If we have Linux installed in eMMC we can boot without
µSD card, but inserting one is not recognised.
The reason is that the card detect gpio (gpio5_152)
is not configured and attached to the mmc1 interface
driver and the mmc driver does not poll by default.
Hence we add pinmux and gpio setup for the SDCARD_NCD
signal.
Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com>
Note that with 9730 the wiring is different compared to 9514 found on
beagleboard xm for example.
On beagleboard xm we have:
/sys/bus/usb/devices/1-2 hub
/sys/bus/usb/devices/1-2.1 9514
While on omap5-uevm we have:
/sys/bus/usb/devices/1-3 9730
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Though the keyboard driver for GPIO buttons(gpio-keys) will continue to
check for/support the legacy "gpio-key,wakeup" boolean property to
enable gpio buttons as wakeup source, "wakeup-source" is the new
standard binding.
This patch replaces the legacy "gpio-key,wakeup" with the unified
"wakeup-source" property in order to avoid any further copy-paste
duplication.
Cc: "Benoît Cousson" <bcousson@baylibre.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Add USR1 button.
Add LEDs.
Add EEPROM.
Some omap5 variants have more than 2GB of memory available as
optional models. Let's update the dts files to use two address
cells similar to what dra7 is using with commit dae320ec3173
("ARM: dts: DRA7: change address-cells and size-cells").
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
The LEDs on igepv5 are on the GPIO expander unlike on omap5-uevm.
Configuration copied from git.isee.biz git tree except fixed for
red and blue mapping.
Few changes to fix issues I've noticed while debugging omap5-uevm
wl18xx issues:
1. Move wlcore irq pin muxing under wlcore. This irq could be
different from gpio_wk14 on some board variants
2. Don't configure pull on wlcore irq pin. There is a 10k
pull up resistor R105 on the device to VDDS_1v8_MAIN
3. The padconf register for wlsdio_data1 is wrong, it's really
at 0x1a8 + 2 - 0x40 = 0x16a offset, not at 0x168 as that's
for wlsdio_data0
4. Mark the omap5-uevm wlan as compatible with ti,wl1837 as
that's what the TDK R078 part seems to be
5. The MMC interrupt for WLAN musb be wakeupgen, not gic
Looks like omap5-uevm WLAN behaves better now, but I still seem
to have issues with some access points.
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Playing audio works on omap5-uevm, but produces an "Unhandled fault:
imprecise external abort (0x1406) at 0x00000000" error on igepv5.
Looks like the twl6040 audpwron GPIO pin is different for these
boards. Let's fix the issue by configuring the audpwron in the
board specific dts file.
Cc: Agustí Fontquerni <af@iseebcn.com>
Cc: Eduard Gavin <egavin@iseebcn.com>
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Acked-by: Peter Ujfalusi <peter.ujflausi@ti com>
Use the pinmux IOPAD macros to define the register as an offset from
the padconf physical address instead of the offset from padconf base.
This makes the DTS easier to read since matches the addresses listed
in the Technical Reference Manual.
Looks like thevarious omap5-uevm models and igepv5 are very similar. So let's
create omap5-board-common.dtsi to allow fixing up things properly for mainline
kernel to support all these.
Even if we eventually end up having only PMIC + MMC + eMMC + SDIO WLAN + SATA +
USB + HDMI configuration in the omap5-board-common.dtsi, this is the easiest
way to add support for other boards rather than diffing various versions of
out of tree dts files.
My guess is that also omap5-sbc-t54.dts can use this, but I don't have that
board so that will need to be dealt with later on.
Commit 99f84cae43df ("ARM: dts: add wl12xx/wl18xx bindings") added
device tree bindings for the TI WLAN SDIO on many omap variants.
I recall wondering how come omap5-uevm did not have the WLAN
added and this issue has been bugging me for a while now, and
I finally tracked it down to a bad pinmux regression, and a missing
deferred probe handling for the 32k clock from palmas that's
requested by twl6040.
