Add support for the general purpose LEDs on the Blanche board.
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Define the Blanche board dependent part of the DU device node.
Add the device nodes for the Analog Devices ADV7511W HDMI transmitter
(connected to DU0) and ADV7123 video DAC (connected to DU1). Add the
necessary subnodes to interconnect DU, HDMI/VDAC devices, and HDMI/VGA
connectors.
Define the Blanche board dependent part of the SDHI0 (connected to the
micro-SD slot) device node along with the necessary voltage regulator.
Add support for the general purpose software switches SW2 and tactile
switches SW24/25 as a virtual keyboard (like it was done with the Lager/
Koelsch boards).
Define the Blanche board dependent part of the CAN0 device node along with
the CAN_CLK crystal.
Add the (previously omitted) pin data for the SMSC LAN89218 Ethernet chip
to the Blanche board's device tree: the chip's IRQ output is connected to
the SoC's IRQ0 pin and its nCS input is connected to the SoC's EX_CS0# pin.
Add the (previously omitted) SCIF0/3 pin data to the Blanche board's
device tree.
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
R8A7792 SoC doesn't have the EtherMAC core, so SMSC LAN89218 Ethernet
chip was used instead on the Blanche board; this chip is compatible with
SMSC LAN9115 for which there's a (device tree aware) driver. Describe
the chip in the Blanche device tree; enable DHCP and NFS root in the
kernel command line for the kernel booting.
Add the initial device tree for the R8A7792 SoC based Blanche board.
The board has 2 debug serial ports: SCIF0 and SCIF3; include support for
them, so that the serial console can work.
