Add an alias for the PMICs found on qcom based SoCs so that the
newly updated dtbTool can find the PMIC compatible string and add
the pmic-id element to the QCDT header.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Andy Gross <agross@codeaurora.org>
Use stdout-path so that we don't have to put the console on the
kernel command line.
PMA8084 have 2 SPMI devices per physical package. Add their
configuration nodes and include them in boards which are using
AQP8084 based chipset.
Signed-off-by: Ivan T. Ivanov <iivanov@mm-sol.com>
Signed-off-by: Kumar Gala <galak@codeaurora.org>
Add the necessary DT node to probe the serial driver on
APQ8084 platforms.
Signed-off-by: Georgi Djakov <gdjakov@mm-sol.com>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Add device-tree file for APQ8084-MTP board, which belongs
to the Snapdragon 805 family.
