This patch adds Audio DMAC (= rcar-dmac) entry for sound
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Audio DMAC peri peri is no longer DMAEngine. it is supported by
sound driver. this patch enable it.
Rensas R-Car sound driver supports reg-names.
Let's use it.
Signed-off-by: Ryo Kataoka <ryo.kataoka.wt@renesas.com>
Signed-off-by: Yoshihiro Kaneko <ykaneko0929@gmail.com>
HSUSB uses hp_clk rather than mp_clk for H/W register access.
Signed-off-by: Kazuya Mizuguchi <kazuya.mizuguchi.ks@renesas.com>
[horms: updated changelog]
r8a7791 SDHI ch0/ch1 has SD_DMACR which is located in 0x324.
This patch updates register size
Add references to the transmit and receive DMA channels in the three
SDHI nodes.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Add the ADSP clocks to the CPG and MSTP5 nodes of the R8A7791 device tree.
Based on the original patch by Konstantin Kozhevnikov
<konstantin.kozhevnikov@cogentembedded.com>.
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Define the generic R8A7791 parts of the CAN0/1 device nodes.
The R-Car CAN controllers can derive the CAN bus clock not only from their
peripheral clock input (clkp1) but also from the other internal clock (clkp2)
and external clock fed on CAN_CLK pin. Describe those clocks in the device
tree, along with the USB_EXTAL clock from which clkp2 is derived.
There appears to have been some inconsistency and confusion here as on
the r8a7790 these clocks are referred to as SD(HI)1 and SD(HI)2 while on
the r8a7791 and r8a7794 they are referred to as SD(HI)2 and SD(HI)3.
Fixes: 59e79895b95892863 ("ARM: shmobile: r8a7791: Add clocks")
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Add the seven IPMMU instances found in the r8a7791 to DT with a disabled
status.
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into next/dt
Merge "Second Round of Renesas ARM Based SoC DT Updates for v3.20" from Simon
Horman:
* Support Renesas memory controllers
* Add SRC interrupt number on r8a779~ and r8a7791 SoCs
* Fix MSTP8 input clocks on r8a7791 SoC
* Add PM domain support to r8a7740
* Add DT bindings for the R-Mobile System Controller
* Use Add sh73a0-specific FSI2 compatible property
* tag 'renesas-dt2-for-v3.20' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas:
PM / Domains: R-Mobile SYSC: Document SH-Mobile AG5 (sh73a0) binding
ARM: shmobile: sh73a0 dtsi: Add memory-controller nodes
ARM: shmobile: r8a7740 dtsi: Add memory-controller node
ARM: shmobile: r8a73a4 dtsi: Add memory-controller nodes
ARM: shmobile: Add DT bindings for Renesas memory controllers
ARM: shmobile: r8a7791: add SRC interrupt number on DTSI
ARM: shmobile: r8a7790: add SRC interrupt number on DTSI
ARM: shmobile: r8a7791: fix MSTP8 input clocks
ARM: shmobile: r8a7740 dtsi: Add PM domain support
PM / Domains: Add DT bindings for the R-Mobile System Controller
ARM: shmobile: sh73a0 dtsi: Add SoC-specific FSI2 compatible property
Merge "Second Round of Renesas ARM Based SoC DT Cleanups for v3.20" from Simon
Horman:
* Tidy up #sound-dai-cells settings
* Drop "renesas,rcar_sound" compatible value
* tag 'renesas-dt-cleanups2-for-v3.20' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas:
ARM: shmobile: r8a7791: tidyup #sound-dai-cells settings
ARM: shmobile: r8a7790: tidyup #sound-dai-cells settings
ARM: shmobile: r8a7791 dtsi: Drop "renesas,rcar_sound" compatible value
ARM: shmobile: r8a7790 dtsi: Drop "renesas,rcar_sound" compatible value
I made a mistake when rebasing Andrey Gusakov's patch adding MLB+ clock to the
R8A7791 device tree, inserting <&hp_clk> into the "clocks" property of the
MSTP8 node at a wrong position, so that the input clocks for MLB+ and IPMMU-SGX
got swapped...
