Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
We currently have three device nodes for the same USB hardware
block, as evident by the reuse of the same reg address multiple
times. Now that the chipidea driver fully supports OTG with the
MSM wrapper we can collapse the three nodes into one USB device
node, reflecting the true nature of the hardware.
Since we're here, we also mark the irq trigger flags correctly,
as IRQ_TYPE_LEVEL_HIGH instead of IRQ_TYPE_NONE.
Cc: Bjorn Andersson <bjorn.andersson@linaro.org>
Cc: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Cc: Nicolas Dechesne <nicolas.dechesne@linaro.org>
Cc: John Stultz <john.stultz@linaro.org>
Signed-off-by: Stephen Boyd <stephen.boyd@linaro.org>
Signed-off-by: Andy Gross <andy.gross@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/agross/linux into next/dt
Qualcomm Device Tree Changes for v4.11
* Add Coresight components for APQ8064
* Fixup PM8058 nodes
* Add APQ8060 gyro and accel support
* Enable SD600 HDMI support
* Add RIVA supprort for Sony Yuga and SD600
* Add PM8821 support
* Add MSM8974 ADSP, USB gadget, SMD, and SMP2P support
* Fix IPQ8064 clock frequencies
* tag 'qcom-dts-for-4.11' of git://git.kernel.org/pub/scm/linux/kernel/git/agross/linux:
ARM: dts: qcom: Add apq8064 CoreSight components
ARM: dts: Add gyro and accel to APQ8060 Dragonboard
ARM: dts: reference PM8058 as IRQ parent
ARM: dts: rename MSM8660/APQ8060 pmicintc to pm8058
ARM: dts: sd-600eval: enable 1.8v regulator on LS expansion
ARM: dts: sd-600eval: add hdmi support
ARM: dts: move hdmi pinctrl out of board file.
ARM: dts: qcom: sd600eval: Enable riva-pil
ARM: dts: qcom: sd600-eval: pm8921_s2 regulator properties
ARM: dts: qcom: apq8064-sony-yuga: Enable riva-pil
ARM: dts: qcom: apq8064: Add riva-pil node
ARM: dts: apq8064: add support to pm8821
arm: dts: qcom: Fix ipq board clock rates
ARM: dts: msm8974: Remove "unused" reserved region
ARM: dts: msm8974: Add ADSP PIL node
ARM: dts: msm8974: Add ADSP smp2p and smd nodes
ARM: dts: qcom: msm8974: Add USB gadget nodes
Add initial set of CoreSight components found on Qualcomm apq8064 based
platforms, including the IFC6410 board.
Signed-off-by: Ivan T. Ivanov <ivan.ivanov@linaro.org>
Acked-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Signed-off-by: Georgi Djakov <georgi.djakov@linaro.org>
This patch moves hdmi pinctrl defination from board file to soc level
pinctrl file. If not this pinctrl setup will be duplicated across all
the apq8064 based board files.
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Reviewed-by: Archit Taneja <architt@codeaurora.org>
Add nodes for the Riva PIL, IRIS RF module, BT and WiFI services exposed
by the Riva firmware and the related memory reserve.
Also provides pinctrl nodes for devices enabling the riva-pil.
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Tested-by: John Stultz <john.stultz@linaro.org>
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
As per the device tree binding the apq8064 scm node requires the core
clock to be specified, so add this.
Adds the core gpu, and dsi nodes for the apq8064 needed
to get graphics working on the nexus7 and other devices.
These apply on top of Archit's patch set that enables HDMI for IFC6410
Feedback would be greatly appreciated!
Cc: Archit Taneja <architt@codeaurora.org>
Cc: vinay simha <vinaysimha@inforcecomputing.com>
Cc: andy.gross@linaro.org
Cc: robdclark@gmail.com
Cc: linux-arm-msm@vger.kernel.org
Cc: dri-devel@lists.freedesktop.org
Signed-off-by: John Stultz <john.stultz@linaro.org>
APQ8064 contains a MDP4 based display controller. It contains a HDMI, LVDS
and 2 DSI outputs.
