Add the serial port config to "chosen/stdout-path", which requires
referring to the port by alias.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Name the Pin Function Controller subnodes for SCIF2 and SCIF4 after
their device names, instead of using some arbitrary names that look like
serial port aliases, but differ from the actual aliases.
This avoids conflicts when enabling support for more serial ports later,
either here or in a DT overlay.
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
Warning (unit_address_vs_reg): Node /fixedregulator@0 has a unit name, but no reg property
Since 16ccaf5bb5a5 ("pinctrl: sh-pfc: Accept standard function, pins and
groups properties") renesas pfc drivers accept generic "function", "pins"
and "groups" properties.
This patch updates the marzen device tree to use the generic properties.
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Add and enable the external crystal for the SCIF_CLK and its pinctrl, to
be used by the Baud Rate Generator for External Clock (BRG) on (H)SCIF.
This increases the range and accuracy of supported baud rates.
Convert Marzen to use board-specific serial0 and serial1 instead
of the older shared SoC-specific SCIF index.
Signed-off-by: Magnus Damm <damm+renesas@opensource.se>
Acked-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
lan0 -> ethernet
Declare the fixed 65MHz pixel clock connected to the DU clock input.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into next/cleanup
Pull "Renesas ARM Based SoC DT Cleanups for v3.19" from Simon Horman:
* Add chosen/stdout-path to DTS files for shmobile boards
* Remove r7s72100-genmai.dtb for ARCH_SHMOBILE_LEGACY
- The corresponding board file has already been removed
* Sort dts nodes by address
* Sort SHMOBILE dtbs alphabetically in Makefile
* tag 'renesas-dt-cleanups-for-v3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas:
ARM: shmobile: kzm9d dts: Add chosen/stdout-path
ARM: shmobile: kzm9g-reference dts: Add chosen/stdout-path
ARM: shmobile: alt dts: Add chosen/stdout-path
ARM: shmobile: koelsch dts: Add chosen/stdout-path
ARM: shmobile: henninger dts: Add chosen/stdout-path
ARM: shmobile: lager dts: Add chosen/stdout-path
ARM: shmobile: marzen dts: Add chosen/stdout-path
ARM: shmobile: bockw-reference dts: Add chosen/stdout-path
ARM: shmobile: armadillo800eva dts: Add chosen/stdout-path
ARM: shmobile: ape6evm-reference dts: Add chosen/stdout-path
ARM: shmobile: genmai dts: Add chosen/stdout-path
ARM: shmobile: emev2 dtsi: Add uart* labels for easier referencing
ARM: shmobile: emev2 dtsi: Use generic names for device nodes
ARM: shmobile: r7s72100: Remove r7s72100-genmai.dtb for ARCH_SHMOBILE_LEGACY
ARM: shmobile: r8a73a4: sort dtsi file by address
ARM: shmobile: kzm9d: sort dts file by address
ARM: shmobile: r7s72100: sort dtsi file by address
ARM: shmobile: r8a73a4: Remove spurious dma-multiplexer base addresses
ARM: dts: Sort SHMOBILE dtbs alphabetically
Specify the DU output topology, enable the DU device and configure the
related pins.
Add a stdout-path property so that automatic console selection works
in the absence of a "console=" parameter on the kernel command line.
Note that we have to keep the "console=" parameter in chosen/bootargs,
as this DTS is shared between legacy and multi-platform.
No more device needs to be added from platform code when booting the
reference platform, remove the now empty
r8a7779_add_standard_devices_dt() function completely.
Tested-by: Simon Horman <horms+renesas@verge.net.au>
Unify white space usage by consistently using tabs for indentation.
Initialise SCIF devices using DT when booting marzen
using multiplatform.
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
As early printk support is not enabled in the kernel in the
shmobile defconfig it does not make much sense to provide for
it in the default command line.
The external crystal frequency is 31.25 on the Marzen board.
Specify it in the device tree.
Based on work for the Lager board by Laurent Pinchart.
Copy the device nodes from Marzen reference into the Marzen device tree
file. This will allow us to use a single DTS file regardless of kernel
configuration. In case of legacy C board code the device nodes may or
may not be used, but in the multiplatform case all the DT device nodes
will be used.
Based on a similar change for the Lager board by Laurent Pinchart.
In order to allow usage of the preprocessor in the SoC device tree
sources, switch from /include/ to #include.
This is in preparation for converting the marzen board to
use DT_MACHINE_START.
Acked-by: Magnus Damm <damm@opensource.se>
