Currently the slope and offset values for calculating the
hot spot temperature of a particular thermal zone is part
of driver data. Pass them here instead and obtain the values
while of node parsing.
Signed-off-by: Keerthy <j-keerthy@ti.com>
Pull ARM DT updates from Arnd Bergmann:
"A total of 380 patches this time, mostly adding support for more
hardware in the device tree descriptions. There is not much exciting
here for 4.11, but I've tried my best to condense the information from
the pull requests I got into a readable summary.
Noteworthy changes to existing platforms include:
- The GIC memory map was a bit wrong almost everywhere and now gets
fixed up
- The Allwinner platforms convert to the generic pinmux properties
- The Marvell EBU platforms now use the new DSA binding
- Samsung Exynos4212 was unused and gets removed
- The Renesas power management got improved
New production machines:
- Lego Mindstorms EV3:
https://www.lego.com/en-us/mindstorms/about-ev3
- Beelink X2 Android media box:
http://linux-sunxi.org/Beelink_X2
- "Romulus" baseboard management controller for OpenPower
- Axentia TSE-850 Data Radio Channel (DARC) encoder:
http://www.axentia.se/db/equipment.html
- Luxul XAP-1410 and XWR-1200 wireless access points:
https://luxul.com/xap-1410
New SoCs:
- Allwinner H2+ and V3s, both minor variations of already supported
chips:
http://www.allwinnertech.com/index.php?c=product&a=index&id=38
- Marvell Prestera DX packet processors based on Armada XP
architecture:
http://www.marvell.com/switching/prestera-dx/
- Samsung Exynos4412 Prime gets added, a minor variation of
Exynos4412
New developer and reference boards:
- Lichee Pi One, Lichee Pi Zero and Orange Pi Zero, all based on
Allwinner SoCs:
http://linux-sunxi.org/LicheePi_One
http://www.orangepi.org/orangepizero/
- SAMA5d36ek Reference platform:
http://www.atmel.com/tools/sama5d36-ek.aspx
- Beaglebone Green Wireless and Black Wireless:
https://beagleboard.org/black-wireless
https://beagleboard.org/green-wireless
- phyCORE-AM335x System on Module:
http://phytec.com/products/system-on-modules/phycore/am335x/
- New revision of "vf610-zii" Zodiac Inflight Innovations board
- Various i.MX System-on-Module: Is.IoT MX6UL, SavageBoard, Engicam
i.Core:
http://www.opossom.com/english/index.html
http://www.savageboard.org/
http://www.engicam.com/en/products/embedded/som/sodimm/is-iot-mx6ul
http://www.engicam.com/en/products/embedded/som/sodimm/i-core-m6s-dl-d-q
- Liebherr (LWN) monitor 6 based on i.MX6 Quad, no idea what this is
- Cleanups and bugfixes on at91, bcm53xx, i.MX, mvebu, omap, oxnas,
qcom, rockchip, sti, stm32 and tegra
New device supports added to some boards and SoCs, briefly by platform:
- Allwinner: SPDIF, A33 cpufreq, A33 Mali GPU
- Aspeed: network, ipmi bt, gpio, pinmux
- Broadcom: video encoder for raspberry pi, qspi, ethernet, sd/mmc
- TI DaVinci: gpio, lcdc, usb, video-in, uart
- TI Keystone 2: MSM RAM, power/reset, uart
- Mediatek MT2701: clocks, iommu, spi, nand, adc, thermal
- Marvell EBU: ethernet switch on Turris Omnia
- NXP i.MX: otp ram, USB, wifi, bluetooth, spdif, spi, pmic, eeprom,
mmc, nand
- TI OMAP:
- Qualcomm: coresight, gyro/accelerometer, hdmi
- Renesas: pmic, soc-id
- Rockchip: qos
- Samsung: audio on Odroid-X
- Socfpga: FPGA manager, i2c, led, can, watchdog, nand, power monitor
- STi: video in/out
- STM32: timer, pwm, i2c, rtc, add, i2s
- NVIDIA Tegra: tpm
- Uniphier: mmc/sd pinmux"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (380 commits)
ARM: dts: armada-385-linksys: fix DSA compatible property
ARM: dts: Fix typo in armada-xp-98dx4251
ARM: DTS: Fix register map for virt-capable GIC
dt-bindings: arm,gic: Fix binding example for a virt-capable GIC
ARM: dts: sun8i: sinlinx: Enable audio nodes
ARM: dts: sun8i: parrot: Enable audio nodes
ARM: dts: sun8i: Add audio codec, dai and card for A33
ARM: dts: Add EMAC AXI settings for Arria10
ARM: dts: am335x-chiliboard: Support charger
ARM: dts: am335x-chiliboard: Support power button
ARM: sun8i: dt: Add mali node
dt-bindings: gpu: Add Mali Utgard bindings
ARM: dts: stm32: Add I2C1 support for STM32429 eval board
ARM: dts: stm32: Add I2C1 support for STM32F429 SoC
ARM: dts: stm32: Use clock DT binding definition on stm32f429 family
dt-bindings: mfd: stm32f4: Add missing binding definition
dt-bindings: mfd: stm32f4: Fix STM32F4_X_CLOCK() macro
ARM: dts: stm32: Enable pwm1 and pwm3 for stm32f469-disco
ARM: dts: stm32: add Timers driver for stm32f429 MCU
ARM: dts: add the AB8500 sysclk to the device trees
Since everybody copied my own mistake from the DT binding example,
let's address all the offenders in one swift go.
