SDR50 isn't working anymore because the GPIO regulator
driver is using descriptors since
commit d6cd33ad7102 ("regulator: gpio: Convert to use descriptors")
which in turn causes the system to use the polarity of the
GPIOs (as specified in the DT) for selecting the states,
but the polarity specified in the DT is wrong.
This patch fixes the regulator DT definition, and that fixes
SDR50.
Fixes: 9eb36b945b5c ("ARM: dts: iwg23s-sbc: Add uSD and eMMC support")
Signed-off-by: Fabrizio Castro <fabrizio.castro@bp.renesas.com>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Convert bootargs from ip=dhcp to ip=on
Signed-off-by: Magnus Damm <damm+renesas@opensource.se>
Enable HS-USB device for the iWave SBC based on RZ/G1C.
Signed-off-by: Biju Das <biju.das@bp.renesas.com>
Enable USB2.0 host on the iwg23s sbc.
Enable USB phy[01] on iWave iwg23s sbc based on RZ/G1C SoC.
This patch adds HDMI video output support to the iwg23s board
from iWave. Due to a problem with the bootloader not dealing
with the configuration of one of the pins correctly, we have
to use a gpio-hog for the interrupt line to make sure the pin
is configured as GPIO-input when requesting the interrupt.
Enable NXP pcf85263 real time clock for the iWave SBC based on RZ/G1C.
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
This commit adds QSPI flash support to the iwg23s board specific
device tree.
Adding pinctrl support for EtherAVB interface.
Reviewed-by: Fabrizio Castro <fabrizio.castro@bp.renesas.com>
This patch enables cmt0 support on the iWave iwg23s sbc.
This patch enables watchdog support on the iWave iwg23s sbc.
Add uSD card and eMMC support to the iwg23s single board
computer powered by the RZ/G1C SoC (a.k.a. r8a77470).
Reviewed-by: Biju Das <biju.das@bp.renesas.com>
Specify EtherAVB PHY IRQ in the board specific device tree, now that we
have GPIO support.
Adding pinctrl support for scif1 interface.
Reviewed-by: Chris Paterson <chris.paterson2@renesas.com>
Define the iW-RainboW-G23S board dependent part of the
EtherAVB device node.
Add support for iWave iW-RainboW-G23S single board computer based on
RZ/G1C.