Add display DT nodes for MDP4, HDMI TX and HDMI PHY. MDP4 based display
blocks have a flat device hierarchy.
Nodes for other outputs will be added later.
Cc: devicetree@vger.kernel.org
Signed-off-by: Archit Taneja <architt@codeaurora.org>
TSENS is part of GCC, hence add TSENS properties as part of GCC node.
Also add thermal zones and qfprom nodes.
Update GCC bindings doc to mention the possibility of optional TSENS
properties that can be part of GCC node.
Acked-by: Eduardo Valentin <edubezval@gmail.com>
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Rajendra Nayak <rnayak@codeaurora.org>
The Qualcomm PMIC GPIO and MPP lines are problematic: the
are fetched from the main MFD driver with platform_get_irq()
which means that at this point they will all be assigned the
flags set up for the interrupts in the device tree.
That is problematic since these are flagged as rising edge
and an this point the interrupt descriptor is assigned a
rising edge, while the only thing the GPIO/MPP drivers really
do is issue irq_get_irqchip_state() on the line to read it
out and to provide a .to_irq() helper for *other* IRQ
consumers.
If another device tree node tries to flag the same IRQ
for use as something else than rising edge, the kernel
irqdomain core will protest like this:
type mismatch, failed to map hwirq-NN for <FOO>!
Which is what happens when the device tree defines two
contradictory flags for the same interrupt line.
To work around this and alleviate the problem, assign 0
as flag for the interrupts taken by the PM GPIO and MPP
drivers. This will lead to the flag being unset, and a
second consumer requesting rising, falling, both or level
interrupts will be respected. This is what the qcom-pm*.dtsi
files already do.
Switched to using the symbolic name IRQ_TYPE_NONE so that
we get this more readable.
Cc: stable@vger.kernel.org
Fixes: bce360469676 ("ARM: dts: apq8064: add pm8921 mpp support")
Fixes: 874443fe9e33 ("ARM: dts: apq8064: Add pm8921 mfd and its gpio node")
Cc: Stephen Boyd <sboyd@codeaurora.org>
Cc: Björn Andersson <bjorn.andersson@linaro.org>
Cc: Ivan T. Ivanov <ivan.ivanov@linaro.org>
Cc: Andy Gross <andy.gross@linaro.org>
Most 8064 devices have micro-usb ports for phy1, so setting
the dr_mode to host here seems incorrect.
Leaving it unspecified should default to otg, and then
any boards that wish to specify something else, can
override it in their dts file.
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Andy Gross <agross@codeaurora.org>
Cc: Stephen Boyd <stephen.boyd@linaro.org>
Reviewed-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Pull ARM DT updates from Olof Johansson:
"Device tree contents continue to be the largest branches we submit.
This time around, some of the contents worth pointing out is:
New SoC platforms:
- Freescale i.MX 7Solo
- Broadcom BCM23550
- Cirrus Logic EP7209 and EP7211 (clps711x platforms)_
- Hisilicon HI3519
- Renesas R8A7792
Some of the other delta that is sticking out, line-count wise:
- Exynos moves of IP blocks under an SoC bus, which causes a large
delta due to indentation changes
- a new Tegra K1 board: Apalis
- a bunch of small updates to many Allwinner platforms; new hardware
support, some cleanup, etc"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (426 commits)
ARM: dts: sun8i: Add dts file for inet86dz board
ARM: dts: sun8i: Add dts file for Polaroid MID2407PXE03 tablet
ARM: dts: sun8i: Use sun8i-reference-design-tablet for ga10h dts
ARM: dts: sun8i: Use sun8i-reference-design-tablet for polaroid mid2809pxe04
ARM: dts: sun8i: reference-design-tablet: Add drivevbus-supply
ARM: dts: Copy sun8i-q8-common.dtsi sun8i-reference-design-tablet.dtsi
ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for utoo p66 dts
ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for dit4350 dts
ARM: dts: sun5i: reference-design-tablet: Remove mention of q8
ARM: dts: sun5i: reference-design-tablet: Set lradc vref to avcc
ARM: dts: sun5i: Rename sun5i-q8-common.dtsi sun5i-reference-design-tablet.dtsi
ARM: dts: sun5i: Move q8 display bits to sun5i-a13-q8-tablet.dts
ARM: dts: sunxi: Rename sunxi-q8-common.dtsi sunxi-reference-design-tablet.dtsi
ARM: dts: at91: Don't build unnecessary dtbs
ARM: dts: at91: sama5d3x: separate motherboard gmac and emac definitions
ARM: dts: at91: at91sam9g25ek: fix isi endpoint node
ARM: dts: at91: move isi definition to at91sam9g25ek
ARM: dts: at91: fix i2c-gpio node name
ARM: dts: at91: vinco: fix regulator name
ARM: dts: at91: ariag25 : fix onewire node
Update the compatible string to align with driver and also
add SoC specific string to DTS.