Most of them got the CPU interface size wrong (4kB, while it should
be 8kB), except for both keystone platforms which got the control
interface wrong (4kB instead of 8kB).
In a few cases where I knew for sure what implementation was used,
I've added the "arm,gic-400" compatible string. I'm 99% sure that
this is what everyone is using, but short of having the TRM for
all the other SoCs, I've left them alone.
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com>
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
AHCI provides the register PORTS_IMPL to let the software know which port
is supported. The register must be initialized by the bootloader. However
in some cases u-boot doesn't properly initialize this value (if it is not
compiled with SATA support for example or if the SATA initialization fails).
The DTS entry "ports-implemented" can be used to override the value in
PORTS_IMPL.
Without this patch the SATA will not work in the following two cases:
* if there has been a failure to initialize SATA in u-boot.
* if ahci_platform module has been removed and re-inserted. The reason is
that the content of PORTS_IMPL is lost after the module is removed.
I suspect that it's because the controller is reset by the hwmod.
Cc: <stable@vger.kernel.org> # v4.6+
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Acked-by: Roger Quadros <rogerq@ti.com>
[tony@atomide.com: updated comments with what goes wrong]
Commit 76a8548ea987 ("ARM: dts: omap5: Remove skeleton.dtsi usage")
removed the skeleton.dtsi usage since we want to get rid of it.
But this can cause issues when booting a kernel with a boot-loader
that doesn't create a chosen node if this isn't present in the DTB
since the decompressor relies on a pre-existing chosen node to be
available to insert the command line and merge other ATAGS info.
Fixes: 76a8548ea987 ("ARM: dts: omap5: Remove skeleton.dtsi usage")
Reported-by: Pali Rohar <pali.rohar@gmail.com>
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Drivers using pinctrl-single,pins have #pinctrl-cells = <1>, while
pinctrl-single,bits need #pinctrl-cells = <2>.
Note that this patch can be optionally applied separately from the
driver changes as the driver supports also the legacy binding without
#pinctrl-cells.
Acked-by: Rob Herring <robh@kernel.org>
Some omap5 variants have more than 2GB of memory available as
optional models. Let's update the dts files to use two address
cells similar to what dra7 is using with commit dae320ec3173
("ARM: dts: DRA7: change address-cells and size-cells").
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
The ID pin GPIO comes from the PMIC. Let's configure it as a GPIO
for the driver to use, and also make sure the PMIC GPIO pin muxing
is correct. The PMIC pad1 and 2 values for omap5-uevm and igepv5 are
0x5a and 0x1b, we only need to clear bit 2 in pad1 register to make
the ID pin GPIO work.
The skeleton.dtsi file was removed in ARM64 for different reasons as
explained in commit ("3ebee5a2e141 arm64: dts: kill skeleton.dtsi").
These also applies to ARM and it will also allow to get rid of the
following DTC warnings in the future:
"Node /memory has a reg or ranges property, but no unit name"
The disassembled DTB are almost the same besides an empty chosen
node being removed and nodes reordered, so it should not have
functional changes.
"These are all the updates to device tree files for 32-bit platforms,
which as usual makes up the bulk of the ARM SoC changes: 462 non-merge
changesets, 450 files changed, 23340 insertions, 5216 deletions.
The three platforms that are added with the "soc" branch are here as
well, and we add some related machine files:
- For Aspeed AST2400/AST2500, we get the evaluation platform and the
Tyan Palmetto POWER8 mainboard that uses the AST2400 BMC
- For Oxnas 810SE, the Western Digital "My Book World Edition" is
added as the only platform at the moment.
