Add the MDP5, DSI and DSI PHY blocks for the display found on the
msm8974 SoCs. This is based on work from msm8916.dtsi and Jonathan
Marek.
Signed-off-by: Brian Masney <masneyb@onstation.org>
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
CoreSight DT bindings have been updated, thus the old compatible strings
are obsolete and the drivers will report warning if DTS uses these
obsolete strings.
This patch switches to the new bindings for CoreSight dynamic funnel,
so can dismiss warning during initialisation.
Cc: Andy Gross <agross@kernel.org>
Cc: David Brown <david.brown@linaro.org>
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Cc: Suzuki K Poulose <suzuki.poulose@arm.com>
Signed-off-by: Leo Yan <leo.yan@linaro.org>
Signed-off-by: Andy Gross <agross@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/agross/linux into arm/dt
Qualcomm Device Tree Changes for v5.1
* Fixup GIC IRQ flags and GSBI state on MSM8660
* Add USB OTG, gpio ranges, and Wifi support on MSM8974 Hammerhead
* Remove skeleton.dtsi on IPQ4019
* tag 'qcom-dts-for-5.1' of git://git.kernel.org/pub/scm/linux/kernel/git/agross/linux:
ARM: dts: ipq4019: Remove skeleton.dtsi
ARM: dts: qcom: msm8974-hammerhead: add USB OTG support
ARM: dts: qcom: msm8974: add gpio-ranges
ARM: dts: qcom: msm8974-hammerhead: add WiFi support
ARM: dts: msm8660: Fix up GIC IRQ flags
ARM: dts: msm8660: Mark two GSBI blocks "disabled"
Remove the usage of skeleton.dtsi in the remaining dts files. It was
deprecated since commit 9c0da3cc61f1 ("ARM: dts: explicitly mark
skeleton.dtsi as deprecated"). This will make adding a unit-address to
memory nodes easier.
The main tricky part to removing skeleton.dtsi is we could end up with
no /memory node at all when a bootloader depends on one being present. I
hacked up dtc to check for this condition.
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Reviewed-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Acked-by: Neil Armstrong <narmstrong@baylibre.com>
Acked-by: Antoine Tenart <antoine.tenart@bootlin.com>
Acked-by: Alexandre TORGUE <alexandre.torgue@st.com>
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Acked-by: Vladimir Zapolskiy <vz@mleia.com>
Tested-by: Kevin Hilman <khilman@baylibre.com>
Reviewed-by: Kevin Hilman <khilman@baylibre.com>
Tested-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
Reviewed-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
Signed-off-by: Rob Herring <robh@kernel.org>
Reviewed-by: Gregory CLEMENT <gregory.clement@bootlin.com>
Tested-by: Gregory CLEMENT <gregory.clement@bootlin.com>
Add the device tree bindings for USB OTG support. Driver was tested
using on a LG Nexus 5 (hammerhead) phone. This patch is based on work
from Jonathan Marek and from the other msm8974 devices.
Signed-off-by: Andy Gross <andy.gross@linaro.org>
As per upstream discussion [1], we should have an SoC-specific
compatible string for Qualcomm's SDHCI nodes. Let's add it.
[1] https://lkml.kernel.org/r/20181105203657.GA32282@bogus
Signed-off-by: Douglas Anderson <dianders@chromium.org>
This new property allows the number of sensors to be configured from DT
instead of being hardcoded in platform data. Use it.
Signed-off-by: Amit Kucheria <amit.kucheria@linaro.org>
Reviewed-by: Matthias Kaehlcke <mka@chromium.org>
Reviewed-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Acked-by: Andy Gross <andy.gross@linaro.org>
We've earlier added support to split the register address space into TM
and SROT regions. Split up the regmap address space into two for msm8974
that has a similar register layout.
Since tsens-common.c/init_common() currently only registers one address
space, the order is important (TM before SROT). This is OK since the
code doesn't really use the SROT functionality yet.
