Currently the slope and offset values for calculating the
hot spot temperature of a particular thermal zone is part
of driver data. Pass them here instead and obtain the values
while of node parsing.
Signed-off-by: Keerthy <j-keerthy@ti.com>
This patch fixes the following DTC warnings:
"bandgap has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Add ABB device nodes for OMAP443x family of devices. abb_iva is
populated, but disabled as it is not used on current OMAP443x family,
but the node is used on OMAP446x family. Data is based on OMAP443x
Technical Reference Manual revision AN (April 2013).
ABB device nodes for OMAP4460 device Data is based on OMAP4460
Technical Reference Manual revision Z (April 2013)
[nm@ti.com: co-developer]
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Andrii.Tseglytskyi <andrii.tseglytskyi@ti.com>
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
git://git.linaro.org/people/mike.turquette/linux
Pull more clock framework changes from Mike Turquette:
"The second half of the clock framework pull requeust for 3.14 is
dominated by platform support for Qualcomm's MSM SoCs, DT binding
updates for TI's OMAP-ish processors and additional support for
Samsung chips.
Additionally there are other smaller clock driver changes and several
last minute fixes. This pull request also includes the HiSilicon
support that depends on the already-merged arm-soc pull request"
[ Fix up stupid compile error in the source tree with evil merge - Grumpy Linus ]
* tag 'clk-for-linus-3.14-part2' of git://git.linaro.org/people/mike.turquette/linux: (49 commits)
clk: sort Makefile
clk: sunxi: fix overflow when setting up divided factors
clk: Export more clk-provider functions
dt-bindings: qcom: Fix warning with duplicate dt define
clk: si5351: remove variant from platform_data
clk: samsung: Remove unneeded semicolon
clk: qcom: Fix modular build
ARM: OMAP3: use DT clock init if DT data is available
ARM: AM33xx: remove old clock data and link in new clock init code
ARM: AM43xx: Enable clock init
ARM: OMAP: DRA7: Enable clock init
ARM: OMAP4: remove old clock data and link in new clock init code
ARM: OMAP2+: io: use new clock init API
ARM: OMAP2+: PRM: add support for initializing PRCM clock modules from DT
ARM: OMAP3: hwmod: initialize clkdm from clkdm_name
ARM: OMAP: hwmod: fix an incorrect clk type cast with _get_clkdm
ARM: OMAP2+: clock: use driver API instead of direct memory read/write
ARM: OMAP2+: clock: add support for indexed memmaps
ARM: dts: am43xx clock data
ARM: dts: AM35xx: use DT clock data
This patch creates a unique node for each clock in the OMAP4 power,
reset and clock manager (PRCM). OMAP443x and OMAP446x have slightly
different clock tree which is taken into account in the data.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
Signed-off-by: Mike Turquette <mturquette@linaro.org>
Small fix on representation. Bandgap node belongs to OCP.
Cc: "Benoît Cousson" <bcousson@baylibre.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: linux-omap@vger.kernel.org
Cc: devicetree@vger.kernel.org
Suggested-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Eduardo Valentin <eduardo.valentin@ti.com>
OMAP4430 devices can reach high temperatures and thus
needs to have cpufreq-cooling on systems running on it.
This patch adds the required cooling device properties
so that cpufreq-cpu0 driver loads the cooling device.
Cc: devicetree-discuss@lists.ozlabs.org
This patch changes the dtsi entry on omap4430 to contain
the thermal data. This data will enable the passive
cooling with CPUfreq cooling device at 100C and the
system will do a thermal shutdown at 125C.
Add the bandgap entry for OMAP4430 devices.
[benoit.cousson@linaro.org: Add blank line and fix reg presentation]
Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
Replace /include/ by #include for OMAP2+ DT, in order to use the
C pre-processor, making use of #define features possible.
Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Add DT OPP table for OMAP443x family of devices. This data is
decoded by OF with of_init_opp_table() helper function.
OPP data here is based on existing opp4xxx_data.c
Since the omap4460 OPP tables would be different from OMAP443x,
introduce an new omap443x.dtsi for 443x specific entries and use
existing omap4.dtsi as the common dtsi file for all OMAP4 platforms.
This is in preparation to use generic cpufreq-cpu0 driver for device
tree enabled boot. Legacy non device tree enabled boot continues to
use omap-cpufreq.c and opp4xxx_data.c.
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Jon Hunter <jon-hunter@ti.com>
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Shawn Guo <shawn.guo@linaro.org>
Cc: Keerthy <j-keerthy@ti.com>