CC: linux-watchdog@vger.kernel.org
Signed-off-by: Matthew McClintock <mmcclint@codeaurora.org>
Signed-off-by: Thomas Pedersen <twp@codeaurora.org>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
This patch updates the qcom,state-cells to qcom,smem-state-cells to
match recent changes to the binding.
This patch moves out the sdcc1 pinctrl nodes out of board files to soc file,
so that it will be duplicated in other board files.
This patch adds the firmware node for the APQ8064
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Pull ARM DT updates from Arnd Bergmann:
"These are all the updates to device tree files for 32-bit platforms,
which as usual makes up the bulk of the ARM SoC changes: 462 non-merge
changesets, 450 files changed, 23340 insertions, 5216 deletions.
The three platforms that are added with the "soc" branch are here as
well, and we add some related machine files:
- For Aspeed AST2400/AST2500, we get the evaluation platform and the
Tyan Palmetto POWER8 mainboard that uses the AST2400 BMC
- For Oxnas 810SE, the Western Digital "My Book World Edition" is
added as the only platform at the moment.
- For ARM MPS2, the AN385 (Cortex-M3) and AN399 (Cortex-M7) are
supported
On the ARM Realview development platform, we now support all machines
with device tree, previously only the board files were supported,
which in turn will likely be removed soon.
Qualcomm IPQ4019 is the second generation ARM based "Internet
Processor", following the IPQ806x that is used in many high-end WiFi
routers. This one integrates two ath10k wifi radios that were
previously on separate chips.
Other boards that got added for existing chips are:
Ti OMAP family:
- Amazon Kindle Fire, first generation, tablet and ebook reader
- OnRISC Baltos iR 2110 and 3220 embedded industrial PCs
- TI AM5728 IDK, TI AM3359 ICE-V2, and TI DRA722 Rev C EVM
development systems
Samsung EXYNOS platform:
- Samsung ARTIK5 evaluation board, see
https://www.artik.io/modules/overview/artik-5/
NXP i.MX platforms:
- Ka-Ro electronics TX6S-8034, TX6S-8035, TX6U-8033, TX6U-81xx,
TX6Q-1036, TX6Q-1110/-1130, TXUL-0010 and TXUL-0011 industrial
SoM modules
- Embest MarS Board i.MX6Dual DIY platform
- Boundary Devices i.MX6 Quad Plus Nitrogen6_MAX and SoloX
Nitrogen6sx embedded boards
- Technexion Pico i.MX6UL compute module
- ZII VF610 Development Board
Marvell embedded (mvebu, orion, kirkwood) platforms:
- Linksys Viper (E4200v2 / EA4500) WiFi router
- Buffalo Kurobox Pro NAS
Qualcomm Snapdragon:
- Arrow DragonBoard 600c (96boards) with APQ8064 Snapdragon 600
Rockchips platform:
- mqmaker MiQi single-board computer
Altera SoCFPGA:
- samtec VIN|ING 1000 vehicle communication interface
Allwinner Sunxi platforms:
- Dserve DSRV9703C tablet
- Difrnce DIT4350 tablet
- Colorfly E708 Q1 tablet
- Polaroid MID2809PXE04 tablet
- Olimex A20 OLinuXino LIME2 single board computer
- Xunlong Orange Pi 2, Orange Pi One, and Orange Pi PC single board
computers
Across many platforms, bug fixes went in to address warnings that dtc
now emits with 'make dtbs W=1'. Further changes for device enablement
went into Ti OMAP, bcm283x (Raspberry Pi), bcm47xx (wifi router), Ti