Switch to the new hardware port bindings for coresight
Cc: Andy Gross <andy.gross@linaro.org>
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
The following commits used IRQ_TYPE_NONE since that matched what was
already in the file and I do not have access to the datasheets for
these devices. After these patches were submitted, commit dcf145011400
("ARM: dts: qcom-msm8974: change invalid flag IRQ NONE to valid value")
changed all of these values to IRQ_TYPE_LEVEL_HIGH. This patch corrects
the IRQ type for these two commits:
commit bd9392507588 ("ARM: dts: qcom: msm8974-hammerhead: add device
tree bindings for ALS / proximity")
commit fe8d81fe7d9a ("ARM: dts: qcom: msm8974-hammerhead: add device
tree bindings for mpu6515")
Prior to these patches, I was having issues with the bmp280 sensor
returning temperature / pressure skipped errors, however these errors
have gone away with these patches.
Patches were tested on a LG Nexus 5 (hammerhead) phone.
This patch adds device tree bindings for the tsl2772 ALS / proximity
sensor for the LG Nexus 5 (hammerhead) phone.
Signed-off-by: Jonathan Marek <jonathan@marek.ca>
Acked-by: Jonathan Cameron <jonathan.cameron@huawei.com>
This patch adds device tree bindings for the mpu6515 to the LG Nexus 5
(hammerhead) phone. Confirmed that the gyroscope / accelerometer
(mpu6515), magnetometer (ak8963), and temperature / pressure (bmp280)
sensors are available on the phone.
Interrupts are not working properly on the ak8963 magnetometer so they
are currently not configured.
The bmp280 retuns temperature/pressure measurement skipped errors but
will reliably work if I run:
echo 1 > in_pressure_oversampling_ratio
echo 1 > in_temp_oversampling_ratio
Change the third field of the "interrupts" property from
IRQ_TYPE_NONE to the correct value.
I do not have hardware documentation for these devices, so I
followed a mail list suggestion to copy the flag values from the same
type of node in arch/arm64/boot/dts/qcom/msm8916.dtsi
Signed-off-by: Frank Rowand <frank.rowand@sony.com>
Cosmetic change of integer value "0" in the third field of the
"interrupts" property to the correct named constant.
Cosmetic change of integer value "4" in the third field of the
Cosmetic change of integer value "1" in the third field of the
Cosmetic change of integer value "0" in the first field of the
Cosmetic change of integer value "1" in the first field of the
Pull ARM device-tree updates from Arnd Bergmann:
"We add device tree files for a couple of additional SoCs in various
areas:
Allwinner R40/V40 for entertainment, Broadcom Hurricane 2 for
networking, Amlogic A113D for audio, and Renesas R-Car V3M for
automotive.
As usual, lots of new boards get added based on those and other SoCs:
- Actions S500 based CubieBoard6 single-board computer
- Amlogic Meson-AXG A113D based development board
- Amlogic S912 based Khadas VIM2 single-board computer
- Amlogic S912 based Tronsmart Vega S96 set-top-box
- Allwinner H5 based NanoPi NEO Plus2 single-board computer
- Allwinner R40 based Banana Pi M2 Ultra and Berry single-board computers
- Allwinner A83T based TBS A711 Tablet
- Broadcom Hurricane 2 based Ubiquiti UniFi Switch 8
- Broadcom bcm47xx based Luxul XAP-1440/XAP-810/ABR-4500/XBR-4500
wireless access points and routers
- NXP i.MX51 based Zodiac Inflight Innovations RDU1 board
- NXP i.MX53 based GE Healthcare PPD biometric monitor
- NXP i.MX6 based Pistachio single-board computer
- NXP i.MX6 based Vining-2000 automotive diagnostic interface
- NXP i.MX6 based Ka-Ro TX6 Computer-on-Module in additional variants
- Qualcomm MSM8974 (Snapdragon 800) based Fairphone 2 phone
- Qualcomm MSM8974pro (Snapdragon 801) based Sony Xperia Z2 Tablet
- Realtek RTD1295 based set-top-boxes MeLE V9 and PROBOX2 AVA
- Renesas R-Car V3M (R8A77970) SoC and "Eagle" reference board
- Renesas H3ULCB and M3ULCB "Kingfisher" extension infotainment boards
- Renasas r8a7745 based iWave G22D-SODIMM SoM
- Rockchip rk3288 based Amarula Vyasa single-board computer
- Samsung Exynos5800 based Odroid HC1 single-board computer
For existing SoC support, there was a lot of ongoing work, as usual
most of that concentrated on the Renesas, Rockchip, OMAP, i.MX,
Amlogic and Allwinner platforms, but others were also active.
