This patch adds the power key device tree node.
Signed-off-by: Andy Gross <andy.gross@linaro.org>
Reviewed-by: Bjorn Andersson <bjorn.andersson@linaro.org>
The #size-cells for the pmics are 0, but we specify a size in the
reg property so that MPP and GPIO modules can figure out how many
pins there are. Now that we've done that by counting irqs, we can
remove the size elements in the reg properties and be DT
compliant.
Add the generic compatible strings for the PMIC gpio and MPP
modules found on qcom based PMICs.
Cc: <devicetree@vger.kernel.org>
Cc: "Ivan T. Ivanov" <iivanov@mm-sol.com>
Cc: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Cc: Rob Herring <robh@kernel.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Reviewed-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Signed-off-by: Andy Gross <agross@codeaurora.org>
Add an alias for the PMICs found on qcom based SoCs so that the
newly updated dtbTool can find the PMIC compatible string and add
the pmic-id element to the QCDT header.
Add configuration nodes for following devices:
* GPIO block, with 22 pins
* MPP block, with 8 pins
* Volatage ADC (VADC), with multiple inputs
* Thermal sensor device, which is using on chip VADC
channel report PMIC die temperature.
* RTC device
Signed-off-by: Ivan T. Ivanov <ivan.ivanov@linaro.org>
Signed-off-by: Kumar Gala <galak@codeaurora.org>
PMA8084 have 2 SPMI devices per physical package. Add their
configuration nodes and include them in boards which are using
AQP8084 based chipset.
Signed-off-by: Ivan T. Ivanov <iivanov@mm-sol.com>