Davinci, Samsung EXYNOS, Marvell mvebu/kirkwood/orion, NXP i.MX/Vybrid
NXP LPC18xx, NXP LPC32xx, Renesas shmobile/r-mobile/r-car, Rockchips
rk3xxx, ST Ux500, ST STi, Atmel AT91/SAMA5, Altera SoCFPGA, Allwinner
Sunxi, Sigma Designs Tango, NVIDIA Tegra, Socionext Uniphier and ARM
Versatile Express"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (458 commits)
ARM: dts: tango4: Import watchdog node
ARM: dts: tango4: Update cpus node for cpufreq
ARM: dts: tango4: Update DT to match clk driver
ARM: dts: tango4: Initial thermal support
arm/dst: Add Aspeed ast2500 device tree
arm/dts: Add Aspeed ast2400 device tree
ARM: sun7i: dt: Add pll3 and pll7 clocks
ARM: dts: sunxi: Add a olinuxino-lime2-emmc
ARM: dts: at91: sama5d4: add trng node
ARM: dts: at91: sama5d3: add trng node
ARM: dts: at91: sama5d2: add trng node
ARM: dts: at91: at91sam9g45 family: reduce the trng register map size
ARM: sun4i: dt: Add pll3 and pll7 clocks
ARM: sun5i: chip: Enable the TV Encoder
ARM: sun5i: r8: Add display blocks to the DTSI
ARM: sun5i: a13: Add display and TCON clocks
ARM: dts: ux500: configure the accelerometers open drain
ARM: mx5: dts: Enable USB OTG on M53EVK
ARM: dts: imx6ul-14x14-evk: Add audio support
ARM: dts: imx6qdl: Remove unneeded unit-addresses
This patch adds support to gsbi7 i2c which is used in some of the new
boards.
This patch adds support to gsbi1 uart and its pinctrls nodes.
This patch fixes pinctrls for spi and i2c nodes whose default and sleep
states are together, which is incorrect.
Without this patch i2c/spi would not be functional.
This patch adds new ports-implemented mask, which is required to get
achi working on the mainline. Without this patch value read from
PORTS_IMPL register which is zero would not enable any ports for
software to use.
Fixes: 566d1827df2e ("libata: disable forced PORTS_IMPL for >= AHCI 1.3")
Cc: stable@vger.kernel.org # v4.5+
Reviewed-by: Andy Gross <andy.gross@linaro.org>
The compatible string "simple-bus" is well defined in ePAPR, while
I see no documentation for the "arm,amba-bus" arnywhere in ePAPR or
Documentation/devicetree/.
DT is also used by other projects than Linux kernel. It is not a
good idea to rely on such an unofficial binding.
This commit
- replaces "arm,amba-bus" with "simple-bus"
- drops "arm,amba-bus" where it is used along with "simple-bus"
This patch adds i2c6 device node and pinctrls required for IFC6410 on
MIPI-CSI connector.
This patch adds gsbi4 and i2c node.
This patch adds missing i2c2 pinctrl information in i2c2 node.
This patch adds spi5 device node, spi5 is used on ifc6410 on the
expansion connector.
This patch adds missing i2c pinctrl sleep states.
Also add 16mA drive strength to the pins so that we can detect wide
range of i2c devices on the other side of level shifters.
As there are more pinctrls to come, moving these to dedicated dtsi makes
more sense.
This patch fixes i2c lables to be inline with serial labels.
The reason to do this is that it would look odd if we add aliases in the
board file along with serial.
This adds address-cell and size-cell values to the i2c3 bus
in the qcom-apq8064.dtsi, which is needed to describe devices
on that bus.
