Pull ARM SoC late DT updates from Arnd Bergmann:
"This is a collection of a few late fixes and other misc stuff that had
dependencies on things being merged from other trees.
The Renesas R-Car power domain handling, and the Nvidia Tegra USB
support both hand notable changes that required changing the DT
binding in a way that only provides compatibility with old DT blobs on
new kernels but not vice versa. As a consequence, the DT changes are
based on top of the driver changes and are now in this branch.
For NXP i.MX and Samsung Exynos, the changes in here depend on other
changes that got merged through the clk maintainer tree"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (35 commits)
ARM: dts: exynos: Add support of Bus frequency using VDD_INT for exynos5422-odroidxu3
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos542x SoC
ARM: dts: exynos: Add NoC Probe dt node for Exynos542x SoC
ARM: dts: exynos: Add support of bus frequency for exynos4412-trats/odroidu3
ARM: dts: exynos: Expand the voltage range of buck1/3 regulator for exynos4412-odroidu3
ARM: dts: exynos: Add support of bus frequency using VDD_INT for exynos3250-rinato
ARM: dts: exynos: Add exynos4412-ppmu-common dtsi to delete duplicate PPMU nodes
ARM: dts: exynos: Add bus nodes using VDD_MIF for Exynos4210
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos4x12
ARM: dts: exynos: Add bus nodes using VDD_MIF for Exynos4x12
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos3250
ARM: dts: exynos: Add DMC bus frequency for exynos3250-rinato/monk
ARM: dts: exynos: Add DMC bus node for Exynos3250
ARM: tegra: Enable XUSB on Nyan
ARM: tegra: Enable XUSB on Jetson TK1
ARM: tegra: Enable XUSB on Venice2
ARM: tegra: Add Tegra124 XUSB controller
ARM: tegra: Move Tegra124 to the new XUSB pad controller binding
ARM: dts: r8a7794: Use SYSC "always-on" PM Domain
ARM: dts: r8a7793: Use SYSC "always-on" PM Domain
Hook up all devices that are part of the CPG/MSTP Clock Domain to the
SYSC "always-on" PM Domain, for a more consistent device-power-area
description in DT.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Add a device node for the System Controller.
Hook up ARM CPU cores 1-3 to their respective PM Domains.
Note that ARM CPU core 0 cannot be shut off.
clk_get() on a disabled clock node will return -EPROBE_DEFER, which can
cause drivers to be deferred forever if such clocks are referenced in
their devices' clocks properties.
Update the various disabled external clock nodes to default to a
frequency of 0, but don't disable them, to prevent this.
The ARM TWD interrupt is a private peripheral interrupt (PPI), and per
the ARM GIC documentation, whether the type for PPIs can be set is
IMPLEMENTATION DEFINED.
For R-Car H1 devices the PPI type cannot be set, and so when we attempt
to set the type for the ARM TWD interrupt it fails. This has gone
unnoticed because it fails silently, and because we cannot re-configure
the type it has had no impact. Nevertheless fix the type for the TWD
interrupt so that it matches the hardware configuration.
Based on patches by Jon Hunter for Tegra20/30 and OMAP4.
* Fixed rate and fixed factor clocks do not require an
clock-output-names property.
* Since 07705583e920fef6 ("clk: shmobile: div6: Make clock-output-names
optional") Renesas div6 clocks do not require a clock-output-names
property.
In the above cases there is only one clock output and its name is taken
from that of the clock node. Accordingly, remove the unnecessary
clock-output-names properties and as necessary update the node names.
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
Add the device node for the external SCIF_CLK.
The presence of the SCIF_CLK crystal and its clock frequency depends on
the actual board.
Add the two optional clock sources (S1 and SCIF_CLK for the internal
resp. external clock) for the Baud Rate Generator for External Clock
(BRG) to all SCIF device nodes.
This increases the range and accuracy of supported baud rates on SCIF.
The clock is really the device functional clock, not the interface
clock. Rename it.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Use GIC_* defines for GIC interrupt cells in r8a7779 device tree.
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Add an appropriate "#power-domain-cells" property to the cpg_clocks
device node, to create the CPG/MSTP Clock Domain.
Add "power-domains" properties to all device nodes for devices that are
part of the CPG/MSTP Clock Domain and can be power-managed through an
MSTP clock. This applies to most on-SoC devices, which have a
one-to-one mapping from SoC device to DT device node.
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Adjust the r8a7779 SoC DTS and the Marzen Reference
C board code to use DTS only for INTC-IRQPIN IRLM setup.
Signed-off-by: Magnus Damm <damm+renesas@opensource.se>
irqpin -> interrupt-controller
Now when r8a7779 CCF is in place we can hook up
the ARM Cortex-A9 TWD timer via DTS.
