This patch adds TCSR support for use by the GSBI to automatically
configure ADM CRCI values based on the GSBI port configuration.
Signed-off-by: Andy Gross <agross@codeaurora.org>
Signed-off-by: Kumar Gala <galak@codeaurora.org>
Add the sdcc nodes to support the SD card controller using pl180
mmci driver. We also add a temporary fixed regulator until the
regulator driver is mainlined.
Cc: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Add the PMIC and the sub-devices that are currently supported in
the kernel to the DT.
* Move SoC peripherals into an SoC container node
* Move serial enabling into board file (qcom-msm8660-surf.dts)
* Cleanup cpu node to match binding spec, enable-method and compatible
should be per cpu, not part of the container
* Add GSBI node and configuration of GSBI controller
Add the necessary nodes to support SMP on MSM8660, MSM8960, and
MSM8974/APQ8074. While we're here also add in the error
interrupts for the Krait cache error detection.
Signed-off-by: Rohit Vaswani <rvaswani@codeaurora.org>
[sboyd: Split into separate patch, add error interrupts]
Pull the SoC device tree bits into their own files so other boards based
on these SoCs can include them and reduce duplication across a number of
boards.
