Add initial support for the display found on the LG Nexus 5 (hammerhead)
phone. This is based on work from Jonathan Marek.
Signed-off-by: Brian Masney <masneyb@onstation.org>
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Add necessary device tree nodes for the main LCD backlight.
Add support for the Synaptics RMI4 touchscreen that is found on the
Nexus 5.
Signed-off-by: Jonathan Marek <jonathan@marek.ca>
Add the device tree bindings for USB OTG support. Driver was tested
using on a LG Nexus 5 (hammerhead) phone. This patch is based on work
from Jonathan Marek and from the other msm8974 devices.
Signed-off-by: Andy Gross <andy.gross@linaro.org>
This patch adds WiFi support to the LG Nexus 5 (hammerhead) phone.
[masneyb@onstation.org: Enabled wlan_regulator_pin and wlan_sleep_clk_pin]
This patch correctly sets the gpios property for the ak8963
magnetometer's DRDY pin so that interrupts work properly.
This patch adds device tree bindings for the tsl2772 ALS / proximity
sensor for the LG Nexus 5 (hammerhead) phone.
Acked-by: Jonathan Cameron <jonathan.cameron@huawei.com>
This patch adds device tree bindings for the mpu6515 to the LG Nexus 5
(hammerhead) phone. Confirmed that the gyroscope / accelerometer
(mpu6515), magnetometer (ak8963), and temperature / pressure (bmp280)
sensors are available on the phone.
Interrupts are not working properly on the ak8963 magnetometer so they
are currently not configured.
The bmp280 retuns temperature/pressure measurement skipped errors but
will reliably work if I run:
echo 1 > in_pressure_oversampling_ratio
echo 1 > in_temp_oversampling_ratio
The kernel would not boot on the hammerhead hardware due to the
following error:
mmc0: Timeout waiting for hardware interrupt.
mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
mmc0: sdhci: Sys addr: 0x00000200 | Version: 0x00003802
mmc0: sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000200
mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000023
mmc0: sdhci: Present: 0x03e80000 | Host ctl: 0x00000034
mmc0: sdhci: Power: 0x00000001 | Blk gap: 0x00000000
mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
mmc0: sdhci: Timeout: 0x0000000e | Int stat: 0x00000000
mmc0: sdhci: Int enab: 0x02ff900b | Sig enab: 0x02ff100b
mmc0: sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
mmc0: sdhci: Caps: 0x642dc8b2 | Caps_1: 0x00008007
mmc0: sdhci: Cmd: 0x00000c1b | Max curr: 0x00000000
mmc0: sdhci: Resp[0]: 0x00000c00 | Resp[1]: 0x00000000
mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
mmc0: sdhci: Host ctl2: 0x00000008
mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x70040220
mmc0: sdhci: ============================================
mmc0: Card stuck in wrong state! mmcblk0 card_busy_detect status: 0xe00
mmc0: cache flush error -110
mmc0: Reset 0x1 never completed.
This patch increases the load on l20 to 0.2 amps for the sdhci
and allows the device to boot normally.
Signed-off-by: Bhushan Shah <bshah@kde.org>
Suggested-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Tested-by: Brian Masney <masneyb@onstation.org>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
This introduces the eMMC sdhci node and its pinctrl state
Reviewed-by: Bjorn Andersson <bjorn.andersson@linaro.org>
This introduces the gpio-keys node for keys of hammerhead and pinctrl
state associated with it.
Cc: Andy Gross <andy.gross@linaro.org>
Cc: Bjorn Andersson <bjorn.andersson@linaro.org>
Cc: David Brown <david.brown@linaro.org>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Russell King <linux@armlinux.org.uk>
Cc: linux-arm-msm@vger.kernel.org
Cc: linux-soc@vger.kernel.org
Cc: devicetree@vger.kernel.org
This DTS file have support LG Nexus 5 (codenamed hammerhead).
Initial version have support for just serial console over headphone
jack.