- For ARM MPS2, the AN385 (Cortex-M3) and AN399 (Cortex-M7) are
supported
On the ARM Realview development platform, we now support all machines
with device tree, previously only the board files were supported,
which in turn will likely be removed soon.
Qualcomm IPQ4019 is the second generation ARM based "Internet
Processor", following the IPQ806x that is used in many high-end WiFi
routers. This one integrates two ath10k wifi radios that were
previously on separate chips.
Other boards that got added for existing chips are:
Ti OMAP family:
- Amazon Kindle Fire, first generation, tablet and ebook reader
- OnRISC Baltos iR 2110 and 3220 embedded industrial PCs
- TI AM5728 IDK, TI AM3359 ICE-V2, and TI DRA722 Rev C EVM
development systems
Samsung EXYNOS platform:
- Samsung ARTIK5 evaluation board, see
https://www.artik.io/modules/overview/artik-5/
NXP i.MX platforms:
- Ka-Ro electronics TX6S-8034, TX6S-8035, TX6U-8033, TX6U-81xx,
TX6Q-1036, TX6Q-1110/-1130, TXUL-0010 and TXUL-0011 industrial
SoM modules
- Embest MarS Board i.MX6Dual DIY platform
- Boundary Devices i.MX6 Quad Plus Nitrogen6_MAX and SoloX
Nitrogen6sx embedded boards
- Technexion Pico i.MX6UL compute module
- ZII VF610 Development Board
Marvell embedded (mvebu, orion, kirkwood) platforms:
- Linksys Viper (E4200v2 / EA4500) WiFi router
- Buffalo Kurobox Pro NAS
Qualcomm Snapdragon:
- Arrow DragonBoard 600c (96boards) with APQ8064 Snapdragon 600
Rockchips platform:
- mqmaker MiQi single-board computer
Altera SoCFPGA:
- samtec VIN|ING 1000 vehicle communication interface
Allwinner Sunxi platforms:
- Dserve DSRV9703C tablet
- Difrnce DIT4350 tablet
- Colorfly E708 Q1 tablet
- Polaroid MID2809PXE04 tablet
- Olimex A20 OLinuXino LIME2 single board computer
- Xunlong Orange Pi 2, Orange Pi One, and Orange Pi PC single board
computers
Across many platforms, bug fixes went in to address warnings that dtc
now emits with 'make dtbs W=1'. Further changes for device enablement
went into Ti OMAP, bcm283x (Raspberry Pi), bcm47xx (wifi router), Ti
Davinci, Samsung EXYNOS, Marvell mvebu/kirkwood/orion, NXP i.MX/Vybrid
NXP LPC18xx, NXP LPC32xx, Renesas shmobile/r-mobile/r-car, Rockchips
rk3xxx, ST Ux500, ST STi, Atmel AT91/SAMA5, Altera SoCFPGA, Allwinner
Sunxi, Sigma Designs Tango, NVIDIA Tegra, Socionext Uniphier and ARM
Versatile Express"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (458 commits)
ARM: dts: tango4: Import watchdog node
ARM: dts: tango4: Update cpus node for cpufreq
ARM: dts: tango4: Update DT to match clk driver
ARM: dts: tango4: Initial thermal support
arm/dst: Add Aspeed ast2500 device tree
arm/dts: Add Aspeed ast2400 device tree
ARM: sun7i: dt: Add pll3 and pll7 clocks
ARM: dts: sunxi: Add a olinuxino-lime2-emmc
ARM: dts: at91: sama5d4: add trng node
ARM: dts: at91: sama5d3: add trng node
ARM: dts: at91: sama5d2: add trng node
ARM: dts: at91: at91sam9g45 family: reduce the trng register map size
ARM: sun4i: dt: Add pll3 and pll7 clocks
ARM: sun5i: chip: Enable the TV Encoder
ARM: sun5i: r8: Add display blocks to the DTSI
ARM: sun5i: a13: Add display and TCON clocks
ARM: dts: ux500: configure the accelerometers open drain
ARM: mx5: dts: Enable USB OTG on M53EVK
ARM: dts: imx6ul-14x14-evk: Add audio support
ARM: dts: imx6qdl: Remove unneeded unit-addresses
otherwise we can't define gpio1_wk14
Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com>
GPMC driver provides interrupts and gpio for the GPMC_WAIT pins.
Mark it as gpio and interrupt capable.
Signed-off-by: Roger Quadros <rogerq@ti.com>
This patch fixes the following DTC warnings:
"pbias_regulator has a reg or ranges property, but no unit name"
DWC3's tx-fifo-resize property has been deprecated
because of it being unnecessary to any HW other than
OMAP5 ES1.0.
