path: root/arch/arm/boot/dts/r8a7791.dtsi
2018-11-23ARM: dts: r8a7791: Correct critical CPU temperatureChris Paterson
commit e4fdf59bcce3b490bbc7197145bcb9f9d5a18cd3 upstream. The R-Car M2W hardware manual states that Tc = –40°C to +105°C. The thermal sensor has an accuracy of ±5°C and there can be a temperature difference of 1 or 2 degrees between Tjmax and the thermal sensor due to the location of the latter. This means that 95°C is a safer value to use. Fixes: cac68a56e34b9810 ("ARM: dts: r8a7791: enable to use thermal-zone") Signed-off-by: Chris Paterson <chris.paterson2@renesas.com> Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-17ARM: dts: r8a7791: Use R-Car SATA Gen2 fallback compat stringSimon Horman
Use newly added R-Car SATA Gen2 fallback compat string in the DT of the r8a7791 SoC. This should have no run-time effect as the driver matches against the per-SoC compat string before the fallback compat string is considered. Signed-off-by: Simon Horman <horms+renesas@verge.net.au> Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
2017-07-27ARM: dts: r8a7791: Use R-Car Gen 2 fallback binding for vin nodesSimon Horman
Use R-Car Gen 2 fallback binding for vind nodes in DT for r8a7791 SoC. This has no run-time effect for the current driver as the initialisation sequence is the same for the SoC-specific binding for r8a7791 and the fallback binding for R-Car Gen 2 Signed-off-by: Simon Horman <horms+renesas@verge.net.au> Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
2017-07-27ARM: dts: r8a7791: Reserve SRAM for the SMP jump stubGeert Uytterhoeven
Reserve SRAM for the jump stub for CPU core bringup. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2017-07-27ARM: dts: r8a7791: Add Inter Connect RAMGeert Uytterhoeven
R-Car M2-W has 2 regions of Inter Connect RAM (72 + 4 KiB). Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2017-06-12ARM: dts: r8a779x: Fix PCI bus dtc warningsRob Herring
The bogus 'device_type = "pci"' confuses dtc, causing lots of totally unrelated warnings. After fixing that, real warnings like arch/arm/boot/dts/r8a7790-lager.dtb: Warning (pci_device_reg): Node /pci@ee090000/usb@0,1 PCI unit address format error, expected "1,0" are left. Correct the unit-addresses and reg properties of the subnodes to fix these. Signed-off-by: Rob Herring <robh@kernel.org> [geert: Improve description] Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2017-05-15ARM: dts: r8a7791: Add GyroADC clock and device nodeMarek Vasut
Add node for the GyroADC block and it's associated clock. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2017-05-15ARM: dts: r8a7791: update PFC node name to pin-controllerSimon Horman
The device trees for Renesas SoCs use either pfc or pin-controller as the node name for the PFC device. This patch is intended to take a step towards unifying the node name used as pin-controller which appears to be the more generic of the two and thus more in keeping with the DT specs. My analysis is that this is a user-visible change to the extent that kernel logs, and sysfs entries change from e6060000.pfc and pfc@e6060000 to e6060000.pin-controller and pin-controller@e6060000. Signed-off-by: Simon Horman <horms+renesas@verge.net.au> Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
2017-04-05ARM: dts: r8a7791: Drop _clk suffix from external CAN clock node nameGeert Uytterhoeven
The current practice is to not add _clk suffixes to clock node names in DT, as these names are used as the actual clock names. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Acked-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2017-04-03ARM: dts: r8a7791: Correct parent of SSI[0-9] clocksGeert Uytterhoeven
The SSI-ALL gate clock is located in between the P clock and the individual SSI[0-9] clocks, hence the former should be listed as their parent. Fixes: ee9141522dcf13f8 ("ARM: shmobile: r8a7791: add MSTP10 support on DTSI") Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2017-03-10ARM: dts: r8a7791: Tidyup Audio-DMAC channel for DVCKuninori Morimoto
Current Audio-DMAC is assigned "rx" as Audio-DMAC0, "tx" as Audio-DMAC1. Thus, DVC "tx" should be assigned as Audio-DMAC1, instead of Audio-DMAC0. Because of this, current platform board (using SRC/DVC/SSI) Playback/Capture both will use same Audio-DMAC0 (but it depends on audio data path). First note is that this "rx" and "tx" are from each IP point, it doesn't mean Playback/Capture. Second note is that Audio DMAC assigned on DT is only for Audio-DMAC, Audio-DMAC-peri-peri has no entry. => Audio-DMAC -> Audio-DMAC-peri-peri -- HW connection Playback case [Mem] => [SRC]--[DVC] -> [SSI]--[Codec] rx ~~~~~~~~~~~~ Capture [Mem] <= [DVC]--[SRC] <- [SSI]--[Codec] tx ~~~~~~~~~~~~ Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2017-03-10ARM: dts: r8a7791: Add INTC-SYS clock to device treeGeert Uytterhoeven