Basically 392adaf796b9 ("ARM: dts: omap5-evm: Add mcspi data")
added pin muxing for mcspi4 that conflicts with the onboard
WLAN. While some omap5-uevm don't have WLAN populated, the
pins are not reused for other devices. And as the SDIO bus
should be probed, let's try to enable WLAN by default.
Let's fix the regression and add the WLAN configuration as
done for the other boards in 99f84cae43df ("ARM: dts: add
wl12xx/wl18xx bindings"). And let's use the new MMC pwrseq for
the 32k clock as suggested by Javier Martinez Canillas
<javier@dowhile0.org>.
Note that without a related deferred probe fix for twl6040,
the 32k clock is not initialized if palmas-clk is a module
and twl6040 is built-in.
Let's also use the generic "non-removable" instead of the
legacy "ti,non-removable" property while at it.
And finally, note that omap5 seems to require WAKEUP_EN for
the WLAN GPIO interrupt.
Fixes: 392adaf796b9 ("ARM: dts: omap5-evm: Add mcspi data")
Cc: Sourav Poddar <sourav.poddar@ti.com>
Many OMAP2+ DTS are not using the defined constants to express
the GPIO polarity. Replace these so the DTS are easier to read.
The i2c5 pinctrl offsets are wrong. If the bootloader doesn't set the
pins up, communication with tca6424a doesn't work (controller timeouts)
and it is not possible to enable HDMI.
Fixes: 9be495c42609 ("ARM: dts: omap5-evm: Add I2c pinctrl data")
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Palmas on OMAP5uevm has support for power button, so enable it.
Signed-off-by: Aparna Balasubramanian <aparnab@ti.com>
Acked-by: Nishanth Menon <nm@ti.com>
UART3 wakeup takes place with iodaisy chain. enable the wakeup pin.
Reported-by: Suman Anna <s-anna@ti.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
[tony@atomide.com: tabify uart pins properly while at it]
OMAP4/5 has been (ab)using the gic_arch_extn to provide
wakeup from suspend, and it makes a lot of sense to convert
this code to use stacked domains instead.
This patch does just this, updating the DT files to actually
reflect what the HW provides.
BIG FAT WARNING: because the DTs were so far lying by not
exposing the WUGEN HW block, kernels with this patch applied
won't have any suspend-resume facility when booted with old DTs,
and old kernels with updated DTs won't even boot.
On a platform with this patch applied, the system looks like
this:
root@bacon-fat:~# cat /proc/interrupts
CPU0 CPU1
16: 0 0 WUGEN 37 gp_timer
19: 233799 155916 GIC 27 arch_timer
23: 0 0 WUGEN 9 l3-dbg-irq
24: 1 0 WUGEN 10 l3-app-irq
27: 282 0 WUGEN 13 omap-dma-engine
44: 0 0 4ae10000.gpio 13 DMA
294: 0 0 WUGEN 20 gpmc
297: 506 0 WUGEN 56 48070000.i2c
298: 0 0 WUGEN 57 48072000.i2c
299: 0 0 WUGEN 61 48060000.i2c
300: 0 0 WUGEN 62 4807a000.i2c
301: 8 0 WUGEN 60 4807c000.i2c
308: 2439 0 WUGEN 74 OMAP UART2
312: 362 0 WUGEN 83 mmc2
313: 502 0 WUGEN 86 mmc0
314: 13 0 WUGEN 94 mmc1
350: 0 0 PRCM pinctrl, pinctrl
406: 35155709 0 GIC 109 ehci_hcd:usb1
407: 0 0 WUGEN 7 palmas
409: 0 0 WUGEN 119 twl6040
410: 0 0 twl6040 5 twl6040_irq_ready
411: 0 0 twl6040 0 twl6040_irq_th
IPI0: 0 1 CPU wakeup interrupts
IPI1: 0 0 Timer broadcast interrupts
IPI2: 95334 902334 Rescheduling interrupts
IPI3: 0 0 Function call interrupts
IPI4: 479 648 Single function call interrupts
IPI5: 0 0 CPU stop interrupts
IPI6: 0 0 IRQ work interrupts
IPI7: 0 0 completion interrupts
Err: 0
Link: https://lkml.kernel.org/r/1426088629-15377-8-git-send-email-marc.zyngier@arm.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
The board uses twl6040 codec connected via McPDM link. McBSP1 and McBSP2 can
be used for FM/BT.