Signed-off-by: Felipe Balbi <balbi@kernel.org>
Add "syscon-phy-power" property and remove the deprecated "ctrl-module"
property from SATA and USB PHY node. Also remove the unused control
module dt nodes.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Add dma channel information to the gpmc. Although not enabled by
default this will allow prefetch-dma to be used.
Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
"ARM: dts: <omap2/omap4/omap5/dra7>: add minimal l4 bus
layout with control module support" moved pbias_regulator dt node
from being a child node of ocp to be the child node of
'syscon'. Since 'syscon' doesn't have the 'ranges' property,
address translation fails while trying to convert the address
to resource. Fix it here by populating 'ranges' property in
syscon dt node.
Fixes: 72b10ac00eb1 ("ARM: dts: omap24xx: add minimal l4 bus
layout with control module support")
Fixes: 7415b0b4c645 ("ARM: dts: omap4: add minimal l4 bus layout
Fixes: ed8509edddeb ("ARM: dts: omap5: add minimal l4 bus
Fixes: d919501feffa ("ARM: dts: dra7: add minimal l4 bus
[tony@atomide.com: fixed omap3 pbias to work]
Use platform specific compatible strings instead of the common
"ti,pbias-omap" compatible string.
Pull ARM DT updates from Olof Johansson:
"Ladies and gentlemen, we proudly announce to you the latest branch of
ARM device tree contents for the mainline kernel. Come and see, come
and see!
No less than twentythree thousand lines of additions! Just imagine the
joy you will have of using your mainline kernel on newly supported
hardware such as Rockchip Chromebooks, Freescale i.MX6UL boards or
UniPhier hardware!
For those of you feeling less adventurous, added hardware support on
platforms such as TI DM814x and Gumstix Overo platforms might be more
of your liking.
We've got something for everyone here!
Ahem. Cough. So, anyway...
This is the usual large batch of DT updates. Lots and lots of smaller
changes, some of the larger ones to point out are:
- Rockchip veyron (Chromebook) support, as well as several other new boards
- DRM support on Atmel AT91SAM9N12EK
- USB additions on some Allwinner platforms
- Mediatek MT6580 support
- Freescale i.MX6UL support
- cleanups for Renesas shmobile platforms
- lots of added devices on LPC18xx
- lots of added devices and boards on UniPhier
There's also some dependent code added here, in particular some
branches that are primarily merged through the clock tree"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (389 commits)
ARM: tegra: Add gpio-ranges property
ARM: tegra: Fix AHB base address on Tegra20, Tegra30 and Tegra114
ARM: tegra: Add Tegra124 PMU support
ARM: tegra: jetson-tk1: Add GK20A GPU DT node
ARM: tegra: venice2: Add GK20A GPU DT node
ARM: tegra: Add IOMMU node to GK20A
ARM: tegra: Add CPU regulator to the Jetson TK1 device tree
ARM: tegra: Add entries for cpufreq on Tegra124
ARM: tegra: Enable the DFLL on the Jetson TK1
ARM: tegra: Add the DFLL to Tegra124 device tree
ARM: dts: zynq: Add devicetree entry for Xilinx Zynq reset controller.
ARM: dts: UniPhier: fix PPI interrupt CPU mask of timer nodes
ARM: dts: rockchip: correct regulator power states for suspend
ARM: dts: rockchip: correct regulator PM properties
ARM: dts: vexpress: Use assigned-clock-parents for sp810
pinctrl: tegra: Only set the gpio range if needed
arm: boot: dts: am4372: add ARM timers and SCU nodes
ARM: dts: AM4372: Add the am4372-rtc compatible string
ARM: shmobile: r8a7794 dtsi: Add CPG/MSTP Clock Domain
ARM: shmobile: r8a7793 dtsi: Add CPG/MSTP Clock Domain
commit <ed8509edddeb> ("ARM: dts: omap5: add minimal l4 bus
layout with control module support") moved pbias_regulator dt node
omap5_padconf_global. After this device for pbias_regulator is
not created.
Fix it by adding "simple-bus" compatible property to
omap5_padconf_global dt node.
Cc: <stable@vger.kernel.org> # v4.1
Add interrupt names so that the same can be used for OTG easily.
Add missing #iommu-cells property to the DSP and IPU IOMMU nodes
for OMAP5 platforms. This property is required as per the generic
iommu binding.
