path: root/arch/arm/boot/dts/picoxcell-pc7302-pc3x3.dts
2019-06-05treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 282Thomas Gleixner
Based on 1 normalized pattern(s): this software is licensed under the terms of the gnu general public license version 2 as published by the free software foundation and may be copied distributed and modified under those terms this program is distributed in the hope that it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose see the gnu general public license for more details extracted by the scancode license scanner the SPDX license identifier GPL-2.0-only has been chosen to replace the boilerplate/reference in 285 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Alexios Zavras <alexios.zavras@intel.com> Reviewed-by: Allison Randal <allison@lohutok.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190529141900.642774971@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-07arm: dts: replace 'linux,stdout-path' with 'stdout-path'Rob Herring
'linux,stdout-path' has been deprecated for some time in favor of 'stdout-path'. Now dtc will warn on occurrences of 'linux,stdout-path'. Search and replace all the of occurrences with 'stdout-path'. Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-09-26picoxcell: add the DTS for the PC7302 boardJamie Iles
The PC7302 board can be populated with either a PC3X2 or PC3X3 device. Add DTS files for both variants of the PC7302. v3: - remove bootargs from dts files Signed-off-by: Jamie Iles <jamie@jamieiles.com>