At the same time move the pinctrl handling to the correct place - under the
corresponding nodes.
Audio connectors on the board:
Headset in/out
Stereo Line out
Stereo Line in.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
The board uses twl6040 as audio codec. Move the corresponding pinctrl as
well under the node.
twl6040 needs 32k clock from palams.
clk32kg-audio clock is needed for twl6040 codec.
omap5-uevm has a single HDMI output. Add the necessary display
information, including pinmuxing.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
omap5-uevm has a tca6424a I/O expander. Add it to the .dts file.
The necessary clock phandle for the EHCI clock is now provided
via device tree so we no longer need this legacy method.
Update the omap4-panda and omap5-uevm board DTS to provide the
necessary EHCI PHY clock information.
Signed-off-by: Roger Quadros <rogerq@ti.com>
When the omap5-evm.dts file has been renamed to omap5-uevm.dts and the sEVM
support got deprecated in favor of uEVM (or Panda5) the content was not
validated.
Panda5 does not have support for digital microphones so remove the pinmux
section for it.
Signed-off-by: Benoit Cousson <bcousson@baylibre.com>
validated.
On uEVM the twl6040 reset GPIO is from gpio5_141 and not via gpio5_145, which
was the case in sEVM.
regulator smps123 supply from Palmas PMIC powers CPU0 on OMAP5uEVM.
Based on a patch by J Keerthy <j-keerthy@ti.com>
Correct mcspi pin descriptions to match corresponding node name and
add chip select number to be consistent with OMAP5 TRM.
Signed-off-by: Eric Witcher <ewitcher@mindspring.com>
smps10 should be enabled only in the case of host mode. So stop
doing always_on, boot_on from smps10_out1. The driver will enable
it in host mode.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
This allows the palmas pm_power_off to kick in on power off command
and switch off the board.
We no longer need to model the RESET line as a regulator since
the USB phy-nop driver accepts "reset-gpios" property.
Without this node, there will be no palmas driver to notify
dwc3 that a cable has been connected and, without that, dwc3
will never initialize.
Signed-off-by: Felipe Balbi <balbi@ti.com>
[kishon@ti.com: added dt properties for enabling vbus/id interrupts
and fixed vbus-supply value after SMPS10 is modeled as 2 regulators]
SMPS10 has two outputs OUT1 and OUT2. Hence SMPS10 is modeled as
two regulators. The DT node is split to reflect it.
commit e00c27ef3b4c23e39d0a77b7c8e5be44c28001c7
(ARM: dts: OMAP5: Add Palmas MFD node and regulator nodes)
introduced regulator entries for OMAP5uEVM.
However, The regulator information is based on an older temporary
pre-production board variant and does not reflect production board
750-2628-XXX boards.
The following optional/unused regulators can be updated:
- SMPS9 supplies TWL6040 over VDDA_2v1_AUD. This regulator needs to be
enabled only when audio is active. Since it does not come active by
default, it does not require "always-on" or "boot-on".
- LDO2 and LDO8 do not go to any peripheral or connector on the board.
Further, these unused regulators should have been 2.8V for LDO2 and
3.0V for LDO8. Mark these LDOs as disabled in the dts until needed.
Reported-by: Marc Jüttner <m-juettner@ti.com>
Acked-by: J Keerthy <j-keerthy@ti.com>
Acked-by: Benoit Cousson <benoit.cousson@gmail.com>
The following fixes are hence mandatory to ensure right voltage is
supplied to key OMAP5 SoC voltage rails:
- LDO1 supplies VDDAPHY_CAM which is OMAP5's vdda_csiporta/b/c. This
can only be supplied at 1.5V or 1.8V and we currently supply 2.8V.