Link the ARM GIC to the INTC-SYS module clock, and add it to the "always on" PM Domain, so it can be power managed using that clock. Note that currently the GIC-400 driver doesn't support module clocks nor Runtime PM, so this must be handled as a critical clock. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2017-03-07ARM: dts: r8a7791: Remove unit-address and reg from integrated cacheGeert Uytterhoeven
The Cortex-A15 cache controller is an integrated controller, and thus the device node representing it should not have a unit-addresses or reg property. Fixes: 6f9314ce258c8504 ("ARM: dts: r8a7791: Fix W=1 dtc warnings") Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2017-02-07ARM: DTS: Fix register map for virt-capable GICMarc Zyngier
Since everybody copied my own mistake from the DT binding example, let's address all the offenders in one swift go. Most of them got the CPU interface size wrong (4kB, while it should be 8kB), except for both keystone platforms which got the control interface wrong (4kB instead of 8kB). In a few cases where I knew for sure what implementation was used, I've added the "arm,gic-400" compatible string. I'm 99% sure that this is what everyone is using, but short of having the TRM for all the other SoCs, I've left them alone. Acked-by: Shawn Guo <shawnguo@kernel.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Santosh Shilimkar <ssantosh@kernel.org> Acked-by: Krzysztof Kozlowski <krzk@kernel.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Matthias Brugger <matthias.bgg@gmail.com> Acked-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2017-01-03ARM: dts: r8a7791: Use R-Car Gen 2 fallback binding for msiof nodesSimon Horman
Use recently added R-Car Gen 2 fallback binding for msiof nodes in DT for r8a7791 SoC. This has no run-time effect for the current driver as the initialisation sequence is the same for the SoC-specific binding for r8a7791 and the fallback binding for R-Car Gen 2. Signed-off-by: Simon Horman <horms+renesas@verge.net.au> Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
2017-01-03ARM: dts: r8a7791: Use R-Car Gen 2 fallback binding for iic nodesSimon Horman
Use recently added R-Car Gen 2 fallback binding for iic nodes in DT for r8a7791 SoC. This has no run-time effect for the current driver as the initialisation sequence is the same for the SoC-specific binding for r8a7791 and the fallback binding for R-Car Gen 2. Signed-off-by: Simon Horman <horms+renesas@verge.net.au> Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2017-01-03ARM: dts: r8a7791: Use R-Car Gen 2 fallback binding for i2c nodesSimon Horman
Use recently added R-Car Gen 2 fallback binding for i2c nodes in DT for r8a7791 SoC. This has no run-time effect for the current driver as the initialisation sequence is the same for the SoC-specific binding for r8a7791 and the fallback binding for R-Car Gen 2. Signed-off-by: Simon Horman <horms+renesas@verge.net.au> Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
2017-01-03ARM: dts: r8a7791: Use renesas,rcar-gen2-usb-phy fallback bindingSimon Horman
A fallback binding for the Renesas R-Car Gen2 PHY driver was added by commit 7777cb8ba08d ("phy: rcar-gen2: add fallback binding"). This patch makes use of this binding in the DT for the r8a7791 SoC. Signed-off-by: Simon Horman <horms+renesas@verge.net.au> Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
2016-12-15Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM DT updates from Arnd Bergmann: "Lots of changes as usual, so I'm trying to be brief here. Most of the new hardware support has the respective driver changes merged through other trees or has had it available for a while, so this is where things come together. We get a DT descriptions for a couple of new SoCs, all of them variants of other chips we already support, and usually coming with a new evaluation board: - Oxford semiconductor (now Broadcom) OX820 SoC for NAS devices - Qualcomm MDM9615 LTE baseband - NXP imx6ull, the latest and smallest i.MX6 application processor variant - Renesas RZ/G (r8a7743 and r8a7745) application processors - Rockchip PX3, a variant of the rk3188 chip used in Android tablets - Rockchip rk1108 single-core application processor - ST stm32f746 Cortex-M7 based microcontroller - TI DRA71x automotive processors These are commercially available consumer platforms we now support: - Motorola Droid 4 (xt894) mobile phone - Rikomagic MK808 Android TV stick based on Rockchips rx3066 - Cloud Engines PogoPlug v3 based on OX820 - Various Broadcom based wireless devices: - Netgear R8500 router - Tenda AC9 router - TP-LINK Archer C9 V1 - Luxul XAP-1510 Access point - Turris Omnia open hardware router based on Armada 385 And a couple of new boards targeted at developers, makers or industrial integration: - Macnica Sodia development platform for Altera socfpga (Cyclone V) - MicroZed board based on Xilinx Zynq FPGA platforms - TOPEET itop/elite based on exynos4412 - WP8548 MangOH Open Hardware platform for IOT, based on Qualcomm MDM9615 - NextThing CHIP Pro gadget - NanoPi M1 development board - AM571x-IDK industrial board based on TI AM5718 - i.MX6SX UDOO Neo - Boundary Devices Nitrogen6_SOM2 (i.MX6) - Engicam i.CoreM6 - Grinn i.MX6UL liteSOM/liteBoard - Toradex Colibri iMX6 module Other changes: - added peripherals on renesas, davinci, stm32f429, uniphier, sti, mediatek, integrator, at91, imx, vybrid, ls1021a, omap, qualcomm, mvebu, allwinner, broadcom, exynos, zynq - Continued fixes for W=1 dtc warnings - The old STiH415/416 SoC support gets removed, these never made it into products and have served their purpose in the kernel as a template for teh newer chips from ST - The exynos4415 dtsi file is removed as nothing uses it. - Intel PXA25x can now be booted using devicetree" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (422 commits) arm: dts: zynq: Add MicroZed board support ARM: dts: da850: enable high speed for mmc ARM: dts: da850: Add node for pullup/pulldown pinconf ARM: dts: da850: enable memctrl and mstpri nodes per board ARM: dts: da850-lcdk: Add ethernet0 alias to DT ARM: dts: artpec: add pcie support ARM: dts: add support for Turris Omnia devicetree: Add vendor prefix for CZ.NIC ARM: dts: berlin2q-marvell-dmp: fix typo in chosen node ARM: dts: berlin2q-marvell-dmp: fix regulators' name ARM: dts: Add xo to sdhc clock node on qcom platforms ARM: dts: r8a7794: Add device node for PRR ARM: dts: r8a7793: Add device node for PRR ARM: dts: r8a7792: Add device node for PRR ARM: dts: r8a7791: Add device node for PRR ARM: dts: r8a7790: Add device node for PRR ARM: dts: r8a7779: Add device node for PRR ARM: dts: r8a73a4: Add device node for PRR ARM: dts: sk-rzg1e: add Ether support ARM: dts: sk-rzg1e: initial device tree ...
2016-11-23ARM: dts: r8a7791: Add device node for PRRGeert Uytterhoeven
Add a device node for the Product Register, which provides SoC product and revision information. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-11-04ARM: dts: r8a7791: Correct SCIFB reg properties to cover all registersGeert Uytterhoeven
Several SCIFB registers reside outside the reported register ranges. Fortunately this works (on Linux), due to the PAGE_SIZE granularity of ioremap(). Extend the sizes from 64 to 0x100 bytes to fix this, like is done on SH/R-Mobile SoCs. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-11-02ARM: dts: r8a7791: Add device node for RST moduleGeert Uytterhoeven
Add a device node for the RST module, which provides a.o. reset control and mode pin monitoring. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
2016-10-17ARM: dts: r8a7791: set maximum frequency for SDHI clocksSimon Horman
Define the upper limit otherwise the driver cannot utilize max speeds. Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-08-17ARM: dts: r8a7791: Remove obsolete vsp1 propertiesGeert Uytterhoeven
As of commit 5aa2eb3c86d4fd16 ("[media] v4l: vsp1: Configure device based on IP version"), the DT properties to identify the exact VSP device instance features are no longer used. Hence remove them. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-06-29ARM: dts: r8a7791: Add APMU nodeMagnus Damm
Add a DT node for the Advanced Power Management Units (APMU), and use the enable-method to point out that the APMU should be used for SMP support. Signed-off-by: Magnus Damm <damm+renesas@opensource.se> Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-05-30ARM: dts: r8a7791: Fix W=1 dtc warningsGeert Uytterhoeven
Warning (unit_address_vs_reg): Node /cache-controller@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,dvc/dvc@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,dvc/dvc@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,mix/mix@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,mix/mix@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@2 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@3 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@4 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@5 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@6 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@7 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@2 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@3 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@4 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@5 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@6 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@7 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@8 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@9 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@2 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@3 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@4 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@5 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@6 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@7 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@8 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@9 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /cache-controller@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,dvc/dvc@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,dvc/dvc@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,mix/mix@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,mix/mix@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@2 