Rob Herring and many others worked on reducing the number of issues
that the latest version of 'dtc' now warns about. Unfortunately there
is still a lot left to do.
A rework of the ARM foundation model introduced several new files for
common variations of the model"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (599 commits)
arm64: dts: uniphier: route on-board device IRQ to GPIO controller for PXs3
dt-bindings: bus: Add documentation for the Technologic Systems NBUS
arm64: dts: actions: s900-bubblegum-96: Add fake uart5 clock
ARM: dts: owl-s500: Add CubieBoard6
dt-bindings: arm: actions: Add CubieBoard6
ARM: dts: owl-s500-guitar-bb-rev-b: Add fake uart3 clock
ARM: dts: owl-s500: Set power domains for CPU2 and CPU3
arm: dts: mt7623: remove unused compatible string for pio node
arm: dts: mt7623: update usb related nodes
arm: dts: mt7623: update crypto node
ARM: dts: sun8i: a711: Enable USB OTG
ARM: dts: sun8i: a711: Add regulator support
ARM: dts: sun8i: a83t: bananapi-m3: Enable AP6212 WiFi on mmc1
ARM: dts: sun8i: a83t: cubietruck-plus: Enable AP6330 WiFi on mmc1
ARM: dts: sun8i: a83t: Move mmc1 pinctrl setting to dtsi file
ARM: dts: sun8i: a83t: allwinner-h8homlet-v2: Add AXP818 regulator nodes
ARM: dts: sun8i: a83t: bananapi-m3: Add AXP813 regulator nodes
ARM: dts: sun8i: a83t: cubietruck-plus: Add AXP818 regulator nodes
ARM: dts: sunxi: Add dtsi for AXP81x PMIC
arm64: dts: allwinner: H5: Restore EMAC changes
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
git://git.kernel.org/pub/scm/linux/kernel/git/agross/linux into next/soc
Pull "Qualcomm Device Tree Changes for v4.15" from Andy Gross:
* Add Support for MSM8974 based Fairphone 2 phone
* Add support for MSM8974 based Sony Xperia Z2 Tablet
* Add MSM8660 GSBI6/7 nodes
* Disable GSBI6 at APQ8064 platform level
* Fix phy cells on APQ8064
* tag 'qcom-dts-for-4.15' of git://git.kernel.org/pub/scm/linux/kernel/git/agross/linux:
ARM: dts: msm8974-FP2: Add USB node
ARM: dts: msm8974-FP2: Add sdhci1 node
ARM: dts: msm8974-FP2: Add regulator nodes for FP2
ARM: dts: msm8974-FP2: Introduce gpio-keys nodes
ARM: dts: qcom: Add initial DTS file for Fairphone 2 phone
ARM: dts: qcom: add MSM8660 GSBI6 and GSBI7
ARM: dts: qcom: msm8974: Add Sony Xperia Z2 Tablet
ARM: dts: qcom-apq8064: disable gsbi6 i2c by default at soc dtsi
ARM: dts: qcom-apq8064: Fix dsi and hdmi phy cells
Fix dtc warnings for 'simple_bus_reg' due to leading 0s. Converted using
the following command:
perl -p -i -e 's/\@0+([0-9a-f])/\@$1/g' `find arch/arm/boot/dts -type -f -name '*.dts*'
Dropped changes to ARM, Ltd. boards LED nodes and manually fixed up some
occurrences of uppercase hex.
This adds a basic DTS file for the Sony Xperia Z2 Tablet, containing
definitions for regulators, eMMC/SD-card, USB, WiFi, Touchscreen,
charger, backlight, coincell and buttons.
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Replace the obsolete compatible string for Coresight programmable
replicator with the new one.
Cc: linux-arm-msm@vger.kernel.org
Reviewed-by: Mathieu Poirier <mathieu.poirier@linaro.org>
This USB controller has two phys, so add them both underneath the
ULPI bus, but only enable one of them based on the board
configuration. To get OTG to work, we need to add the id and vbus
detection info and also populate the regulators for the vbus
supply.
