[ Upstream commit bd73a3dd257fb838bd456a18eeee0ef0224b7a40 ]
while compiling an ipq4019 target, dtc will complain:
regulator@b089000 unit address format error, expected "2089000"
The saw0 regulator reg value seems to be
copied and pasted from qcom-ipq8064.dtsi.
This patch fixes the reg value to match that of the
unit address which in turn silences the warning.
(There is no driver for qcom,saw2 right now.
So this went unnoticed)
Signed-off-by: Christian Lamparter <chunkeey@gmail.com>
Signed-off-by: John Crispin <john@phrozen.org>
Signed-off-by: Andy Gross <andy.gross@linaro.org>
This patch adds and enables the device-tree definitions for
both qcom,ipq4019-wifi blocks for the IPQ4019.
Support for these have been added into the ath10k driver since:
commit 280e762e9c72 ("ath10k: enable ipq4019 device probe in ahb module")
The binding documentation was added in:
commit a47aaa69de88 ("dt: bindings: add new dt entry for pre calibration in qcom, ath10k.txt")
This has been tested on an ASUS RT-AC58U (IPQ4019),
an AVM Fritz!Box 4040 (IPQ4018), a Compex WPJ428 (IPQ4028)
and a Cisco Meraki MR33 (IPQ4029).
| a000000.wifi: qca4019 hw1.0 target 0x01000000 chip_id 0x003b00ff [...]
| a000000.wifi: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
| a000000.wifi: firmware ver 10.4-3.4-00082 api 5 features no-p2p,mfp,[...]
| a000000.wifi: board_file api 2 bmi_id 0:16 crc32 5773b188
| a000000.wifi: htt-ver 2.2 wmi-op 6 htt-op 4 cal pre-cal-file [...]
| a800000.wifi: qca4019 hw1.0 target 0x01000000 chip_id 0x003b00ff sub 0000:0000
| a800000.wifi: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
| a800000.wifi: firmware ver 10.4-3.4-00082 api 5 features no-p2p, [...]
| a800000.wifi: board_file api 2 bmi_id 0:17 crc32 5773b188
| a800000.wifi: htt-ver 2.2 wmi-op 6 htt-op 4 cal pre-cal-file [...]
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
This architecture has a pseudo random number generator
supported by the existing "qcom,prng" binding.
rngtest: bits received from input: 5795960032
rngtest: FIPS 140-2 successes: 289591
rngtest: FIPS 140-2 failures: 207
rngtest: FIPS 140-2(2001-10-10) Monobit: 25
rngtest: FIPS 140-2(2001-10-10) Poker: 28
rngtest: FIPS 140-2(2001-10-10) Runs: 91
rngtest: FIPS 140-2(2001-10-10) Long run: 67
rngtest: FIPS 140-2(2001-10-10) Continuous run: 0
rngtest: input channel speed: (min=244; avg=46122; max=3906250)Kibits/s
rngtest: FIPS tests speed: (min=1.327; avg=20.966; max=26.345)Mibits/s
rngtest: Program run time: 386965827 microseconds
The node for xo and timer belong to the SoC DTS file.
Else, new board DT files may not inherit these nodes.
Signed-off-by: Varadarajan Narayanan <varada@codeaurora.org>
This patch fixes the pinctrl node addresses to be the correct format.
This patch fixes two typos in the i2c_0 node for the ipq4019.
The reg property length is just 0x600. The core clock is
GCC_BLSP1_QUP1_I2C_APPS_CLK. GCC_BLSP1_QUP2_I2C_APPS_CLK is
used by the second i2c.
Fixes: e76b4284b520ba3 ("qcom: ipq4019: add i2c node to ipq4019 SoC and DK01 device tree")
Pull ARM DT updates from Olof Johansson:
"Device tree contents continue to be the largest branches we submit.
This time around, some of the contents worth pointing out is:
New SoC platforms:
- Freescale i.MX 7Solo
- Broadcom BCM23550
- Cirrus Logic EP7209 and EP7211 (clps711x platforms)_
- Hisilicon HI3519
- Renesas R8A7792
Some of the other delta that is sticking out, line-count wise:
- Exynos moves of IP blocks under an SoC bus, which causes a large
delta due to indentation changes
- a new Tegra K1 board: Apalis
- a bunch of small updates to many Allwinner platforms; new hardware
support, some cleanup, etc"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (426 commits)
ARM: dts: sun8i: Add dts file for inet86dz board
ARM: dts: sun8i: Add dts file for Polaroid MID2407PXE03 tablet
ARM: dts: sun8i: Use sun8i-reference-design-tablet for ga10h dts
ARM: dts: sun8i: Use sun8i-reference-design-tablet for polaroid mid2809pxe04
ARM: dts: sun8i: reference-design-tablet: Add drivevbus-supply
ARM: dts: Copy sun8i-q8-common.dtsi sun8i-reference-design-tablet.dtsi
ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for utoo p66 dts
ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for dit4350 dts
ARM: dts: sun5i: reference-design-tablet: Remove mention of q8
ARM: dts: sun5i: reference-design-tablet: Set lradc vref to avcc
ARM: dts: sun5i: Rename sun5i-q8-common.dtsi sun5i-reference-design-tablet.dtsi
ARM: dts: sun5i: Move q8 display bits to sun5i-a13-q8-tablet.dts
ARM: dts: sunxi: Rename sunxi-q8-common.dtsi sunxi-reference-design-tablet.dtsi
ARM: dts: at91: Don't build unnecessary dtbs
ARM: dts: at91: sama5d3x: separate motherboard gmac and emac definitions
ARM: dts: at91: at91sam9g25ek: fix isi endpoint node
ARM: dts: at91: move isi definition to at91sam9g25ek
ARM: dts: at91: fix i2c-gpio node name
ARM: dts: at91: vinco: fix regulator name
ARM: dts: at91: ariag25 : fix onewire node
Commit 0dfd582e026a ("watchdog: qcom: use timer devicetree
binding") moved to use the watchdog as a subset timer
register block. Some devices have the watchdog completely
standalone with slightly different register offsets as
well so let's account for the differences here.
The existing "kpss-standalone" compatible string doesn't
make it entirely clear exactly what the device is so
rename to "kpss-wdt" to reflect watchdog timer
functionality. Also update ipq4019 DTS with an SoC
specific compatible.
Signed-off-by: Matthew McClintock <mmcclint@codeaurora.org>
Signed-off-by: Thomas Pedersen <twp@codeaurora.org>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
Add support for cortex-a7-pmu present on ipq4019 SoCs.
This adds the blsp_dma node to the device tree and the required
properties for using DMA with serial
This adds the crypto nodes to the ipq4019 device tree, it also adds the
BAM node used by crypto as well which the driver currently requires to
operate properly
The crypto driver itself depends on some other patches to qcom_bam_dma
to function properly:
https://lkml.org/lkml/2015/12/1/113
CC: Stanimir Varbanov <svarbanov@mm-sol.com>
This adds some operating points for cpu frequeny scaling
This will allow boards to enable the I2C bus
CC: Sricharan R <srichara@qti.qualcomm.com>
This will allow boards to enable the SPI bus
This will allow these types of boards to be rebooted.
This will allow boards to enable watchdog support
This adds the required device tree nodes to bring up the
secondary cores on the ipq4019 SoC.
Add initial dts files and SoC support for IPQ4019
