2016-09-14 | ARM: dts: orion5x: Configure WNR854T ethernet PHY LEDs | Jamie Lentin | |
The default PHY configuration disables most of the LEDs. The following configures the ethernet activity LEDs as Netgear intended. [gregory.clement@free-electrons.com: fix commit title] Signed-off-by: Jamie Lentin <jm@lentin.co.uk> Reviewed-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> | |||
2016-09-14 | ARM: dts: orion5x: Add description for Netgear WNR854T | Jamie Lentin | |
This is a router based on the mv88f5181 chipset. http://www.netgear.com/support/product/WNR854T.aspx http://wiki.openwrt.org/toh/netgear/wnr854t [gregory.clement@free-electrons.com: - extract dt part from "arm: orion5x: Add DT-based support for Netgear WNR854T" - squashed "arm: orion5x: Alias uart0 to serial0 for all orion5x" into this commit and move serial0 alias from dtsi to dts] Signed-off-by: Jamie Lentin <jm@lentin.co.uk> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> |