Signed-off-by: Stephen Boyd <stephen.boyd@linaro.org>
These regulators are controlled by the SPMI regulator driver
instead of the RPM regulator driver in the downstream android
kernel sources. Let's remove them from the DTS here because
they'll never be used by the RPM regulator driver.
Cc: Bjorn Andersson <bjorn.andersson@linaro.org>
This reverts commit 769907ae6e6c2871c2ba4f578814d86fbfbe8d91.
This change caused issues with people using USB gadget for serial
consoles. In addition, with the other USB changes coming in, it
makes sense to revert this patch and apply the new set as it
becomes ready.
Add the RPM Clock Controller DT node for msm8974-based platforms, so that
drivers can use the clocks provided by the RPM processor.
Signed-off-by: Georgi Djakov <georgi.djakov@linaro.org>
Without this patch (and with CONFIG_QCOM_ADSP_PIL), I get this error:
[ 0.711529] qcom_adsp_pil adsp-pil: failed to get xo clock
[ 0.711540] remoteproc remoteproc0: releasing adsp-pil
With this patch, adsp-pil can initialize correctly.
Signed-off-by: Jonathan Neuschäfer <j.neuschaefer@gmx.net>
Add initial set of CoreSight components found on Qualcomm
msm8974 and apq8074 based platforms, including the APQ8074
Dragonboard board.
Signed-off-by: Ivan T. Ivanov <ivan.ivanov@linaro.org>
sources for msm8974, this isn't actually a reserved region.
Instead it's marked as "unused" for reserved regions. Let's
remove it so we get back a good chunk of memory.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Add the necessary nodes for USB gadget on MSM8974 and enable these for
Honami.
Add xo entry to sdhc clock node on all qcom platforms.
Signed-off-by: Ritesh Harjani <riteshh@codeaurora.org>
vreg_boost is Qualcomm platform specific and is also used in hammerhead
device.
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Russell King <linux@armlinux.org.uk>
Cc: linux-soc@vger.kernel.org
Cc: devicetree@vger.kernel.org
Signed-off-by: Bhushan Shah <bshah@kde.org>
Add thermal zones, tsens and qfprom nodes
Acked-by: Eduardo Valentin <edubezval@gmail.com>
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Rajendra Nayak <rnayak@codeaurora.org>
This serial port is used by LG Nexus 5 (codenammed hammerhead).
Cc: Stephen Boyd <stephen.boyd@linaro.org>
This patch updates the qcom,state-cells to qcom,smem-state-cells to
match recent changes to the binding.
This patch adds the Qualcomm SCM firmware node.
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
This adds back the dma channels for the i2c1 node. This is safe now
that the qcom,controlled-remotely changes are in place and will be used
on the boards that require it.
This reverts commit 10c0f0e92f019ab8d0c17da3696e35b0eef4ec16.
This puts back in place the blsp2_bam node. This can be safely added
due to the addition of the special qcom,controlled-remotely flag that
will be used on specific boards that require it.
This reverts commit 338d51889851cb2ac900d2ec75c8185afcde8caf.
Pull ARM DT updates from Arnd Bergmann:
"These are all the updates to device tree files for 32-bit platforms,
which as usual makes up the bulk of the ARM SoC changes: 462 non-merge
changesets, 450 files changed, 23340 insertions, 5216 deletions.
The three platforms that are added with the "soc" branch are here as
well, and we add some related machine files:
- For Aspeed AST2400/AST2500, we get the evaluation platform and the
Tyan Palmetto POWER8 mainboard that uses the AST2400 BMC
- For Oxnas 810SE, the Western Digital "My Book World Edition" is
added as the only platform at the moment.
- For ARM MPS2, the AN385 (Cortex-M3) and AN399 (Cortex-M7) are
supported
On the ARM Realview development platform, we now support all machines
with device tree, previously only the board files were supported,
which in turn will likely be removed soon.
Qualcomm IPQ4019 is the second generation ARM based "Internet
Processor", following the IPQ806x that is used in many high-end WiFi
routers. This one integrates two ath10k wifi radios that were
previously on separate chips.
