Follow the comment style of mode0_name.modeX_name for pins
which mux mode differs from MUX_MODE0.
Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
CM-T54 CoM can be used with various custom baseboards, other
than SB-T54 (supplied with SBC-T54 single board computer).
Update model property of SBC-T54 DT to clarify this.
The OMAP4/5 TRMs primarily list address offsets from the padconf
physical address (which is not driver base address) and not
always the absolute physical address for padconf registers like
some other OMAP TRMs. So create a new macro to use this offset
and to avoid confusion between different OMAP parts.
For more information, see the tables in TRM for named something like
"Device Core Control Module Pad Configuration Register Fields"
and "Device Wake-Up Control Module Pad Configuration Register Fields"
Note that we now also have to update cm-t54 for the fixed up
offsets.
Signed-off-by: Joachim Eastwood <manabian@gmail.com>
[tony@atomide.com: updated comments, updated cm-t54]
Add support for CM-T54 CoM and SBC-T54 board:
http://compulab.co.il/products/computer-on-modules/cm-t54/
http://compulab.co.il/products/sbcs/sbc-t54/
SBC-T54 is a single board computer based on OMAP5432 CPU.
It is implemented with a CM-T54 CoM providing most of the functions,
and SB-T54 carrier board providing connectors and several additional
functions.
Added basic support for:
* PMIC
* LED
* MMC/SD
* eMMC
* USB
* I2C1/4
* SB-T54 and CM-T54 EEPROMs
* RTC
[tony@atomide.com: updated for Makefile sorting]
