2015-03-06 | ARM: dts: OMAP5: fix polling intervals for thermal zones | Tero Kristo | |
OMAP4 has a finer counter granularity, which allows for a delay of 1000ms in the thermal zone polling intervals. OMAP5 has a different counter mechanism, which allows at maximum a 500ms timer. Adjust the cpu thermal zone polling interval accordingly. Without this patch, the polling interval information is simply ignored, and the following thermal warnings are printed during boot (assuming thermal is enabled); [ 1.545343] ti-soc-thermal 4a0021e0.bandgap: Delay 1000 ms is not supported [ 1.552691] ti-soc-thermal 4a0021e0.bandgap: Delay 1000 ms is not supported [ 1.560029] ti-soc-thermal 4a0021e0.bandgap: Delay 1000 ms is not supported Signed-off-by: Tero Kristo <t-kristo@ti.com> Cc: Tony Lindgren <tony@atomide.com> Acked-by: Eduardo Valentin <edubezval@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> | |||
2013-12-04 | arm: dts: add omap5 GPU thermal data | Eduardo Valentin | |
This patch changes a dtsi file to contain the thermal data for GPU domain on OMAP5 and later SoCs. This data will enable a thermal shutdown at 125C. This thermal data can be reused across TI SoC devices. Cc: "BenoƮt Cousson" <bcousson@baylibre.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: linux-omap@vger.kernel.org Cc: devicetree@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Eduardo Valentin <eduardo.valentin@ti.com> |
