Name the Pin Function Controller subnode for QSPI after its device name,
instead of after the spi interface alias.
This avoids conflicts when enabling support for more spi interfaces later,
either here or in a DT overlay.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Name the Pin Function Controller subnodes for SCIF0 and SCIF1 after
their device names, instead of after the serial port aliases.
This avoids conflicts when enabling support for more serial ports later,
Warning (unit_address_vs_reg): Node /regulator@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /regulator@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /regulator@2 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /regulator@3 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /regulator@4 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /regulator@5 has a unit name, but no reg property
Includes regulator and pin assignments.
Signed-off-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com>
* Fixed rate and fixed factor clocks do not require an
clock-output-names property.
* Since 07705583e920fef6 ("clk: shmobile: div6: Make clock-output-names
optional") Renesas div6 clocks do not require a clock-output-names
property.
In the above cases there is only one clock output and its name is taken
from that of the clock node. Accordingly, remove the unnecessary
clock-output-names properties and as necessary update the node names.
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
Since 16ccaf5bb5a5 ("pinctrl: sh-pfc: Accept standard function, pins and
groups properties") renesas pfc drivers accept generic "function", "pins"
and "groups" properties.
This patch updates the gose device tree to use the generic
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Though the keyboard driver for GPIO buttons(gpio-keys) will continue to
check for/support the legacy "gpio-key,wakeup" boolean property to
enable gpio buttons as wakeup source, "wakeup-source" is the new
standard binding.
This patch replaces the legacy "gpio-key,wakeup" with the unified
"wakeup-source" property in order to avoid any further copy-paste
duplication.
Changelog text from a similar patch by Sudeep Holla.
Acked-by: Sudeep Holla <sudeep.holla@arm.com>
Add and enable the external crystal for the SCIF_CLK and its pinctrl, to
be used by the Baud Rate Generator for External Clock (BRG) on (H)SCIF.
This increases the range and accuracy of supported baud rates.
Enable DMA transfer using DVC in r8a7793/gose device tree.
DMA DMApp
[MEM] -> [SRC] -> [DVC] -> [SSIU] -> [SSI]
DMA DMApp
[MEM] <- [DVC] <- [SRC] <- [SSIU] <- [SSI]
Based on similar work for the r8a7791/koelsch by Kuninori Morimoto.
Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Enable DMA transfer to/from SRC in r8a7793/gose device tree.
DMA DMApp
[MEM] -> [SRC] -> [SSIU] -> [SSI]
DMA DMApp
[MEM] <- [SRC] <- [SSIU] <- [SSI]
Current sound driver is supporting
SSI/SRC random connection.
So, this patch is tring
SSI0 -> SRC2
SSI1 <- SRC3
Based on similar work for the r8a7791/koeslch by Kuninori Morimoto.
Enable DMA transfer to/from SSIU in gose/r8a7791 device tree.
DMA
[MEM] -> [SSIU] -> [SSI]
DMA
[MEM] <- [SSIU] <- [SSI]
Enable DMA transfer to/from SSI in r8a7793/gose device tree.
DMA
[MEM] -> [SSI]
DMA
[MEM] <- [SSI]
Enable sound PIO support in the r8a7793/gose device tree.
This patch adds r8a7793 GOSE HDMI video out support.
The r8a7793 GOSE board is similar to r8a7791 Koelsch. For those
boards an on-board HDMI encoder chip provides HDMI video out
and also a LVDS port is available for external LCD panels.
Tested on r8a7793 Gose with HDMI hooked up to a Toshiba TV.
Signed-off-by: Magnus Damm <damm+renesas@opensource.se>
[simon: rebased; reused existing i2c2 node]
Activate i2c2 bus in r8a7793/gose device tree.
Based on similar work for the r8a7791/koelsch by Wolfram Sang.
Acked-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Instantiate the GPIO leds in the gose device tree.
Based on similar work for the koelsch board by Magnus Damm.
Tested-by: Magnus Damm <damm+renesas@opensource.se>
Instantiate the GPIO keys in the gose device tree.
Based on similar work for the koelsch board by Laurent Pinchart.
As of commit e488ca9f8d4f62c2 ("doc: dt: mtd: partitions: add compatible
property to "partitions" node"), the "partitions" subnode of an SPI
FLASH device node must have a compatible property. The partitions are no
longer detected if it is not present.
Acked-by: Brian Norris <computersforpeace@gmail.com>
Enable the QSPI controller in the gose device tree.
Based on similar work for the silk board by Vladimir Barinov and
Sergei Shtylyov.
Configure PFC for the already enabled scif and ethernet devices
in the device tree for the gose board.
Based on similar work for the koelsch board by Laurent Pinchart and
Sergei Shtylyov.
Acked-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Minimal DT description and Makefile entry for the Gose eval board.
Support for console, timer, and Ethernet.
