vreg_boost is Qualcomm platform specific and is also used in hammerhead
device.
Cc: Andy Gross <andy.gross@linaro.org>
Cc: Bjorn Andersson <bjorn.andersson@linaro.org>
Cc: David Brown <david.brown@linaro.org>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Russell King <linux@armlinux.org.uk>
Cc: linux-arm-msm@vger.kernel.org
Cc: linux-soc@vger.kernel.org
Cc: devicetree@vger.kernel.org
Signed-off-by: Bhushan Shah <bshah@kde.org>
Reviewed-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Signed-off-by: Andy Gross <andy.gross@linaro.org>
The #size-cells for the pmics are 0, but we specify a size in the
reg property so that MPP and GPIO modules can figure out how many
pins there are. Now that we've done that by counting irqs, we can
remove the size elements in the reg properties and be DT
compliant.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Acked-by: Andy Gross <andy.gross@linaro.org>
The properties specified in the wled node could harm connected hardware,
so move the properties to Honami and disable the platform node.
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Signed-off-by: Andy Gross <agross@codeaurora.org>
Add the generic compatible strings for the PMIC gpio and MPP
modules found on qcom based PMICs.
Cc: <devicetree@vger.kernel.org>
Cc: "Ivan T. Ivanov" <iivanov@mm-sol.com>
Cc: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Cc: Rob Herring <robh@kernel.org>
Reviewed-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Add an alias for the PMICs found on qcom based SoCs so that the
newly updated dtbTool can find the PMIC compatible string and add
the pmic-id element to the QCDT header.
Signed-off-by: Courtney Cavin <courtney.cavin@sonymobile.com>
This doesn't match the binding, and the driver doesn't look to
be using it. Remove the extra element.
CC: Ivan T. Ivanov <ivan.ivanov@linaro.org>
Acked-by: Ivan T. Ivanov <ivan.ivanov@linaro.org>
Add framework for the coincell charger DT block in pm8941 file, and
actual values for honami battery in the honami dts file.
Signed-off-by: Tim Bird <tim.bird@sonymobile.com>
Reviewed-by: Andy Gross <agross@codeaurora.org>
Add configuration nodes for following devices:
* GPIO block, with 36 pins
* MPP block, with 8 pins
* Current ADC (IADC)
* Volatage ADC (VADC), with multiple inputs
* Thermal sensor device, which is using on chip VADC
channel report PMIC die temperature
* Power key device, which is responsible for clean system
reboot or shutdown
* White LED device
* RTC device
Signed-off-by: Ivan T. Ivanov <ivan.ivanov@linaro.org>
Signed-off-by: Kumar Gala <galak@codeaurora.org>
PM8841 and PM8941 have 2 SPMI devices per physical package.
Add their configuration nodes and include them in boards
which are using 8x74 based chipset.
Signed-off-by: Ivan T. Ivanov <iivanov@mm-sol.com>