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@3 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@4 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@5 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@6 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@7 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@2 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@3 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@4 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@5 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@6 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@7 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@8 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@9 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@2 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@3 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@4 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@5 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@6 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@7 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@8 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@9 has a unit name, but no reg property Move the cache-controller node under the cpus node, and make its unit name and reg property match the MPIDR values. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-05-30ARM: dts: r8a7791: Reference both DMA controllersNiklas Söderlund
R-Car Gen2 have two DMA controllers, which are equivalent. Add references to both dmac0 and dmac1 so the driver can choose which one to use. Signed-off-by: Niklas Söderlund <niklas.soderlund+renesas@ragnatech.se> Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-05-24Merge tag 'armsoc-late' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC late DT updates from Arnd Bergmann: "This is a collection of a few late fixes and other misc stuff that had dependencies on things being merged from other trees. The Renesas R-Car power domain handling, and the Nvidia Tegra USB support both hand notable changes that required changing the DT binding in a way that only provides compatibility with old DT blobs on new kernels but not vice versa. As a consequence, the DT changes are based on top of the driver changes and are now in this branch. For NXP i.MX and Samsung Exynos, the changes in here depend on other changes that got merged through the clk maintainer tree" * tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (35 commits) ARM: dts: exynos: Add support of Bus frequency using VDD_INT for exynos5422-odroidxu3 ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos542x SoC ARM: dts: exynos: Add NoC Probe dt node for Exynos542x SoC ARM: dts: exynos: Add support of bus frequency for exynos4412-trats/odroidu3 ARM: dts: exynos: Expand the voltage range of buck1/3 regulator for exynos4412-odroidu3 ARM: dts: exynos: Add support of bus frequency using VDD_INT for exynos3250-rinato ARM: dts: exynos: Add exynos4412-ppmu-common dtsi to delete duplicate PPMU nodes ARM: dts: exynos: Add bus nodes using VDD_MIF for Exynos4210 ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos4x12 ARM: dts: exynos: Add bus nodes using VDD_MIF for Exynos4x12 ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos3250 ARM: dts: exynos: Add DMC bus frequency for exynos3250-rinato/monk ARM: dts: exynos: Add DMC bus node for Exynos3250 ARM: tegra: Enable XUSB on Nyan ARM: tegra: Enable XUSB on Jetson TK1 ARM: tegra: Enable XUSB on Venice2 ARM: tegra: Add Tegra124 XUSB controller ARM: tegra: Move Tegra124 to the new XUSB pad controller binding ARM: dts: r8a7794: Use SYSC "always-on" PM Domain ARM: dts: r8a7793: Use SYSC "always-on" PM Domain ...
2016-04-27ARM: dts: r8a7791: Use SYSC "always-on" PM DomainGeert Uytterhoeven
Hook up all devices that are part of the CPG/MSTP Clock Domain to the SYSC "always-on" PM Domain, for a more consistent device-power-area description in DT. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-04-27ARM: dts: r8a7791: Add SYSC PM DomainsGeert Uytterhoeven
Add a device node for the System Controller. Hook up the Cortex-A15 CPU cores and the Cortex-A15 L2 cache/SCU to their respective PM Domains. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-04-26Merge tag 'renesas-fixes-for-v4.6' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into next/dt Renesas ARM Based SoC Fixes for v4.6 * Correct preset_lpj calculation which may lead to too short delays * Correct handling of optional clocks on r8a7791 to restore access to the serial port the porter board This is a backmerge of v4.6 fixes, to avoid a merge conflict between 4.6 and our next/dt branch. * tag 'renesas-fixes-for-v4.6' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas: ARM: shmobile: timer: Fix preset_lpj leading to too short delays Revert "ARM: dts: porter: Enable SCIF_CLK frequency and pins" ARM: dts: r8a7791: Don't disable referenced optional clocks