Other boards that got added for existing chips are:
Ti OMAP family:
- Amazon Kindle Fire, first generation, tablet and ebook reader
- OnRISC Baltos iR 2110 and 3220 embedded industrial PCs
- TI AM5728 IDK, TI AM3359 ICE-V2, and TI DRA722 Rev C EVM
development systems
Samsung EXYNOS platform:
- Samsung ARTIK5 evaluation board, see
https://www.artik.io/modules/overview/artik-5/
NXP i.MX platforms:
- Ka-Ro electronics TX6S-8034, TX6S-8035, TX6U-8033, TX6U-81xx,
TX6Q-1036, TX6Q-1110/-1130, TXUL-0010 and TXUL-0011 industrial
SoM modules
- Embest MarS Board i.MX6Dual DIY platform
- Boundary Devices i.MX6 Quad Plus Nitrogen6_MAX and SoloX
Nitrogen6sx embedded boards
- Technexion Pico i.MX6UL compute module
- ZII VF610 Development Board
Marvell embedded (mvebu, orion, kirkwood) platforms:
- Linksys Viper (E4200v2 / EA4500) WiFi router
- Buffalo Kurobox Pro NAS
Qualcomm Snapdragon:
- Arrow DragonBoard 600c (96boards) with APQ8064 Snapdragon 600
Rockchips platform:
- mqmaker MiQi single-board computer
Altera SoCFPGA:
- samtec VIN|ING 1000 vehicle communication interface
Allwinner Sunxi platforms:
- Dserve DSRV9703C tablet
- Difrnce DIT4350 tablet
- Colorfly E708 Q1 tablet
- Polaroid MID2809PXE04 tablet
- Olimex A20 OLinuXino LIME2 single board computer
- Xunlong Orange Pi 2, Orange Pi One, and Orange Pi PC single board
computers
Across many platforms, bug fixes went in to address warnings that dtc
now emits with 'make dtbs W=1'. Further changes for device enablement
went into Ti OMAP, bcm283x (Raspberry Pi), bcm47xx (wifi router), Ti
Davinci, Samsung EXYNOS, Marvell mvebu/kirkwood/orion, NXP i.MX/Vybrid
NXP LPC18xx, NXP LPC32xx, Renesas shmobile/r-mobile/r-car, Rockchips
rk3xxx, ST Ux500, ST STi, Atmel AT91/SAMA5, Altera SoCFPGA, Allwinner
Sunxi, Sigma Designs Tango, NVIDIA Tegra, Socionext Uniphier and ARM
Versatile Express"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (458 commits)
ARM: dts: tango4: Import watchdog node
ARM: dts: tango4: Update cpus node for cpufreq
ARM: dts: tango4: Update DT to match clk driver
ARM: dts: tango4: Initial thermal support
arm/dst: Add Aspeed ast2500 device tree
arm/dts: Add Aspeed ast2400 device tree
ARM: sun7i: dt: Add pll3 and pll7 clocks
ARM: dts: sunxi: Add a olinuxino-lime2-emmc
ARM: dts: at91: sama5d4: add trng node
ARM: dts: at91: sama5d3: add trng node
ARM: dts: at91: sama5d2: add trng node
ARM: dts: at91: at91sam9g45 family: reduce the trng register map size
ARM: sun4i: dt: Add pll3 and pll7 clocks
ARM: sun5i: chip: Enable the TV Encoder
ARM: sun5i: r8: Add display blocks to the DTSI
ARM: sun5i: a13: Add display and TCON clocks
ARM: dts: ux500: configure the accelerometers open drain
ARM: mx5: dts: Enable USB OTG on M53EVK
ARM: dts: imx6ul-14x14-evk: Add audio support
ARM: dts: imx6qdl: Remove unneeded unit-addresses
One part of the efs memory region is used specifically for sharing file system
buffers between the apps and modem cpus (aka rmtfs), so better reflect this
split.
Revert this commit to fix regressions on non-dragonboard MSM8974 boards.
This will be put back in after the correct fixes to the bam driver are
accepted that allow remote processor control of the main control registers.
This reverts commit 0a5d0f85bba61d8643d78869c7c4214d6c2a7ce6.
This reverts commit 62bc8179222372624fd8a52b88327b962614d7b2.
Signed-off-by: Sricharan R <sricharan@codeaurora.org>
Reviewed-by: Andy Gross <andy.gross@linaro.org>
