Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
This defines the memory location and interrupt used by the GSBI8
I2C adapter on the MSM8660 SoCs. We add it as "disabled" by
default so that boards using this I2C can enable it.
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Signed-off-by: Andy Gross <andy.gross@linaro.org>
This adds the PM8058 XOADC node to the PM8058 PMIC node,
defines the 16 channels and further also define an IIO HWMON
node for the channels that are used for housekeeping of
voltages and die temperature for the PMIC chip die.
Tested on the APQ8060 DragonBoard:
cd /sys/class/hwmon/hwmon0
cat in2_input
4773 (DC mains ~5V)
cat in4_input
625 (0.625V reference voltage)
cat in5_input
1250 (1.25V reference voltage)
cat temp1_input
35852 (die temperature)
To make the picture complete, add DTS entries also for the
second and fourth MMC/SD blocks on the MSM8660. SDC2 is
an 8-bit interface and SDC4 is a 4-bit interface.
Reviewed-by: Bjorn Andersson <bjorn.andersson@linaro.org>
The name "pmicintc" is ambiguous: there is a second power
management IC named PM8901 on these systems, and it is also
an interrupt controller. To make things clear, just name the
node alias "pm8058", this in unambigous and has all information
we need.
This adds the external bus interface EBI2 to the MSM8660 device
tree, albeit with status = "disabled" so that devices actually
using EBI2 can turn it on if needed.
The Qualcomm SPMI GPIO and MPP lines are problematic: the
are fetched from the main MFD driver with platform_get_irq()
which means that at this point they will all be assigned the
flags set up for the interrupts in the device tree.
That is problematic since these are flagged as rising edge
and an this point the interrupt descriptor is assigned a
rising edge, while the only thing the GPIO/MPP drivers really
do is issue irq_get_irqchip_state() on the line to read it
out and to provide a .to_irq() helper for *other* IRQ
consumers.
If another device tree node tries to flag the same IRQ
for use as something else than rising edge, the kernel
irqdomain core will protest like this:
type mismatch, failed to map hwirq-NN for <FOO>!
Which is what happens when the device tree defines two
contradictory flags for the same interrupt line.
To work around this and alleviate the problem, assign 0
as flag for the interrupts taken by the PM GPIO and MPP
drivers. This will lead to the flag being unset, and a
second consumer requesting rising, falling, both or level
interrupts will be respected. This is what the qcom-pm*.dtsi
files already do.
Switched to using the symbolic name IRQ_TYPE_NONE so that
we get this more readable.
This misconfiguration was caused by a copy/pasting the
APQ8064 set-up, the latter has been fixed in a separate
patch.
Tested with one of the SPMI GPIOs: after this I can
successfully request one of these GPIOs as falling edge
from the device tree.
Fixes: 0840ea9e4457 ("ARM: dts: add GPIO and MPP to MSM8660 PMIC")
Cc: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Cc: Stephen Boyd <sboyd@codeaurora.org>
Cc: Björn Andersson <bjorn.andersson@linaro.org>
Cc: Ivan T. Ivanov <ivan.ivanov@linaro.org>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Andy Gross <andy.gross@linaro.org>
There is currently a fixed regulator in the .dtsi file for
the MSM8660 chipset, used by the SURF board. We want to define
real regulators for a board using this chipset, so push the fixed
regulator down to the SURF board which is the only user.
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
The RTC was defined on 0x11d but on the MSM8660/APQ8060 it is
actually on 0x1e8. We were saved by the fact that the driver does
not use the reg parameter: instead it uses the compatible string
to figure out where the RTC is.
The I2C block on the GSBI12 is used on the APQ8060 Dragonboard for
sensors. Make it available in the chipset file.
Take this opportunity to fix the IRQ flag "0" to "NONE" using the
IRQ DT include.
This adds the L2CC IPC resource and RPM devices plus the nodes
for the PM8901 and PM8058 regulators to the MSM8660 device tree.
This was tested on the APQ8060 Dragonboard.
The SDCC5 SD/MMC controller is used for a second uSD slot
on the APQ8060 Dragonboard. On most other systems it is just
dark silicon so define it and leave it as "disabled" in the core
SoC file.
This adds the 8660 PMIC GPIO and MPP blocks to the MSM8660
DTSI. Verified against the vendor tree to be in these locations
with these interrupts, tested on the APQ8060 Dragonboard.
The compatible string "simple-bus" is well defined in ePAPR, while
I see no documentation for the "arm,amba-bus" arnywhere in ePAPR or
Documentation/devicetree/.
DT is also used by other projects than Linux kernel. It is not a
good idea to rely on such an unofficial binding.
This commit
- replaces "arm,amba-bus" with "simple-bus"
- drops "arm,amba-bus" where it is used along with "simple-bus"
These clocks are fixed rate board sources that should be in DT.
Add them.
Cc: Georgi Djakov <georgi.djakov@linaro.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Reviewed-by: Georgi Djakov <georgi.djakov@linaro.org>
Add a label to the serial nodes that are being used for the
console.
Replace the standalone gpio driver with pinctrl-msm as we now have
msm8660 support there.
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Signed-off-by: Andy Gross <agross@codeaurora.org>
Enable perf events on msm8660 devices by adding the pmu node.
Signed-off-by: Kumar Gala <galak@codeaurora.org>
This patch adds TCSR support for use by the GSBI to automatically
configure ADM CRCI values based on the GSBI port configuration.
Add the sdcc nodes to support the SD card controller using pl180
mmci driver. We also add a temporary fixed regulator until the
regulator driver is mainlined.
Add the PMIC and the sub-devices that are currently supported in
the kernel to the DT.
* Move SoC peripherals into an SoC container node
* Move serial enabling into board file (qcom-msm8660-surf.dts)
* Cleanup cpu node to match binding spec, enable-method and compatible
should be per cpu, not part of the container
* Add GSBI node and configuration of GSBI controller
Add the necessary nodes to support SMP on MSM8660, MSM8960, and
MSM8974/APQ8074. While we're here also add in the error
interrupts for the Krait cache error detection.
Signed-off-by: Rohit Vaswani <rvaswani@codeaurora.org>
[sboyd: Split into separate patch, add error interrupts]
Pull the SoC device tree bits into their own files so other boards based
on these SoCs can include them and reduce duplication across a number of
boards.