Signed-off-by: Suman Anna <s-anna@ti.com>
The L3 Error handling on OMAP5 for the most part is very similar
to that of OMAP4, and had leveraged common data structures and
register layout definitions so far. Upon closer inspection, there
are a few minor differences causing an incorrect decoding and
reporting of the master NIU upon an error:
1. The L3_TARG_STDERRLOG_MSTADDR.STDERRLOG_MSTADDR occupies
11 bits on OMAP5 as against 8 bits on OMAP4, with the master
NIU connID encoded in the 6 MSBs of the STDERRLOG_MSTADDR
field.
2. The CLK3 FlagMux component has 1 input source on OMAP4 and 3
input sources on OMAP5. The common DEBUGSS source is at a
different input on each SoC.
Fix the above issues by using a OMAP5-specific compatible property
and using SoC-specific data where there are differences.
Acked-by: Nishanth Menon <nm@ti.com>
Pull ARM SoC late changes from Olof Johansson:
"We were expecting to sit on this branch through most of the merge
window since the contents was merged into our tree late, but we ended
up sitting on all of our contents so it can go in with the rest.
The contents here is:
- a large branch of cleanups of the CM/PRM blocks on OMAP.
- a couple of patches plumbing up CM/PRM on OMAP5 and DRA7.
- a branch with DT updates for Freescale i.MX. including some
shuffling from .dts to .dtsi (include) files that causes a little
churn"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (78 commits)
ARM: OMAP2+: Fix booting with configs that don't have MFD_SYSCON
ARM: OMAP4+: control: add support for initializing control module via DT
ARM: dts: dra7: add minimal l4 bus layout with control module support
ARM: dts: omap5: add minimal l4 bus layout with control module support
ARM: OMAP4+: control: remove support for legacy pad read/write
ARM: OMAP4: display: convert display to use syscon for dsi muxing
ARM: dts: omap4: add minimal l4 bus layout with control module support
ARM: dts: am4372: add minimal l4 bus layout with control module support
ARM: dts: am43xx-epos-evm: fix pinmux node layout
ARM: dts: am33xx: add minimal l4 bus layout with control module support
ARM: dts: omap3: add minimal l4 bus layout with control module support
ARM: dts: omap24xx: add minimal l4 bus layout with control module support
ARM: OMAP2+: control: add syscon support for register accesses
ARM: OMAP2+: id: cache omap_type value
ARM: OMAP2+: control: remove API for getting control module base address
ARM: OMAP2+: clock: add low-level support for regmap
ARM: OMAP4+: PRM: get rid of cpu_is_omap44xx calls from interrupt init
ARM: OMAP4+: PRM: setup prm_features from the PRM init time flags
ARM: OMAP2+: CM: move SoC specific init calls within a generic API
ARM: OMAP4+: PRM: determine prm_device_inst based on DT compatibility
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/late
Pull "Clean-up for omap PRCM (Power Reset Clock Management) and interconnects" from Tony Lindgren
Patches originally from Tero Kristo <t-kristo@ti.com>.
This sets gets us into a better position for further clean-up:
- Gets PRCM code closer to being device drivers
- Allows to move the remainig clock code to drivers/clk for v4.2
- Starts enforcing interconnect hierarchy in the SoC specific .dts
files to enforce device drivers are only accesing registers in
the related hardware module
This patchset has seen quite a few revisions but did not come into
mergeable shape until recently. As other patchsets for clock specific
device drivers depend on this, it would be good to get this merged
although it's a bit late for the v4.1 merge window.
Note that as the device entries in the .dts files are moved around,
this is based on earlier non-urgent fixes to avoid a non-trivial
merge conflict.
* tag 'omap-for-v4.1/prcm-dts' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (44 commits)
ARM: OMAP2+: PRM: move SoC specific init calls within a generic API
git://git.infradead.org/users/jcooper/linux into irq/core
irqchip core change for v4.1 (round 3) from Jason Cooper
Purge the gic_arch_extn hacks and abuse by using the new stacked domains
NOTE: Due to the nature of these changes, patches crossing subsystems have
been kept together in their own branches.
- tegra
- Handle the LIC properly
- omap
- Convert crossbar to stacked domains
- kill arm,routable-irqs in GIC binding
- exynos
- Convert PMU wakeup to stacked domains
- shmobile, ux500, zynq (irq_set_wake branch)
- Switch from abusing gic_arch_extn to using gic_set_irqchip_flags
This patch creates the l4_cfg and l4_wkup interconnects for OMAP5, and
moves some of the generic peripherals under it. System control module
support is added to the device tree also, and the existing SCM related
functionality is moved under it.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
OMAP4/5 has been (ab)using the gic_arch_extn to provide
wakeup from suspend, and it makes a lot of sense to convert
this code to use stacked domains instead.
