* Move SoC peripherals into an SoC container node
* Move serial enabling into board file (qcom-apq8074-dragonboard.dts)
* Move spi pinctrl into board file
* Cleanup cpu node to match binding spec, enable-method and compatible
should be per cpu, not part of the container
* Drop interrupts property from l2-cache node as its not part of the
binding spec
* Move timer node out of SoC container
Signed-off-by: Kumar Gala <galak@codeaurora.org>
Add support for the 2 SDHC controllers on the DB8074 board. The first
controller (at 0xf9824900) is connected to an on board soldered eMMC.
The second controller (at 0xf98a4900) is connected to a uSD card slot.
Signed-off-by: Georgi Djakov <gdjakov@mm-sol.com>
Add the pin control node and pin definitions of SPI8.
Signed-off-by: Ivan T. Ivanov <iivanov@mm-sol.com>
Reviewed-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Pull ARM SoC device tree changes from Arnd Bergmann:
"A large part of the arm-soc patches are nowadays DT changes, adding
support for new SoCs, boards and devices without changing kernel
source. The plan is still to move the devicetree files out of the
kernel tree and reduce the amount of churn going on here, but we keep
finding reasons to delay doing that.
Changes are really all over the place, with little sticking out
particularly. We have contributions from a total of 116 people in
this branch.
Unfortunately, the size of this branch also causes a significant
number of conflicts at the moment, typically when subsystem
maintainers merge patches that change the driver at the same time as
the dts files. In most cases this could be avoided because the dts
changes are supposed to be compatible in both ways, and we are asking
everyone to send ARM dts changes through our tree only"
* tag 'dt-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (541 commits)
dts: stmmac: Document the clocks property in the stmmac base document
dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac.
ARM: STi: stih41x: Add support for the FSM Serial Flash Controller
ARM: STi: stih416: Add support for the FSM Serial Flash Controller
ARM: tegra: fix Dalmore pinctrl configuration
ARM: dts: keystone: use common "ti,keystone" compatible instead of -evm
ARM: dts: k2hk-evm: set ubifs partition size for 512M NAND
ARM: dts: Build all keystone dt blobs
ARM: dts: keystone: Fix control register range for clktsip
ARM: dts: keystone: Fix domain register range for clkfftc1
ARM: dts: bcm28155-ap: leave camldo1 on to fix reboot
ARM: dts: add bcm590xx pmu support and enable for bcm28155-ap
ARM: dts: bcm21664: Add device tree files.
ARM: DT: bcm21664: Device tree bindings
ARM: efm32: properly namespace i2c location property
ARM: efm32: fix unit address part in USART2 device nodes' names
ARM: mvebu: Enable NAND controller in Armada 385-DB
ARM: mvebu: Add support for NAND controller in Armada 38x SoC
ARM: mvebu: Add the Core Divider clock to Armada 38x SoCs
ARM: mvebu: Add a 2 GHz fixed-clock on Armada 38x SoCs
Allows us to probe the performance counters on Krait CPUs.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
[olof: Moved 8960 contents to the dtsi instead]
Add the necessary DT node to probe the rng driver on
msm8974 platforms.
Signed-off-by: Stanimir Varbanov <svarbanov@mm-sol.com>
Acked-by: Stephen Boyd <sboyd@codeaurora.org>
Add the necessary nodes to support SMP on MSM8660, MSM8960, and
MSM8974/APQ8074. While we're here also add in the error
interrupts for the Krait cache error detection.
Signed-off-by: Rohit Vaswani <rvaswani@codeaurora.org>
[sboyd: Split into separate patch, add error interrupts]
Add the necessary DT nodes to probe the clock controllers on MSM
devices as well as hook up the uart nodes to the clock
controllers. This should allow us to boot to a serial console on
all DT enabled MSM platforms.
Cc: David Brown <davidb@codeaurora.org>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
Add the mmio architected timer node.
Signed-off-by: David Brown <davidb@codeaurora.org>
Add the restart node so we can reboot the device.
Add support for the Snapdragon 800 MSM8974 SoC, used on the Dragonboard
and others. Board support added in separate patch.
Acked-by: Kumar Gala <galak@codeaurora.org>
[olof: split off SoC support in separate patch]
