-03-07arm/dts: omap4-sdp: Add twl6030, i2c3 and i2c4 devicesBenoit Cousson
Update DTS file with required clock frequencies for the i2c client devices existing on sdp4430. Add the twl6030 node inside the i2c1 controller node. This is the minimal support needed to boot OMAP4 boards without any crash. The support for all the features included in this MFD will be added later. Add the RTC submodule inside the twl node. Add tmp105 temperature sensor in i2c3 Add bh1780 Ambient Light Sensor in i2c3 Add hmc5843 3-Axis Digital Compass in i2c4 Signed-off-by: Benoit Cousson <b-cousson@ti.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Rob Herring <rob.herring@calxeda.com>
2011-12-13arm/dts: OMAP: Remove bootargs node from board filesBenoit Cousson
Since 3.2, the CONFIG_ARM_ATAG_DTB_COMPAT config allows an old bootloader to still use ATAG to provide cmdline. Remove chosen/bootargs from the DTS board files. Signed-off-by: Benoit Cousson <b-cousson@ti.com> Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-10-04arm/dts: Add support for OMAP4 SDP boardBenoit Cousson
Add the SDP/Blaze (Software Development Board) support with device tree. That file is based on the omap4-panda.dts. Signed-off-by: Benoit Cousson <b-cousson@ti.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Cc: G, Manjunath Kondaiah <manjugk@ti.com>