This patch does just this, updating the DT files to actually
reflect what the HW provides.
BIG FAT WARNING: because the DTs were so far lying by not
exposing the WUGEN HW block, kernels with this patch applied
won't have any suspend-resume facility when booted with old DTs,
and old kernels with updated DTs won't even boot.
On a platform with this patch applied, the system looks like
this:
root@bacon-fat:~# cat /proc/interrupts
CPU0 CPU1
16: 0 0 WUGEN 37 gp_timer
19: 233799 155916 GIC 27 arch_timer
23: 0 0 WUGEN 9 l3-dbg-irq
24: 1 0 WUGEN 10 l3-app-irq
27: 282 0 WUGEN 13 omap-dma-engine
44: 0 0 4ae10000.gpio 13 DMA
294: 0 0 WUGEN 20 gpmc
297: 506 0 WUGEN 56 48070000.i2c
298: 0 0 WUGEN 57 48072000.i2c
299: 0 0 WUGEN 61 48060000.i2c
300: 0 0 WUGEN 62 4807a000.i2c
301: 8 0 WUGEN 60 4807c000.i2c
308: 2439 0 WUGEN 74 OMAP UART2
312: 362 0 WUGEN 83 mmc2
313: 502 0 WUGEN 86 mmc0
314: 13 0 WUGEN 94 mmc1
350: 0 0 PRCM pinctrl, pinctrl
406: 35155709 0 GIC 109 ehci_hcd:usb1
407: 0 0 WUGEN 7 palmas
409: 0 0 WUGEN 119 twl6040
410: 0 0 twl6040 5 twl6040_irq_ready
411: 0 0 twl6040 0 twl6040_irq_th
IPI0: 0 1 CPU wakeup interrupts
IPI1: 0 0 Timer broadcast interrupts
IPI2: 95334 902334 Rescheduling interrupts
IPI3: 0 0 Function call interrupts
IPI4: 479 648 Single function call interrupts
IPI5: 0 0 CPU stop interrupts
IPI6: 0 0 IRQ work interrupts
IPI7: 0 0 completion interrupts
Err: 0
Link: https://lkml.kernel.org/r/1426088629-15377-8-git-send-email-marc.zyngier@arm.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
OMAP4 has a finer counter granularity, which allows for a delay of 1000ms
in the thermal zone polling intervals. OMAP5 has a different counter
mechanism, which allows at maximum a 500ms timer. Adjust the cpu thermal
zone polling interval accordingly.
Without this patch, the polling interval information is simply ignored,
and the following thermal warnings are printed during boot (assuming
thermal is enabled);
[ 1.545343] ti-soc-thermal 4a0021e0.bandgap: Delay 1000 ms is not supported
[ 1.552691] ti-soc-thermal 4a0021e0.bandgap: Delay 1000 ms is not supported
[ 1.560029] ti-soc-thermal 4a0021e0.bandgap: Delay 1000 ms is not supported
Cc: Tony Lindgren <tony@atomide.com>
Acked-by: Eduardo Valentin <edubezval@gmail.com>
According to the Documentation/devicetree/bindings/dma/dma.txt the
dma-channels and dma-requests property should not have '#'.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
The sata_ref_clk is a reference clock to the SATA phy.
This fixes SATA malfunction across suspend/resume or when
SATA driver is used as a module.
The '#mbox-cells' property is added to all the OMAP mailbox
nodes. This property is mandatory with the new mailbox framework.
Cc: "Benoît Cousson" <bcousson@baylibre.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
Pull ARM SoC DT updates from Arnd Bergmann:
"As usual, this is the largest branch, though this time a little under
half of the total changes with 307 individual non-merge changesets.
The largest changes are the addition of new machines, in particular
the Tegra based Chromebook, the Renesas r8a7794 SoC, and DT support
for the old i.MX1 platform.