Cc: Arnd Bergmann <arnd.bergmann@linaro.org>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
Cc: Vinay Simha BN <simhavcs@gmail.com>
Acked-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Add the RPM Clock Controller DT node.
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"PCI changes for the v4.5 merge window:
Enumeration:
- Simplify config space size computation (Bjorn Helgaas)
- Avoid iterating through ROM outside the resource window (Edward O'Callaghan)
- Support PCIe devices with short cfg_size (Jason S. McMullan)
- Add Netronome vendor and device IDs (Jason S. McMullan)
- Limit config space size for Netronome NFP6000 family (Jason S. McMullan)
- Add Netronome NFP4000 PF device ID (Simon Horman)
- Limit config space size for Netronome NFP4000 (Simon Horman)
- Print warnings for all invalid expansion ROM headers (Vladis Dronov)
Resource management:
- Fix minimum allocation address overwrite (Christoph Biedl)
PCI device hotplug:
- acpiphp_ibm: Fix null dereferences on null ibm_slot (Colin Ian King)
- pciehp: Always protect pciehp_disable_slot() with hotplug mutex (Guenter Roeck)
- shpchp: Constify hpc_ops structure (Julia Lawall)
- ibmphp: Remove unneeded NULL test (Julia Lawall)
Power management:
- Make ASPM sysfs link_state_store() consistent with link_state_show() (Andy Lutomirski)
Virtualization
- Add function 1 DMA alias quirk for Lite-On/Plextor M6e/Marvell 88SS9183 (Tim Sander)
MSI:
- Remove empty pci_msi_init_pci_dev() (Bjorn Helgaas)
- Mark PCIe/PCI (MSI) IRQ cascade handlers as IRQF_NO_THREAD (Grygorii Strashko)
- Initialize MSI capability for all architectures (Guilherme G. Piccoli)
- Relax msi_domain_alloc() to support parentless MSI irqdomains (Liu Jiang)
ARM Versatile host bridge driver:
- Remove unused pci_sys_data structures (Lorenzo Pieralisi)
Broadcom iProc host bridge driver:
- Hide CONFIG_PCIE_IPROC (Arnd Bergmann)
- Do not use 0x in front of %pap (Dmitry V. Krivenok)
- Update iProc PCIe device tree binding (Ray Jui)
- Add PAXC interface support (Ray Jui)
- Add iProc PCIe MSI device tree binding (Ray Jui)
- Add iProc PCIe MSI support (Ray Jui)
Freescale i.MX6 host bridge driver:
- Use gpio_set_value_cansleep() (Fabio Estevam)
- Add support for active-low reset GPIO (Petr Štetiar)
HiSilicon host bridge driver:
- Add support for HiSilicon Hip06 PCIe host controllers (Gabriele Paoloni)
Intel VMD host bridge driver:
- Export irq_domain_set_info() for module use (Keith Busch)
- x86/PCI: Allow DMA ops specific to a PCI domain (Keith Busch)
- Use 32 bit PCI domain numbers (Keith Busch)
- Add driver for Intel Volume Management Device (VMD) (Keith Busch)
Qualcomm host bridge driver:
- Document PCIe devicetree bindings (Stanimir Varbanov)
- Add Qualcomm PCIe controller driver (Stanimir Varbanov)
- dts: apq8064: add PCIe devicetree node (Stanimir Varbanov)
- dts: ifc6410: enable PCIe DT node for this board (Stanimir Varbanov)
Renesas R-Car host bridge driver:
- Add support for R-Car H3 to pcie-rcar (Harunobu Kurokawa)
- Allow DT to override default window settings (Phil Edworthy)
- Convert to DT resource parsing API (Phil Edworthy)
- Revert "PCI: rcar: Build pcie-rcar.c only on ARM" (Phil Edworthy)
- Remove unused pci_sys_data struct from pcie-rcar (Phil Edworthy)
- Add runtime PM support to pcie-rcar (Phil Edworthy)
- Add Gen2 PHY setup to pcie-rcar (Phil Edworthy)
- Add gen2 fallback compatibility string for pci-rcar-gen2 (Simon Horman)
- Add gen2 fallback compatibility string for pcie-rcar (Simon Horman)
Synopsys DesignWare host bridge driver:
- Simplify control flow (Bjorn Helgaas)