Hook up MSTP clocks to SCIF devices on r8a7779 to allow
clock gating to work as expected.
Use R8A7779_CLK_P as parent clock for SCIF devices on r8a7779.
With this change in place the SCIF CCF handling matches the
legacy clock code. Also, this matches the data sheet.
With the addition of clock-indices in commit 8e33f91a0b84ae19 ("clk:
shmobile: clk-mstp: change to using clock-indices"), we can change the
DTSes to use the generic property instead of the deprecated
vendor-specific property.
Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Acked-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into next/dt
Pull "Second Round of Renesas ARM Based SoC DT Cleanups for v3.19" from Simon Horman:
* Drop console= bootargs parameter on alt
* Correct scifb* naming on r8a73a4
* Drop 0x unit-address prefixes
* Remove unnecessary MMC options
* tag 'renesas-dt-cleanups2-for-v3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas:
ARM: shmobile: alt dts: Drop console= bootargs parameter
ARM: shmobile: r8a73a4: fix scifb* naming
ARM: shmobile: kzm9g-reference dts: Drop bogus 0x unit-address prefix
ARM: shmobile: r8a7791 dtsi: Drop bogus 0x unit-address prefix
ARM: shmobile: r8a7790 dtsi: Drop bogus 0x unit-address prefix
ARM: shmobile: r8a7790 dtsi: Remove unnecessary MMC options
ARM: shmobile: r8a7779 dtsi: Remove unnecessary MMC options
ARM: shmobile: r8a7778 dtsi: Remove unnecessary MMC options
As of commit 81bbbc7278fa109f ("mmc: sdhi: update sh_mobile_sdhi_of_data
for r8a7779"), the driver takes care of r8a7779 specific MMC options.
Hence they can be removed from the dtsi.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
[geert: Rebased, reworded, added reference]
The SATA node used the generic compatible property only, which was
deprecated by commit e67adb4e669db834 ("sata_rcar: Add R-Car Gen2 SATA
PHY support"). Add the SoC-specific one introduced by that commit.
Add the DU device with a disabled state. Boards that want to enable the
DU need to specify the output topology
[horms+renesas@verge.net.au: resolved minor conflict]
Pull ARM SoC DT updates from Arnd Bergmann:
"As usual, this is the largest branch, though this time a little under
half of the total changes with 307 individual non-merge changesets.
The largest changes are the addition of new machines, in particular
the Tegra based Chromebook, the Renesas r8a7794 SoC, and DT support
for the old i.MX1 platform.
Other changes include
- at91: various sam9 and sama5 updates
- exynos: much extended Peach Pi/Pit (Chromebook 2) support
- keystone: new peripherals
- meson: added DT for meson6 SoC
- mvebu: new device support for Armada 370/375
- qcom: improved support for IPQ8064 and MSM8x60
- rockchip: much improved support for rk3288
- shmobile: lots of updates all over the place
- sunxi: dts license change
- sunxi: more a23 device support
- vexpress: CLCD DT description"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (308 commits)
ARM: DTS: meson: update DTSI to add watchdog node
ARM: dts: keystone-k2l: fix mdio io start address
ARM: dts: keystone-k2e: fix mdio io start address
ARM: dts: keystone-k2e: update usb1 node for dma properties
ARM: dts: keystone: fix io range for usb_phy0
Revert "Merge tag 'hix5hd2-dt-for-3.18' of git://github.com/hisilicon/linux-hisi into next/dt"
Revert "ARM: dts: hix5hd2: add wdg node"
ARM: dts: add rk3288 i2s controller
ARM: vexpress: Add CLCD Device Tree properties
ARM: bcm2835: add I2S pinctrl to device tree
ARM: meson: documentation: add bindings documentation
ARM: meson: dts: add basic Meson/Meson6/Meson6-atv1200 DTSI/DTS
ARM: dts: mt6589: Change compatible string for GIC
ARM: dts: mediatek: Add compatible property for aquaris5
ARM: dts: mt6589-aquaris5: Add boot argument earlyprintk
ARM: dts: mt6589: Fix typo in GIC unit address
ARM: dts: Build dtb for Mediatek board
ARM: dts: keystone: fix bindings for pcie and usb clock nodes
ARM: dts: keystone: k2l: Fix chip selects for SPI devices
ARM: dts: keystone: add dsp gpio controllers nodes
In general Renesas hardware is not documented to the extent
where the relationship between IP blocks on different SoCs can be assumed
although they may appear to operate the same way. Furthermore the
documentation typically does not specify a version for individual
IP blocks. For these reasons a convention of using the SoC name in place
of a version and providing SoC-specific compat strings has been adopted.
Although not universally liked this convention is used in the bindings for
a number of drivers for Renesas hardware. The purpose of this patch is to
make use of the SoC-specific CMT compat string for the r8a7779 TMU
clock source.