To prevent any potential device damage risk, use the specified
1.5V-1.8V supply.
Remove 'always-on' and 'boot-on' settings here as it is
a 'on need' supply to SoC IP and is not enabled by PMIC by
default at boot.
- LDO3 supplies Low Latency Interface(LLI) hardware module which is a
special hardware to communicate with Modem. However since uEVM is
not setup by default for this communication, this should be disabled
by default.
Further, vdda_lli is supposed to be 1.5V and not 3V.
- LDO4 supplies VDDAPHY_DISP which is vdda_dsiporta/c/vdda_hdmi
This can only be supplied at 1.5V or 1.8V and we currently
supply 2.2V.
1.5V-1.8V supply.
Remove 'always-on' and 'boot-on' settings here as it is a 'on need'
supply to SoC IP and is not enabled by PMIC by default at boot.
- LDO6 supplies the board specified VDDS_1V2_WKUP supply going to
ldo_emu_wkup/vdds_hsic. To stay within the SoC specification supply
1.2V instead of 1.5V.
- LDO7 supplies VDD_VPP which is vpp1. This is currently configured for
1.5V which as per data manual "A pulse width of 1000 ns and an amplitude
of 2V is required to program each eFuse bit. Otherwise, VPP1 must not
be supplied".
So, fix the voltage to 2V. and disable the supply since we have no plans
of programming efuse bits - it can only be done once - in factory.
Further it is not enabled by default by PMIC so, 'boot-on' must be
removed, and the 'always-on' needs to be removed to achieve pulsing
if efuse needs to be programmed.
- LDO9 supplies the board specified vdds_sdcard supply going within SoC
specification of 1.8V or 3.0V. Further the supply is controlled by
switch enabled by REGEN3. So, introduce REGEN3 and map sdcard slot to
be powered by LDO9. Remove 'always-on' allowing the LDO to be disabled
on need basis.
However, currently we use the Palmas regulator names which is used for
different purposes on uEVM. Document the same based on 750-2628-XXX
boards - which is meant to be supported by this dts.
USB Host PHY clock on port 2 must be configured to 19.2MHz.
Provide this information.
Cc: Sricharan R <r.sricharan@ti.com>
Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
Add Palmas MFD node and the regulator nodes for OMAP5.
The node definitions are based on: https://lkml.org/lkml/2013/6/6/25
Boot tested on omap5-uevm board.
Signed-off-by: Graeme Gregory <gg@slimlogic.co.uk>
Signed-off-by: J Keerthy <j-keerthy@ti.com>
Booting omap5 uevm results in the following error
"did not get pins for uart error: -19"
This happens because omap5 uevm dts file is not adapted
to use uart through pinctrl framework.
Populate uart pinctrl data to get rid of the error.
Signed-off-by: Sourav Poddar <sourav.poddar@ti.com>
[r.sricharan@ti.com: Replaced constants with preprocessor macros]
Signed-off-by: Sricharan R <r.sricharan@ti.com>
Add support for blue LED 1 off of GPIO 153.
Make the LED a heartbeat LED
Configure the MUX for GPIO output.
Signed-off-by: Dan Murphy <dmurphy@ti.com>
Provide the RESET regulators for the USB PHYs, the USB Host
port modes and the PHY devices.
Also provide pin multiplexer information for the USB host
pins.
The uevm is the only official board supported for the OMAP5 soc
in mainline. The existent sevm platform will no more be supported.
Hence cleaning up the board dts file to have only the data
required for uevm.
Renaming the board dts file and adding the following cleanups.
* There are no devices connected on I2C 2,3,4 buses. So remove
the pinmux data for the same.
* OMAP5432 and DDR3 memory is used in the uevm. Temperature polling
is not supported with DDR3 memories. Because of DDR3 phy limitation
the voltage change across DVFS and all shadow registers for DVFS on
DDR3 is not supported. Hence the emif kernel driver is not required,
so removing the DDR3 device file and emif nodes for uevm.
* Keypad is not supported on uevm. So remove the device node.