Fixes: 7408d3061d2f ("ARM: shmobile: r8a7791: add MLB+ clock")
Renesas sound driver needs #sound-dai-cells settings, but, this usage
is a little bit confusable. It came from ALSA SoC historical reasons.
The sound DAI naming method is different between Single/Multi DAI in
the ALSA framework, and it is used for sound card matching.
And this #sound-dai-cells has relationship to it.
Current SoC dtsi has #sound-dai-cells = <1> as default settings
(= it is assuming that board/platform has multi DAI), and
board/platform side needs to overwrite it if board/platform was single
DAI. This style is more confusable for users.
This patch removes SoC side default settings, and force to set it by
board/platform side.
The "renesas,rcar_sound" compatible property value was never processed
nor documented.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Add MLB+ clock to R8A7791 device tree.
Signed-off-by: Andrey Gusakov <andrey.gusakov@cogentembedded.com>
[Sergei: rebased, renamed, added changelog]
[horms: resolved conflicts]
R-Car M2-W (r8a7791) contains two Cortex-A15 cores, hence the second
interrupt specifier cell for Private Peripheral Interrupts should use
"GIC_CPU_MASK_SIMPLE(2)".
With the addition of clock-indices in commit 8e33f91a0b84ae19 ("clk:
shmobile: clk-mstp: change to using clock-indices"), we can change the
DTSes to use the generic property instead of the deprecated
vendor-specific property.
Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
[geert: Extracted r8a7791-specific part, rebased, reworded]
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Pull "Second Round of Renesas ARM Based SoC DT Updates for v3.19" from Simon Horman:
* Add labels for LEDs on kzm9g-reference and koelsch
* Add Sound support to r8a7790/lager and r8a7791/koelsch
* Add IIC DMA nodes to r8a7790 and r8a7791
* Use SoC-specific IIC compatible properties on sh73a0 and r8a73a4
* Add SGX, MMP and VSP1 clocks to r8a7794
* Add USBDMAC{0,1} clocks to r8a7790 and r8a7791
* tag 'renesas-dt2-for-v3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas: (29 commits)
ARM: shmobile: r8a7791: add USBDMAC{0,1} clocks to device tree
ARM: shmobile: r8a7790: add USBDMAC{0,1} clocks to device tree
ARM: shmobile: r8a7794: Add MMP and VSP1 clocks to device tree
ARM: shmobile: r8a7794: Add SGX clock to device tree
ARM: shmobile: koelsch: add Volume Ramp usage on comment
ARM: shmobile: lager: add Volume Ramp usage on comment
ARM: shmobile: r8a7791: add DMA nodes for IIC
ARM: shmobile: r8a7790: add DMA nodes for IIC
ARM: shmobile: kzm9g-reference dts: Add labels for the LEDs
ARM: shmobile: koelsch dts: Add labels for the LEDs
ARM: shmobile: sh73a0 dtsi: Add SoC-specific IIC compatible properties
ARM: shmobile: r8a73a4 dtsi: Add SoC-specific IIC compatible properties
ARM: shmobile: koelsch: Sound DMA support via DVC on DTS
ARM: shmobile: koelsch: Sound DMA support via SRC on DTS
ARM: shmobile: koelsch: Sound DMA support via BUSIF on DTS
ARM: shmobile: koelsch: Sound DMA support on DTS
ARM: shmobile: koelsch: Sound PIO support on DTS
ARM: shmobile: koelsch: fixup I2C2 clock frequency
ARM: shmobile: lager: Sound DMA support via DVC on DTS
ARM: shmobile: lager: Sound DMA support via SRC on DTS
Pull "Second Round of Renesas ARM Based SoC DT Cleanups for v3.19" from Simon Horman:
* Drop console= bootargs parameter on alt
* Correct scifb* naming on r8a73a4
* Drop 0x unit-address prefixes
* Remove unnecessary MMC options
* tag 'renesas-dt-cleanups2-for-v3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas:
ARM: shmobile: alt dts: Drop console= bootargs parameter
ARM: shmobile: r8a73a4: fix scifb* naming
ARM: shmobile: kzm9g-reference dts: Drop bogus 0x unit-address prefix
ARM: shmobile: r8a7791 dtsi: Drop bogus 0x unit-address prefix
ARM: shmobile: r8a7790 dtsi: Drop bogus 0x unit-address prefix
ARM: shmobile: r8a7790 dtsi: Remove unnecessary MMC options
ARM: shmobile: r8a7779 dtsi: Remove unnecessary MMC options
ARM: shmobile: r8a7778 dtsi: Remove unnecessary MMC options
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Instantiate the Audio DMAC peri peri controllers
in the r8a7791 device tree.
