And here's another nitpick ;-)
Cc: Agustí Fontquerni i Gorchs <afontquerni@iseebcn.com>
Cc: Enric Balletbo Serra <eballetbo@gmail.com>
Cc: Javier Martinez Canillas <javier@osg.samsung.com>
Cc: Pau Pajuel <ppajuel@gmail.com>
Fixes: b118c6a6ffa1 ("ARM: dts: Add power button support for igepv5")
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
It should be GPIO_ACTIVE_LOW instead of GPIO_ACTIVE_HIGH as
pointed out by Pau Pajuel <ppajuel@gmail.com>.
Some omap5 variants have more than 2GB of memory available as
optional models. Let's update the dts files to use two address
cells similar to what dra7 is using with commit dae320ec3173
("ARM: dts: DRA7: change address-cells and size-cells").
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
The LEDs on igepv5 are on the GPIO expander unlike on omap5-uevm.
Configuration copied from git.isee.biz git tree except fixed for
red and blue mapping.
Add power button support for igepv5.
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Fix ldo7 source for HDMI on igepv5.
Suggested-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Playing audio works on omap5-uevm, but produces an "Unhandled fault:
imprecise external abort (0x1406) at 0x00000000" error on igepv5.
Looks like the twl6040 audpwron GPIO pin is different for these
boards. Let's fix the issue by configuring the audpwron in the
board specific dts file.
Cc: Agustí Fontquerni <af@iseebcn.com>
Cc: Eduard Gavin <egavin@iseebcn.com>
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Acked-by: Peter Ujfalusi <peter.ujflausi@ti com>
With omap5-board-common.dtsi, we can now easily add support for various omap5
board variants. Let's add minimal support for isee igepv5.
So far I've tested that basic things work, such as serial, USB Ethernet, HDMI
and WLAN.
Note that like omap5-uevm, these boards seem to need to reserve 16MB for a
trap section as in commit 03178c66d289 ("ARM: dts: omap5-evm: Update
available memory to 2032 MB") and also noted in a u-boot commit at
http://marc.info/?l=u-boot&m=134376852603255 and also at
http://patchwork.ozlabs.org/patch/159881/.
Not sure why this is not needed for omap5-cm-t54.dts, maybe because of
different u-boot configuration.