Other changes include
- at91: various sam9 and sama5 updates
- exynos: much extended Peach Pi/Pit (Chromebook 2) support
- keystone: new peripherals
- meson: added DT for meson6 SoC
- mvebu: new device support for Armada 370/375
- qcom: improved support for IPQ8064 and MSM8x60
- rockchip: much improved support for rk3288
- shmobile: lots of updates all over the place
- sunxi: dts license change
- sunxi: more a23 device support
- vexpress: CLCD DT description"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (308 commits)
ARM: DTS: meson: update DTSI to add watchdog node
ARM: dts: keystone-k2l: fix mdio io start address
ARM: dts: keystone-k2e: fix mdio io start address
ARM: dts: keystone-k2e: update usb1 node for dma properties
ARM: dts: keystone: fix io range for usb_phy0
Revert "Merge tag 'hix5hd2-dt-for-3.18' of git://github.com/hisilicon/linux-hisi into next/dt"
Revert "ARM: dts: hix5hd2: add wdg node"
ARM: dts: add rk3288 i2s controller
ARM: vexpress: Add CLCD Device Tree properties
ARM: bcm2835: add I2S pinctrl to device tree
ARM: meson: documentation: add bindings documentation
ARM: meson: dts: add basic Meson/Meson6/Meson6-atv1200 DTSI/DTS
ARM: dts: mt6589: Change compatible string for GIC
ARM: dts: mediatek: Add compatible property for aquaris5
ARM: dts: mt6589-aquaris5: Add boot argument earlyprintk
ARM: dts: mt6589: Fix typo in GIC unit address
ARM: dts: Build dtb for Mediatek board
ARM: dts: keystone: fix bindings for pcie and usb clock nodes
ARM: dts: keystone: k2l: Fix chip selects for SPI devices
ARM: dts: keystone: add dsp gpio controllers nodes
In order to handle errata I688, a page of sram was reserved by doing a
static iotable map. Now that we use gen_pool to manage sram, we can
completely remove all of these static mappings and use gen_pool_alloc()
to get the one page of sram space needed to implement errata I688.
omap_bus_sync will be NOP until SRAM initialization happens.
Suggested-by: Sekhar Nori <nsekhar@ti.com>
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
Use drivers/misc/sram.c driver to manage SRAM on all DT only
OMAP platforms (am33xx, am43xx, omap4 and omap5) instead of
the existing private plat-omap/sram.c
Address and size related data is removed from mach-omap2/sram.c
and now passed to drivers/misc/sram.c from DT.
Users can hence use general purpose allocator apis instead of
OMAP private ones to manage and use SRAM.
The sub-mailbox devices are added to the Mailbox DT nodes on
OMAP2420, OMAP2430, OMAP3, AM33xx, AM43xx, OMAP4 and OMAP5
family of SoCs. This data represents the same mailboxes that
used to be represented in hwmod attribute data previously.
The node name is chosen based on the .name field of
omap_mbox_dev_info structure used in the hwmod data.
https://github.com/nmenon/linux-2.6-playground into omap-for-v3.18/dt
We've had deeper idle states working on omaps for few years now,
but only in the legacy mode. When booted with device tree, the
wake-up events did not have a chance to work until commit
3e6cee1786a1 ("pinctrl: single: Add support for wake-up interrupts")
that recently got merged. In addition to that we also needed
commit 79d9701559a9 ("of/irq: create interrupts-extended property")
that's now also merged.
Note that there's no longer need to specify the wake-up bit in
the pinctrl settings, the request_irq on the wake-up pin takes
care of that.
Signed-off-by: Nishanth Menon <nm@ti.com>
Now that ti,omap5-padconf is available, switch over to that compatible
property. Retain pinctrl-single for legacy support.
While at it, mark pinctrl as interrupt controller so that it can be
used with interrupts-extended property for wakeup events.
Provide OMAP3, 4 and OMAP5 with interrupt number for PRM
And for DRA7, provide crossbar number for prm interrupt.
The RFBI node for OMAP DSS was left out when adding the rest of the DSS
nodes, because it was not clear how to set up the clocks for the RFBI.
However, it seems that if there is a HWMOD for a device, we also need a
DT node for it. Otherwise, at boot, we get:
WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2542 _init+0x464/0x4e0()
omap_hwmod: dss_rfbi: doesn't have mpu register target base
Now that v3.17-rc3 contains a fix 8fd46439e1f5 ("ARM: dts:
omap54xx-clocks: Fix the l3 and l4 clock rates") for the L3 ICLK
required by the RFBI, let's add the RFBI node to get rid of the
warning.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
[tony@atomide.com: updated description per comments from Nishant]
This resolves a nontrivial conflict against a bug fix
in another branch.
arch/arm/mach-exynos/pm.c
The number of mailbox fifos and users (IP interrupts) are added
to the Mailbox DT nodes on OMAP2420, OMAP2430, OMAP3, and OMAP5
family of SoCs through the DT properties "ti,mbox-num-fifos" and
"ti,mbox-num-users" properties. This data represents the same data
that used to be represented in hwmod attribute data through the
.num_fifos and .num_users fields previously.