Instantiate the two Audio DMA controllers in the r8a7791 device tree.
[geert: corrected spelling of audmac1]
Add references to the transmit and receive DMA channels in the MMCIF
node.
Tested-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Add the MMCIF0 device to the r8a7791 device tree.
Define the R8A7791 generic part of the HS-USB device node. It is up to the board
file to enable the device.
[Sergei: fixed summary, added changelog]
Signed-off-by: Yoshifumi Hosoya <yoshifumi.hosoya.wj@renesas.com>
Signed-off-by: Kouei Abe <kouei.abe.cp@renesas.com>
Describe the PCI USB devices that are behind the PCI bridges, adding necessary
links to the USB PHY device.
Define the R8A7791 generic part of the USB PHY device node. It is up to the
board file to enable the device.
Add the DU device with a disabled state. Boards that want to enable the
DU need to specify the output topology
Pull ARM SoC DT updates from Arnd Bergmann:
"As usual, this is the largest branch, though this time a little under
half of the total changes with 307 individual non-merge changesets.
The largest changes are the addition of new machines, in particular
the Tegra based Chromebook, the Renesas r8a7794 SoC, and DT support
for the old i.MX1 platform.
Other changes include
- at91: various sam9 and sama5 updates
- exynos: much extended Peach Pi/Pit (Chromebook 2) support
- keystone: new peripherals
- meson: added DT for meson6 SoC
- mvebu: new device support for Armada 370/375
- qcom: improved support for IPQ8064 and MSM8x60
- rockchip: much improved support for rk3288
- shmobile: lots of updates all over the place
- sunxi: dts license change
- sunxi: more a23 device support
- vexpress: CLCD DT description"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (308 commits)
ARM: DTS: meson: update DTSI to add watchdog node
ARM: dts: keystone-k2l: fix mdio io start address
ARM: dts: keystone-k2e: fix mdio io start address
ARM: dts: keystone-k2e: update usb1 node for dma properties
ARM: dts: keystone: fix io range for usb_phy0
Revert "Merge tag 'hix5hd2-dt-for-3.18' of git://github.com/hisilicon/linux-hisi into next/dt"
Revert "ARM: dts: hix5hd2: add wdg node"
ARM: dts: add rk3288 i2s controller
ARM: vexpress: Add CLCD Device Tree properties
ARM: bcm2835: add I2S pinctrl to device tree
ARM: meson: documentation: add bindings documentation
ARM: meson: dts: add basic Meson/Meson6/Meson6-atv1200 DTSI/DTS
ARM: dts: mt6589: Change compatible string for GIC
ARM: dts: mediatek: Add compatible property for aquaris5
ARM: dts: mt6589-aquaris5: Add boot argument earlyprintk
ARM: dts: mt6589: Fix typo in GIC unit address
ARM: dts: Build dtb for Mediatek board
ARM: dts: keystone: fix bindings for pcie and usb clock nodes
ARM: dts: keystone: k2l: Fix chip selects for SPI devices
ARM: dts: keystone: add dsp gpio controllers nodes
In general Renesas hardware is not documented to the extent
where the relationship between IP blocks on different SoCs can be assumed
although they may appear to operate the same way. Furthermore the
documentation typically does not specify a version for individual
IP blocks. For these reasons a convention of using the SoC name in place
of a version and providing SoC-specific compat strings has been adopted.
Although not universally liked this convention is used in the bindings for
a number of drivers for Renesas hardware. The purpose of this patch is to
make use of the SoC-specific CMT compat string for the r8a7791 48-bit CMT
clock source.
There's already an "interrupt-parent = <&gic>;" at the top, which is
inherited by all child nodes, so the "interrupt-parent" property in
the sound node can be removed.
