Add an alias for the PMICs found on qcom based SoCs so that the
newly updated dtbTool can find the PMIC compatible string and add
the pmic-id element to the QCDT header.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Andy Gross <agross@codeaurora.org>
The ifc6540 is an sbc (single board computer) board, so update
the compatible field accordingly.
Use stdout-path so that we don't have to put the console on the
kernel command line.
PMA8084 have 2 SPMI devices per physical package. Add their
configuration nodes and include them in boards which are using
AQP8084 based chipset.
Signed-off-by: Ivan T. Ivanov <iivanov@mm-sol.com>
Signed-off-by: Kumar Gala <galak@codeaurora.org>
Add basic support for the IFC6540 single-board computer boards, that are
based on the APQ8084 SoC. This patch adds the initial device tree and the
neccessary nodes required for enabling the serial port and eMMC.
Signed-off-by: Georgi Djakov <gdjakov@mm-sol.com>
