Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Devices using an external encoder, ESD protection and level shifter
such as tpd12s015 or ip4791cz12 have the CEC pull in the encoder
chip. And on var-som-om44, there is external pull up resistor R30.
So the internal CEC pull-up resistor needs to be disabled as otherwise
the external and internal pull are parallel making the pull value
much smaller than intended. This leads into the CEC not working as
reported by Hans Verkuil <hverkuil@xs4all.nl>.
Reported-by: Hans Verkuil <hverkuil@xs4all.nl>
Cc: Dmitry Lifshitz <lifshitz@compulab.co.il>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
The at24 driver allows to register I2C EEPROM chips using different vendor
and devices, but the I2C subsystem does not take the vendor into account
when matching using the I2C table since it only has device entries.
But when matching using an OF table, both the vendor and device has to be
taken into account so the driver defines only a set of compatible strings
using the "atmel" vendor as a generic fallback for compatible I2C devices.
So add this generic fallback to the device node compatible string to make
the device to match the driver using the OF device ID table.
Signed-off-by: Javier Martinez Canillas <javier@dowhile0.org>
Some omap5 variants have more than 2GB of memory available as
optional models. Let's update the dts files to use two address
cells similar to what dra7 is using with commit dae320ec3173
("ARM: dts: DRA7: change address-cells and size-cells").
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
This patch fixes the following DTC warnings for many boards:
"Node /leds/led@1 has a unit name, but no reg property"
This patch fixes the following DTC warnings for omap5-cm-t54.dtb:
"connector@0 has a unit name, but no reg property"
"encoder@0 has a unit name, but no reg property"
"endpoint@0 has a unit name, but no reg property"
"connector@1 has a unit name, but no reg property"
Pull ARM DT updates from Arnd Bergmann:
"These are all the updates to device tree files for 32-bit platforms,
which as usual makes up the bulk of the ARM SoC changes: 462 non-merge
changesets, 450 files changed, 23340 insertions, 5216 deletions.
The three platforms that are added with the "soc" branch are here as
well, and we add some related machine files:
- For Aspeed AST2400/AST2500, we get the evaluation platform and the
Tyan Palmetto POWER8 mainboard that uses the AST2400 BMC
- For Oxnas 810SE, the Western Digital "My Book World Edition" is
added as the only platform at the moment.
- For ARM MPS2, the AN385 (Cortex-M3) and AN399 (Cortex-M7) are
supported
On the ARM Realview development platform, we now support all machines
with device tree, previously only the board files were supported,
which in turn will likely be removed soon.
Qualcomm IPQ4019 is the second generation ARM based "Internet
Processor", following the IPQ806x that is used in many high-end WiFi
routers. This one integrates two ath10k wifi radios that were
previously on separate chips.
Other boards that got added for existing chips are:
Ti OMAP family:
- Amazon Kindle Fire, first generation, tablet and ebook reader
- OnRISC Baltos iR 2110 and 3220 embedded industrial PCs
- TI AM5728 IDK, TI AM3359 ICE-V2, and TI DRA722 Rev C EVM
development systems
Samsung EXYNOS platform:
- Samsung ARTIK5 evaluation board, see
https://www.artik.io/modules/overview/artik-5/
NXP i.MX platforms:
- Ka-Ro electronics TX6S-8034, TX6S-8035, TX6U-8033, TX6U-81xx,
TX6Q-1036, TX6Q-1110/-1130, TXUL-0010 and TXUL-0011 industrial
SoM modules
- Embest MarS Board i.MX6Dual DIY platform
- Boundary Devices i.MX6 Quad Plus Nitrogen6_MAX and SoloX
Nitrogen6sx embedded boards
- Technexion Pico i.MX6UL compute module
- ZII VF610 Development Board
Marvell embedded (mvebu, orion, kirkwood) platforms:
- Linksys Viper (E4200v2 / EA4500) WiFi router
- Buffalo Kurobox Pro NAS
Qualcomm Snapdragon:
- Arrow DragonBoard 600c (96boards) with APQ8064 Snapdragon 600
Rockchips platform:
- mqmaker MiQi single-board computer
Altera SoCFPGA:
- samtec VIN|ING 1000 vehicle communication interface
Allwinner Sunxi platforms:
- Dserve DSRV9703C tablet
- Difrnce DIT4350 tablet
- Colorfly E708 Q1 tablet
- Polaroid MID2809PXE04 tablet
- Olimex A20 OLinuXino LIME2 single board computer
- Xunlong Orange Pi 2, Orange Pi One, and Orange Pi PC single board
computers
Across many platforms, bug fixes went in to address warnings that dtc
now emits with 'make dtbs W=1'. Further changes for device enablement
went into Ti OMAP, bcm283x (Raspberry Pi), bcm47xx (wifi router), Ti
Davinci, Samsung EXYNOS, Marvell mvebu/kirkwood/orion, NXP i.MX/Vybrid