Acked-by: Magnus Damm <damm+renesas@opensource.se>
Signed-off-by: Mikhail Ulyanov <mikhail.ulyanov@cogentembedded.com>
Add register sets used for access by the DMA engine, and DMA properties to
the MSIOF nodes.
Add a DMA property to the QSPI node
Instantiate the two system DMA controllers in the r8a7791 device tree.
Define the generic R8A7791 parts of the VIN[0-2] device nodes. Add aliases for
Add the CMT0 and CMT1 counters to the r8a7791 device tree and make them
disabled by default.
Tested-by: Simon Horman <horms+renesas@verge.net.au>
Pull ARM SoC device-tree changes from Olof Johansson:
"Unlike the board branch, this keeps having large sets of changes for
every release, but that's quite expected and is so far working well.
Most of this is plumbing for various device bindings and new
platforms, but there's also a bit of cleanup and code removal for
things that are moved from platform code to DT contents (some OMAP
clock code in particular).
There's also a pinctrl driver for tegra here (appropriately acked),
that's introduced this way to make it more bisectable.
I'm happy to say that there were no conflicts at all with this branch
this release, which means that changes are flowing through our tree as
expected instead of merged through driver maintainers (or at least not
done with conflicts).
There are several new boards added, and a couple of SoCs. In no
particular order:
- Rockchip RK3288 SoC support, including DTS for a dev board that
they have seeded with some community developers.
- Better support for Hardkernel Exynos4-based ODROID boards.
- CCF conversions (and dtsi contents) for several Renesas platforms.
- Gumstix Pepper (TI AM335x) board support
- TI eval board support for AM437x
- Allwinner A23 SoC, very similar to existing ones which mostly has
resulted in DT changes for support. Also includes support for an
Ippo tablet with the chipset.
- Allwinner A31 Hummingbird board support, not to be confused with
the SolidRun i.MX-based Hummingboard.
- Tegra30 Apalis board support"
* tag 'dt-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (334 commits)
ARM: dts: Enable USB host0 (EHCI) on rk3288-evb
ARM: dts: add rk3288 ehci usb devices
ARM: dts: Turn on USB host vbus on rk3288-evb
ARM: tegra: apalis t30: fix device tree compatible node
ARM: tegra: paz00: Fix some indentation inconsistencies
ARM: zynq: DT: Clarify Xilinx Zynq platform
ARM: dts: rockchip: add watchdog node
ARM: dts: rockchip: remove pinctrl setting from radxarock uart2
ARM: dts: Add missing pinctrl for uart0/1 for exynos3250
ARM: dts: Remove duplicate 'interrput-parent' property for exynos3250
ARM: dts: Add TMU dt node to monitor the temperature for exynos3250
ARM: dts: Specify MAX77686 pmic interrupt for exynos5250-smdk5250
ARM: dts: cypress,cyapa trackpad is exynos5250-Snow only
ARM: dts: max77686 is exynos5250-snow only
ARM: zynq: DT: Remove DMA from board DTs
ARM: zynq: DT: Add CAN node
ARM: EXYNOS: Add exynos5260 PMU compatible string to DT match table
ARM: dts: Add PMU DT node for exynos5260 SoC
ARM: EXYNOS: Add support for Exynos5410 PMU
ARM: dts: Add PMU to exynos5410
59e79895b95892863617ce630fbda467f2470575
(ARM: shmobile: r8a7791: Add clocks)
added r8a7791 SD clocks when v3.14.
2c60a7df72711fb8b4be1e6aa651ab166a8931bc
(ARM: shmobile: Add SDHI devices for Koelsch DTS)
enabled SD on r8a7791 Koelsch when v3.15.
1299df03d7191ab4356c995dde8b912d3c8922e9
(ARM: shmobile: henninger: add SDHI0/2 DT support)
enable SD on r8a7791 Henninger when v3.16.
But r8a7791 SD clock had wrong address.
This patch fixup it.
[Kuninori Morimoto: tidyup for upstreaming]
Signed-off-by: Shinobu Uehara <shinobu.uehara.xc@renesas.com>
Add device nodes for the R8A7791 internal PCI bridge devices.
[horms+renesas@verge.net.au: minor witespace changes]
