The license text has been mangled at some point then copy pasted across
multiple files. Restore it to what it should be.
Note that this is not intended as a license change.
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Rafał Miłecki <zajec5@gmail.com>
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
In order to support more linkstation devices, common part of current
.dts file goes into .dtsi file. Some .dtsi start with "mvebu-" prefix
because other kirkwood based linkstation devices are similar, and
will be migrated to use these .dtsi some time later.
- orion5x-linkstation.dtsi
- mvebu-linkstation-fan.dtsi
- mvebu-linkstation-gpio-simple.dtsi
while all rest part remains in device specific .dts file:
- orion5x-linkstation-lswtgl.dts
Signed-off-by: Roger Shimizu <rogershimizu@gmail.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
MTD flash stores u-boot and u-boot environment on linkstation lswtgl.
The latter one can be easily read/write by u-boot-tools package in Debian.
Fixes: dc57844a736f ("ARM: dts: orion5x: add buffalo linkstation ls-wtgl")
Here're a few gpio pin related fixes:
- remove pinctrl-0 definition from pinctrl, since those pins are used
in other places such as gpio-fan and regulators.
- keep initial state of power led
- fix for alarm pin of gpio-fan.
Add dts file to support Buffalo Linkstation LS-WTGL,
which is marvell orion5x based 2-bay 3.5" HDD NAS.
Product info:
- (JPN) http://buffalo.jp/products/catalog/storage/ls-wtgl_r1/
- (ENG) http://www.buffalotech.com/support-and-downloads/download/LinkStation_Pro_Duo_Manual_web.pdf
Acked-by: Andrew Lunn <andrew@lunn.ch>