NXP LPC18xx, NXP LPC32xx, Renesas shmobile/r-mobile/r-car, Rockchips
rk3xxx, ST Ux500, ST STi, Atmel AT91/SAMA5, Altera SoCFPGA, Allwinner
Sunxi, Sigma Designs Tango, NVIDIA Tegra, Socionext Uniphier and ARM
Versatile Express"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (458 commits)
ARM: dts: tango4: Import watchdog node
ARM: dts: tango4: Update cpus node for cpufreq
ARM: dts: tango4: Update DT to match clk driver
ARM: dts: tango4: Initial thermal support
arm/dst: Add Aspeed ast2500 device tree
arm/dts: Add Aspeed ast2400 device tree
ARM: sun7i: dt: Add pll3 and pll7 clocks
ARM: dts: sunxi: Add a olinuxino-lime2-emmc
ARM: dts: at91: sama5d4: add trng node
ARM: dts: at91: sama5d3: add trng node
ARM: dts: at91: sama5d2: add trng node
ARM: dts: at91: at91sam9g45 family: reduce the trng register map size
ARM: sun4i: dt: Add pll3 and pll7 clocks
ARM: sun5i: chip: Enable the TV Encoder
ARM: sun5i: r8: Add display blocks to the DTSI
ARM: sun5i: a13: Add display and TCON clocks
ARM: dts: ux500: configure the accelerometers open drain
ARM: mx5: dts: Enable USB OTG on M53EVK
ARM: dts: imx6ul-14x14-evk: Add audio support
ARM: dts: imx6qdl: Remove unneeded unit-addresses
ldo4_reg is connected to DSS, and should always be 1.8V. However the The
dts defines a range of 1.5V-1.8V, which requires somethings to set the
actual voltage at runtime. Currently we set the voltage in omapdss
driver.
As the voltage must always be 1.8V, let's just define the range to 1.8V
so that the driver doesn't need to deal with the voltage. In fact, the
driver should not touch the voltage, except in the cases where the
voltage needs to be changed at runtime.
I presume the situation is the same for ldo1_reg, used for CSI, although
I think it is not currently used in the mainline.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Though the keyboard and other driver will continue to support the legacy
"gpio-key,wakeup", "linux,wakeup" boolean property to enable the wakeup
source, "wakeup-source" is the new standard binding.
This patch replaces all the legacy wakeup properties with the unified
"wakeup-source" property in order to avoid any futher copy-paste
duplication.
Cc: "Benoît Cousson" <bcousson@baylibre.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: linux-omap@vger.kernel.org
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Use the pinmux IOPAD macros to define the register as an offset from
the padconf physical address instead of the offset from padconf base.
This makes the DTS easier to read since matches the addresses listed
in the Technical Reference Manual.
Many OMAP2+ DTS are not using the defined constants to express
the GPIO polarity. Replace these so the DTS are easier to read.
OMAP4/5 has been (ab)using the gic_arch_extn to provide
wakeup from suspend, and it makes a lot of sense to convert
this code to use stacked domains instead.
This patch does just this, updating the DT files to actually
reflect what the HW provides.
BIG FAT WARNING: because the DTs were so far lying by not
exposing the WUGEN HW block, kernels with this patch applied
won't have any suspend-resume facility when booted with old DTs,
and old kernels with updated DTs won't even boot.
On a platform with this patch applied, the system looks like
this:
root@bacon-fat:~# cat /proc/interrupts
CPU0 CPU1
16: 0 0 WUGEN 37 gp_timer
19: 233799 155916 GIC 27 arch_timer
23: 0 0 WUGEN 9 l3-dbg-irq
24: 1 0 WUGEN 10 l3-app-irq
27: 282 0 WUGEN 13 omap-dma-engine
44: 0 0 4ae10000.gpio 13 DMA
294: 0 0 WUGEN 20 gpmc
297: 506 0 WUGEN 56 48070000.i2c
298: 0 0 WUGEN 57 48072000.i2c
299: 0 0 WUGEN 61 48060000.i2c
300: 0 0 WUGEN 62 4807a000.i2c
301: 8 0 WUGEN 60 4807c000.i2c
308: 2439 0 WUGEN 74 OMAP UART2
312: 362 0 WUGEN 83 mmc2
313: 502 0 WUGEN 86 mmc0
314: 13 0 WUGEN 94 mmc1
350: 0 0 PRCM pinctrl, pinctrl
406: 35155709 0 GIC 109 ehci_hcd:usb1
407: 0 0 WUGEN 7 palmas
409: 0 0 WUGEN 119 twl6040
410: 0 0 twl6040 5 twl6040_irq_ready
411: 0 0 twl6040 0 twl6040_irq_th
IPI0: 0 1 CPU wakeup interrupts
IPI1: 0 0 Timer broadcast interrupts
IPI2: 95334 902334 Rescheduling interrupts
IPI3: 0 0 Function call interrupts
IPI4: 479 648 Single function call interrupts
IPI5: 0 0 CPU stop interrupts
IPI6: 0 0 IRQ work interrupts
IPI7: 0 0 completion interrupts
Err: 0
Link: https://lkml.kernel.org/r/1426088629-15377-8-git-send-email-marc.zyngier@arm.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
Pull ARM SoC DT updates from Arnd Bergmann:
"As usual, this is the largest branch, though this time a little under
half of the total changes with 307 individual non-merge changesets.