Acked-by: Pavel Machek <pavel@ucw.cz>
Add ABB device nodes for OMAP5 family of devices. Data is based on
final production OMAP543x Technical Reference Manual revision Z (April 2013).
Final production Data Manual for OMAP5432 SWPS050F(APRIL 2014).
[nm@ti.com: co-developer and updates to latest documentation]
Signed-off-by: Andrii.Tseglytskyi <andrii.tseglytskyi@ti.com>
As per the Final production Data Manual for OMAP5432,
There are only two OPPs - 1GHz and 1.5GHz. the older OPP_LOW has been
completely descoped. The Nominal voltages are still correct though.
However, expectation for final production configuration is operation
with Adaptive Body Bias (ABB) and Adaptive Voltage Scaling Class 0
operation.
There are no IDcode or version change information encoded to
programmatically detect this and software is supposed to NOT use
OPP_LOW(500MHz) anymore for all devices (legacy and production
samples).
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux
Pull OMAP DT fbdev updates from Tomi Valkeinen:
"Here are display related device tree data changes for OMAP. They are
based on an already merged branch to satisfy the dependencies for the
dts file changes.
Add OMAP DT data:
- omap5 display subsystem
- display data for omap5 uEVM board
- am43xx display subsystem
- display data for am43xx ePOS and GP boards (LCD only)
- display data for GTA04 board
- display data for overo board
- display data for duovero-parlor board
- display data for omap3 evm and ldp boards"
* tag 'fbdev-omap-dt-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux:
ARM: omap5.dtsi: Add audio related parameters to hdmi node
ARM: omap4.dtsi: Add audio related parametes to hdmi node
ARM: dts: duovero-parlor: Add HDMI output
ARM: dts: overo: Add support for 3.5'' LCD output
ARM: dts: overo: Add support for 4.3'' LCD output
ARM: dts: overo: Add support for DVI output
ARM: dts: Add LCD panel sharp ls037v7dw01 support for omap3-evm and ldp
ARM: dts: omap3-gta04: Add display support
ARM: dts: omap5-uevm.dts: add display nodes
ARM: dts: omap5-uevm.dts: add tca6424a
ARM: dts: omap5.dtsi: add DSS nodes
ARM: dts: am43x-epos-evm: add LCD data
ARM: dts: am437x-gp-evm: add LCD data
ARM: dts: am4372.dtsi: add DSS information
Adds HDMI audio sDMA properties.
Signed-off-by: Jyri Sarha <jsarha@ti.com>
Add OMAP5 DSS nodes to omap5.dtsi.
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc into next
Pull ARM SoC devicetree updates from Olof Johansson:
"As with previous release, this continues to be among the largest
branches we merge, with lots of new contents.
New things for this release are among other things:
- DTSI contents for the new SoCs supported in 3.16 (see SoC pull request)
- Qualcomm APQ8064 and APQ8084 SoCs and eval boards
- Nvidia Jetson TK1 development board (Tegra T124-based)
Two new SoCs that didn't need enough new platform code to stand out
enough for me to notice when writing the SoC tag, but that adds new DT
contents are:
- TI DRA72
- Marvell Berlin 2Q"
* tag 'dt-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (500 commits)
ARM: dts: add secure firmware support for exynos5420-arndale-octa
ARM: dts: add pmu sysreg node to exynos3250
ARM: dts: correct the usb phy node in exynos5800-peach-pi
ARM: dts: correct the usb phy node in exynos5420-peach-pit
ARM: dts: add dts files for exynos5410 and exynos5410-smdk5410
ARM: dts: add dts files for exynos3250 SoC
ARM: dts: add mfc node for exynos5800
ARM: dts: add Vbus regulator for USB 3.0 on exynos5800-peach-pi
ARM: dts: enable fimd for exynos5800-peach-pi
ARM: dts: enable display controller for exynos5800-peach-pi
ARM: dts: enable hdmi for exynos5800-peach-pi
ARM: dts: add dts file for exynos5800-peach-pi board
ARM: dts: add dts file for exynos5800 SoC
ARM: dts: add dts file for exynos5260-xyref5260 board
ARM: dts: add dts files for exynos5260 SoC
ARM: dts: update watchdog node name in exynos5440
ARM: dts: use key code macros on Origen and Arndale boards
ARM: dts: enable RTC and WDT nodes on Origen boards
ARM: dts: qcom: Add APQ8084-MTP board support
ARM: dts: qcom: Add APQ8084 SoC support