2016-04-20ARM: dts: r8a7791: Use USB3.0 fallback compatibility stringSimon Horman
Use recently added fallback compatibility string in r8a7791 device tree. Signed-off-by: Simon Horman <horms+renesas@verge.net.au> Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
2016-04-20ARM: dts: r8a7791: use fallback can compatibility stringSimon Horman
2016-04-20ARM: dts: r8a7791: use fallback jpu compatibility stringSimon Horman
2016-04-20ARM: dts: r8a7791: Don't disable referenced optional clocksSjoerd Simons
clk_get on a disabled clock node will return EPROBE_DEFER, which can cause drivers to be deferred forever if such clocks are referenced in their clocks property. Update the various disabled external clock nodes to default to a frequency of 0, but don't disable them to prevent this. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-03-28ARM: dts: r8a7791: Remove unnecessary clock-output-names propertiesSimon Horman
* Fixed rate and fixed factor clocks do not require an clock-output-names property. * Since 07705583e920fef6 ("clk: shmobile: div6: Make clock-output-names optional") Renesas div6 clocks do not require a clock-output-names property. In the above cases there is only one clock output and its name is taken from that of the clock node. Accordingly, remove the unnecessary clock-output-names properties and as necessary update the node names. Signed-off-by: Simon Horman <horms+renesas@verge.net.au> Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
2016-02-19ARM: dts: r8a7791: Add L2 cache-controller nodeGeert Uytterhoeven
Add a device node for the L2 cache, and link the CPU nodes to it. The L2 cache for the Cortex-A15 CPU cores is 1 MiB large (organized as 64 KiB x 16 ways). Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-02-16ARM: dts: r8a7791: enable to use thermal-zoneKuninori Morimoto
This patch enables to use thermal-zone on r8a7791. This thermal sensor can measure temperature from -40000 to 125000, but over 117000 can be critical on this chip. Thus, default critical temperature is now set as 115000 (this driver is using 5000 steps) (Current critical temperature is using it as 90000, but there is no big reason about it) And it doesn't check thermal zone periodically (same as current behavior). You can exchange it by modifying polling-delay[-passive] property. You can set trip temp if your kernel has CONFIG_THERMAL_WRITABLE_TRIPS, but you need to take care to use it, since it will call orderly_poweroff() it it reaches to the value. echo $temp > /sys/class/thermal/thermal_zone0/trip_point_0_temp Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-02-15ARM: dts: r8a7791: use fallback pci compatibility stringSimon Horman
2016-02-15ARM: dts: r8a7791: use fallback pcie compatibility stringSimon Horman
2016-02-09ARM: dts: r8a7791: Add BRG support for (H)SCIFGeert Uytterhoeven
Add the device node for the external SCIF_CLK. The presence of the SCIF_CLK crystal and its clock frequency depends on the actual board. Add the two optional clock sources (ZS_CLK and SCIF_CLK for the internal resp. external clock) for the Baud Rate Generator for External Clock (BRG) to all SCIF and HSCIF device nodes. This increases the range and accuracy of supported baud rates on (H)SCIF. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-02-09ARM: dts: r8a7791: Rename the serial port clock to fckLaurent Pinchart
The clock is really the device functional clock, not the interface clock. Rename it. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-02-09ARM: dts: r8a7791: Add SCIF fallback compatibility stringsGeert Uytterhoeven
2016-01-25ARM: dts: r8a7791: use GIC_* definesSimon Horman
Use GIC_* defines for GIC interrupt cells in r8a7791 device tree. Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-01-25ARM: dts: r8a7791: use fallback usbhs compatibility stringSimon Horman
2015-12-17ARM: shmobile: r8a779x: use SoC-specific usb-dmac compatibility stringsSimon Horman
Use recently SoC-specific compatibility strings in r8a779[01] device trees. Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2015-12-15ARM: shmobile: r8a7791: IPMMU compat string SoC part number updateMagnus Damm
Update IPMMU compat strings to include SoC part number. By specifying SoC part number in DT it becomes possible to implement SoC specific features in the IPMMU driver. Signed-off-by: Magnus Damm <damm+renesas@opensource.se> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2015-12-15ARM: shmobile: r8a7791: dtsi: add internal delay for i2c IPsWolfram Sang
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2015-12-07ARM: shmobile: r8a7791: add EtherAVB DT supportSergei Shtylyov
Define the generic R8A7791 part of the EtherAVB device node. Based on the commit f25d6b977240 ("ARM: shmobile: r8a7790: add EtherAVB DT support"). Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2015-12-07ARM: shmobile: r8a7791: add EtherAVB clockSergei Shtylyov
Add the EtherAVB clock to the R8A7791 device tree. Based on the commit 63d2d750c902 ("ARM: shmobile: r8a7790: add EtherAVB clocks"). Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