The largest changes are the addition of new machines, in particular
the Tegra based Chromebook, the Renesas r8a7794 SoC, and DT support
for the old i.MX1 platform.
Other changes include
- at91: various sam9 and sama5 updates
- exynos: much extended Peach Pi/Pit (Chromebook 2) support
- keystone: new peripherals
- meson: added DT for meson6 SoC
- mvebu: new device support for Armada 370/375
- qcom: improved support for IPQ8064 and MSM8x60
- rockchip: much improved support for rk3288
- shmobile: lots of updates all over the place
- sunxi: dts license change
- sunxi: more a23 device support
- vexpress: CLCD DT description"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (308 commits)
ARM: DTS: meson: update DTSI to add watchdog node
ARM: dts: keystone-k2l: fix mdio io start address
ARM: dts: keystone-k2e: fix mdio io start address
ARM: dts: keystone-k2e: update usb1 node for dma properties
ARM: dts: keystone: fix io range for usb_phy0
Revert "Merge tag 'hix5hd2-dt-for-3.18' of git://github.com/hisilicon/linux-hisi into next/dt"
Revert "ARM: dts: hix5hd2: add wdg node"
ARM: dts: add rk3288 i2s controller
ARM: vexpress: Add CLCD Device Tree properties
ARM: bcm2835: add I2S pinctrl to device tree
ARM: meson: documentation: add bindings documentation
ARM: meson: dts: add basic Meson/Meson6/Meson6-atv1200 DTSI/DTS
ARM: dts: mt6589: Change compatible string for GIC
ARM: dts: mediatek: Add compatible property for aquaris5
ARM: dts: mt6589-aquaris5: Add boot argument earlyprintk
ARM: dts: mt6589: Fix typo in GIC unit address
ARM: dts: Build dtb for Mediatek board
ARM: dts: keystone: fix bindings for pcie and usb clock nodes
ARM: dts: keystone: k2l: Fix chip selects for SPI devices
ARM: dts: keystone: add dsp gpio controllers nodes
Add "extcon" and "vbus-supply" properties of DWC3 node.
Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
Add ADS7846 touchscreen support.
Add DT support for Startek KD050C LCD 800x480 panel.
Add DSS related pinmux and display data nodes required to support HDMI
and DVI video out on CM-T54.
Follow the comment style of mode0_name.modeX_name for pins
which mux mode differs from MUX_MODE0.
LDO8 regulator is used for act led and serial cosole power supply.
Its DT status is declared as "disabled", however the serial console was
functional until Commit 318dbb02b ("regulator: palmas: Fix SMPS
enable/disable/is_enabled") wich properly turns off LDO8 on boot.
Fix serial cosole power supply (and act led) on boot by turning LDO8 on.
Fixes: 318dbb02b ("regulator: palmas: Fix SMPS enable/disable/is_enabled")
Tested-by: Paul Walmsley <paul@pwsan.com>
The OMAP4/5 TRMs primarily list address offsets from the padconf
physical address (which is not driver base address) and not
always the absolute physical address for padconf registers like
some other OMAP TRMs. So create a new macro to use this offset
and to avoid confusion between different OMAP parts.
For more information, see the tables in TRM for named something like
"Device Core Control Module Pad Configuration Register Fields"
and "Device Wake-Up Control Module Pad Configuration Register Fields"
Note that we now also have to update cm-t54 for the fixed up
offsets.
Signed-off-by: Joachim Eastwood <manabian@gmail.com>
[tony@atomide.com: updated comments, updated cm-t54]
Add support of AW-NH387 (mwifiex) WiFi/BT chip connected to MMC3.
Add support for CM-T54 CoM and SBC-T54 board:
http://compulab.co.il/products/computer-on-modules/cm-t54/
http://compulab.co.il/products/sbcs/sbc-t54/
SBC-T54 is a single board computer based on OMAP5432 CPU.
It is implemented with a CM-T54 CoM providing most of the functions,
and SB-T54 carrier board providing connectors and several additional
functions.
Added basic support for:
* PMIC
* LED
* MMC/SD
* eMMC
* USB
* I2C1/4
* SB-T54 and CM-T54 EEPROMs
* RTC
[tony@atomide.com: updated for Makefile sorting]