Checkpatch says:
ERROR: code indent should use tabs where possible
The thermal node used the generic compatible property only.
Add the SoC-specific one, to make it future proof.
There's already an "interrupt-parent = <&gic>;" at the top, which is
inherited by all child nodes, so the "interrupt-parent" properties in
the serial nodes can be removed.
Acked-by: Magnus Damm <damm+renesas@opensource.se>
Add the TMU0, TMU1 and TMU2 counters to the r8a7779 device tree and make
them disabled by default.
Tested-by: Simon Horman <horms+renesas@verge.net.au>
Pull ARM SoC device-tree changes from Olof Johansson:
"Unlike the board branch, this keeps having large sets of changes for
every release, but that's quite expected and is so far working well.
Most of this is plumbing for various device bindings and new
platforms, but there's also a bit of cleanup and code removal for
things that are moved from platform code to DT contents (some OMAP
clock code in particular).
There's also a pinctrl driver for tegra here (appropriately acked),
that's introduced this way to make it more bisectable.
I'm happy to say that there were no conflicts at all with this branch
this release, which means that changes are flowing through our tree as
expected instead of merged through driver maintainers (or at least not
done with conflicts).
There are several new boards added, and a couple of SoCs. In no
particular order:
- Rockchip RK3288 SoC support, including DTS for a dev board that
they have seeded with some community developers.
- Better support for Hardkernel Exynos4-based ODROID boards.
- CCF conversions (and dtsi contents) for several Renesas platforms.
- Gumstix Pepper (TI AM335x) board support
- TI eval board support for AM437x
- Allwinner A23 SoC, very similar to existing ones which mostly has
resulted in DT changes for support. Also includes support for an
Ippo tablet with the chipset.
- Allwinner A31 Hummingbird board support, not to be confused with
the SolidRun i.MX-based Hummingboard.
- Tegra30 Apalis board support"
* tag 'dt-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (334 commits)
ARM: dts: Enable USB host0 (EHCI) on rk3288-evb
ARM: dts: add rk3288 ehci usb devices
ARM: dts: Turn on USB host vbus on rk3288-evb
ARM: tegra: apalis t30: fix device tree compatible node
ARM: tegra: paz00: Fix some indentation inconsistencies
ARM: zynq: DT: Clarify Xilinx Zynq platform
ARM: dts: rockchip: add watchdog node
ARM: dts: rockchip: remove pinctrl setting from radxarock uart2
ARM: dts: Add missing pinctrl for uart0/1 for exynos3250
ARM: dts: Remove duplicate 'interrput-parent' property for exynos3250
ARM: dts: Add TMU dt node to monitor the temperature for exynos3250
ARM: dts: Specify MAX77686 pmic interrupt for exynos5250-smdk5250
ARM: dts: cypress,cyapa trackpad is exynos5250-Snow only
ARM: dts: max77686 is exynos5250-snow only
ARM: zynq: DT: Remove DMA from board DTs
ARM: zynq: DT: Add CAN node
ARM: EXYNOS: Add exynos5260 PMU compatible string to DT match table
ARM: dts: Add PMU DT node for exynos5260 SoC
ARM: EXYNOS: Add support for Exynos5410 PMU
ARM: dts: Add PMU to exynos5410
Unify white space usage by consistently using tabs for indentation.
Warning (ranges_format): /clocks has empty "ranges" property but its #address-cells (2) differs from / (1)
Warning (ranges_format): /clocks has empty "ranges" property but its #size-cells (2) differs from / (1)
As r8a7779 doesn't support LPAE, change #address-cells and #size-cells from
"<2>" to "<1>", and update the affected "reg" properties to fix this.
- Correct the unit-address for the "cpg_clocks" node,
- Add missing unit-addresses for the "mstp*_clks" nodes,
- Rename "cpg_clocks" and "mstp*_clks" nodes to the more generic
"clocks".
Add 1GHz to the r8a7779 DTS to describe the maximum CPU frequency.
Based on work by Magnus dam for the r8a7740 SoC.
Cc: Magnus Damm <damm+renesas@opensource.se>
Reference clocks using a "clocks" property in all nodes corresponding to
devices that require a clock.
Based on work by Laurent Pinchart for the r8a7790 and r8a7791 SoC.
Declare all core and MSTP clocks currently used by r8a7779-based boards.
Based on work by Laurent Pinchart for the r8a7790 and r8a7791 SoCs.
There's no need to duplicate the interrupt-parent property in all DT
nodes as the kernel automatically walks parent nodes to find the
property. Specify it once in the root node only.
- Add "renesas,hspi-r8a7779" compatible value,
- Correct reference to parent interrupt controller
(use "interrupt-parent" instead of "interrupt-controller"),
- Add missing "#address-cells" and "#size-cells" properties, which are
needed when populating the SPI buses.
Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org>
Tested-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Based on work for the r8a7778 SoC by Kuninori Morimoto.
Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Add "renesas,intc-irqpin-r8a7779" to the compatible string for the
IRQ pins in case of r8a7779 INTC. This makes the INTC irqpin follow
the same style as the other devices and also makes it more future proof.
Signed-off-by: Magnus Damm <damm@opensource.se>
According to ePAPR spec,
this patch tidies up DT node name and related clock.
10e8d4f6dddb0f9dc408c2f2bde8399b243a42ca
(ARM: mach-shmobile: r8a7779: Minimal setup using DT)
added I2C driver, but it was SH-Mobile I2C.
R-Car H1 needs R-Car I2C driver.
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt
From Tony Lindgren:
Changes needed to prepare for making omap3 device tree only:
- Always build in board-generic, and add pdata quirks and auxdata
support for it so we have all the pdata related quirks
in the same place.
- Merge of the drivers/pinctrl changes that are needed for PM
to continue working on omap3 and also needed for other omaps
eventually. The three pinctrl related patches have been acked
by Linus Walleij and are pulled into both the pinctrl tree
and this branch.
- Few defconfig related changes for drivers needed.
* tag 'omap-for-v3.13/quirk-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (523 commits)
ARM: configs: omap2plus_defconfig: enable dwc3 and dependencies
ARM: OMAP2+: Add WLAN modules and of_serial to omap2plus_defconfig
ARM: OMAP2+: Run make savedefconfig on omap2plus_defconfig to shrink it
ARM: OMAP2+: Add minimal 8250 support for GPMC
ARM: OMAP2+: Use pdata quirks for wl12xx for omap3 evm and zoom3
ARM: OMAP: Move DT wake-up event handling over to use pinctrl-single-omap
ARM: OMAP2+: Add support for auxdata
pinctrl: single: Add support for auxdata
pinctrl: single: Add support for wake-up interrupts
pinctrl: single: Prepare for supporting SoC specific features
ARM: OMAP2+: igep0020: use display init from dss-common
ARM: OMAP2+: pdata-quirks: add legacy display init for IGEPv2 board
+Linux 3.12-rc4
Signed-off-by: Kevin Hilman <khilman@linaro.org>
r8a7779 INTC needs IRL pin mode settings to determine
behavior of IRQ0 - IRQ3. But it depends on platform.
This patch adds status = "disabled" on r8a7779.dtsi as default
Currently all I2C interfaces in all *.dtsi files for various Renesas SoCs
are enabled by default. Switch them all off and only enable populated I2C
interfaces in board-specific *.dts files.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski+renesas@gmail.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
This property is no longer required by the GPIO binding. Remove it.
Pull ARM Renesas SoC cleanup, refactoring and more SMP support from Kevin Hilman:
"Lots of cleanup and refactoring and some SMP additions for Renesas
platforms. Due to some inter-dependencies with other arm-soc
branches, this Renesas stuff was separated out for sending after the
other branches were merged.
Highlights:
- remove unused board support and cleanup of unused headers
- refactoring of init and device registration
- simplify IRQ initialization"
* tag 'renesas-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (68 commits)
ARM: shmobile: Per-CPU SMP boot / sleep code for SCU SoCs
ARM: shmobile: Introduce per-CPU SMP boot / sleep code
ARM: shmobile: Use shared SCU CPU Hotplug code on r8a7779
ARM: shmobile: Use shared SCU CPU Hotplug code on sh73a0
ARM: shmobile: Add shared SCU CPU Hotplug code
ARM: shmobile: Use shared SCU SMP boot code on emev2
ARM: shmobile: Use shared SCU SMP boot code on r8a7779
ARM: shmobile: Use shared SCU SMP boot code on sh73a0
ARM: shmobile: Introduce shared SCU SMP boot code
ARM: shmobile: sh73a0: Remove global GPIO_NR definition
ARM: shmobile: kzm9d: remove nfsroot settings from bootargs
ARM: shmobile: armadillo800eva: remove nfsroot settings from bootargs
ARM: shmobile: r8a7779: move r8a7779_init_irq_xxx() to setup
ARM: shmobile: r8a7740: move r8a7740_init_irq_of() to setup
ARM: shmobile: bockw: add missing __initdata
ARM: shmobile: r8a7790: add missing __initdata
ARM: shmobile: r8a7779: add missing __initdata
ARM: shmobile: Remove unused shmobile_init_time()
ARM: shmobile: Use clocksource_of_init() on r8a7790
ARM: shmobile: Use default ->init_time() on KZM9G DT ref
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Add GPIO controller nodes to the r8a7779 core device tree.