- Make config accessor override checking symmetric (Bjorn Helgaas)
- Ensure ATU is enabled before IO/conf space accesses (Stanimir Varbanov)
Miscellaneous:
- Add of_pci_get_host_bridge_resources() stub (Arnd Bergmann)
- Check for PCI_HEADER_TYPE_BRIDGE equality, not bitmask (Bjorn Helgaas)
- Fix all whitespace issues (Bogicevic Sasa)
- x86/PCI: Simplify pci_bios_{read,write} (Geliang Tang)
- Use to_pci_dev() instead of open-coding it (Geliang Tang)
- Use kobj_to_dev() instead of open-coding it (Geliang Tang)
- Use list_for_each_entry() to simplify code (Geliang Tang)
- Fix typos in <linux/msi.h> (Thomas Petazzoni)
- x86/PCI: Clarify AMD Fam10h config access restrictions comment (Tomasz Nowicki)"
* tag 'pci-v4.5-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (58 commits)
PCI: Add function 1 DMA alias quirk for Lite-On/Plextor M6e/Marvell 88SS9183
PCI: Limit config space size for Netronome NFP4000
PCI: Add Netronome NFP4000 PF device ID
x86/PCI: Add driver for Intel Volume Management Device (VMD)
PCI/AER: Use 32 bit PCI domain numbers
irqdomain: Export irq_domain_set_info() for module use
PCI: host: Add of_pci_get_host_bridge_resources() stub
genirq/MSI: Relax msi_domain_alloc() to support parentless MSI irqdomains
PCI: rcar: Add Gen2 PHY setup to pcie-rcar
PCI: rcar: Add runtime PM support to pcie-rcar
PCI: designware: Make config accessor override checking symmetric
PCI: ibmphp: Remove unneeded NULL test
ARM: dts: ifc6410: enable PCIe DT node for this board
ARM: dts: apq8064: add PCIe devicetree node
PCI: hotplug: Use list_for_each_entry() to simplify code
PCI: rcar: Remove unused pci_sys_data struct from pcie-rcar
PCI: hisi: Add support for HiSilicon Hip06 PCIe host controllers
PCI: Avoid iterating through memory outside the resource window
PCI: acpiphp_ibm: Fix null dereferences on null ibm_slot
Add the PCIe DT node so that it can probe and be used.
Signed-off-by: Stanimir Varbanov <stanimir.varbanov@linaro.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Currently the rates of the xo and sleep clocks are hard-coded in the
GCC driver, but this is a board layout description that actually should
be in the DT. Moving them into DT also allows us to insert the RPM
controlled clocks between the DT and GCC clocks.
Signed-off-by: Andy Gross <agross@codeaurora.org>
Add the generic compatible strings for the PMIC gpio and MPP
modules found on qcom based PMICs.
Cc: <devicetree@vger.kernel.org>
Cc: "Ivan T. Ivanov" <iivanov@mm-sol.com>
Cc: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Cc: Rob Herring <robh@kernel.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Reviewed-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Consolidate all labeling of regulators into the core 8064 dtsi file to
make them available from all other dts files.
Add devicetree data to add support for hw_rng support
to the apq8064 dts.
Tested on the Nexus7 (2013).
This patch adds missing gsbi7 uart pinctrl, this is the default debug
uart on most boards.
Usage of generic names like "uart_pins" is confusing to the reader, given
the fact that there could be more than one uart on APQ8064.
This patch adds gsbi prefix to uart pinctrl nodes so as to avoid such
confusion.
This patch adds support to pm8921 power button.
This patch adds rtc node for pmic8921.
This patch removes i2c pinctrl properties from board which which are now
mentioned in the SOC specific file. This will avoid redundant properties
across multiple board fiiles.
This patch removes temporary fixed regluator use for mmc.
Board files should use the regulators which are wiredup appropriately.
