Use R-Car Gen 2 fallback binding for vind nodes in DT for r8a7794 SoC.
This has no run-time effect for the current driver as the initialisation
sequence is the same for the SoC-specific binding for r8a7794 and the
fallback binding for R-Car Gen 2
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
Reserve SRAM for the jump stub for CPU core bringup.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
R-Car E2 has 2 regions of Inter Connect RAM (72 + 4 KiB).
The bogus 'device_type = "pci"' confuses dtc, causing lots of totally
unrelated warnings. After fixing that, real warnings like
arch/arm/boot/dts/r8a7790-lager.dtb: Warning (pci_device_reg): Node /pci@ee090000/usb@0,1 PCI unit address format error, expected "1,0"
are left. Correct the unit-addresses and reg properties of the subnodes
to fix these.
Signed-off-by: Rob Herring <robh@kernel.org>
[geert: Improve description]
Add the Z2 clock (Cortex-A7 CPU core clock), which uses a fixed divider,
and link the first CPU node to it.
The second channel of the display unit uses a different module clock
than the first channel.
Fixes: 46c4f13d04d729fa ("ARM: shmobile: r8a7794: Add DU node to device tree")
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Add the missing module clock for the second channel of the display unit.
Link the ARM GIC to the INTC-SYS module clock, and add it to the "always
on" PM Domain, so it can be power managed using that clock.
Note that currently the GIC-400 driver doesn't support module clocks nor
Runtime PM, so this must be handled as a critical clock.
The Cortex-A7 cache controller is an integrated controller, and thus the
device node representing it should not have a unit-addresses or reg
property.
Fixes: 34ea4b4a827b4ee7 ("ARM: dts: r8a7794: Fix W=1 dtc warnings")
Since everybody copied my own mistake from the DT binding example,
let's address all the offenders in one swift go.
Most of them got the CPU interface size wrong (4kB, while it should
be 8kB), except for both keystone platforms which got the control
interface wrong (4kB instead of 8kB).
In a few cases where I knew for sure what implementation was used,
I've added the "arm,gic-400" compatible string. I'm 99% sure that
this is what everyone is using, but short of having the TRM for
all the other SoCs, I've left them alone.
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com>
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Use recently added R-Car Gen 2 fallback binding for iic nodes in
DT for r8a7794 SoC.
fallback binding for R-Car Gen 2.
Use recently added R-Car Gen 2 fallback binding for i2c nodes in
DT for r8a7794 SoC.
A fallback binding for the Renesas R-Car Gen2 PHY driver was
added by commit 7777cb8ba08d ("phy: rcar-gen2: add fallback binding").
This patch makes use of this binding in the DT for the r8a7794 SoC.
Pull ARM DT updates from Arnd Bergmann:
"Lots of changes as usual, so I'm trying to be brief here. Most of the
new hardware support has the respective driver changes merged through
other trees or has had it available for a while, so this is where
things come together.
We get a DT descriptions for a couple of new SoCs, all of them
variants of other chips we already support, and usually coming with a
new evaluation board:
- Oxford semiconductor (now Broadcom) OX820 SoC for NAS devices
- Qualcomm MDM9615 LTE baseband
- NXP imx6ull, the latest and smallest i.MX6 application processor variant
- Renesas RZ/G (r8a7743 and r8a7745) application processors
- Rockchip PX3, a variant of the rk3188 chip used in Android tablets
- Rockchip rk1108 single-core application processor
- ST stm32f746 Cortex-M7 based microcontroller
- TI DRA71x automotive processors
These are commercially available consumer platforms we now support:
- Motorola Droid 4 (xt894) mobile phone
- Rikomagic MK808 Android TV stick based on Rockchips rx3066
- Cloud Engines PogoPlug v3 based on OX820
- Various Broadcom based wireless devices:
- Netgear R8500 router
- Tenda AC9 router
- TP-LINK Archer C9 V1
- Luxul XAP-1510 Access point
- Turris Omnia open hardware router based on Armada 385
And a couple of new boards targeted at developers, makers or
industrial integration:
- Macnica Sodia development platform for Altera socfpga (Cyclone V)
- MicroZed board based on Xilinx Zynq FPGA platforms
- TOPEET itop/elite based on exynos4412
- WP8548 MangOH Open Hardware platform for IOT, based on Qualcomm MDM9615
- NextThing CHIP Pro gadget
- NanoPi M1 development board
- AM571x-IDK industrial board based on TI AM5718
- i.MX6SX UDOO Neo
- Boundary Devices Nitrogen6_SOM2 (i.MX6)
- Engicam i.CoreM6
- Grinn i.MX6UL liteSOM/liteBoard
- Toradex Colibri iMX6 module
Other changes:
- added peripherals on renesas, davinci, stm32f429, uniphier, sti,
mediatek, integrator, at91, imx, vybrid, ls1021a, omap, qualcomm,
mvebu, allwinner, broadcom, exynos, zynq
- Continued fixes for W=1 dtc warnings
- The old STiH415/416 SoC support gets removed, these never made it
into products and have served their purpose in the kernel as a
template for teh newer chips from ST
- The exynos4415 dtsi file is removed as nothing uses it.
- Intel PXA25x can now be booted using devicetree"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (422 commits)
arm: dts: zynq: Add MicroZed board support
ARM: dts: da850: enable high speed for mmc
ARM: dts: da850: Add node for pullup/pulldown pinconf
ARM: dts: da850: enable memctrl and mstpri nodes per board
ARM: dts: da850-lcdk: Add ethernet0 alias to DT
ARM: dts: artpec: add pcie support
ARM: dts: add support for Turris Omnia
devicetree: Add vendor prefix for CZ.NIC
ARM: dts: berlin2q-marvell-dmp: fix typo in chosen node
ARM: dts: berlin2q-marvell-dmp: fix regulators' name
ARM: dts: Add xo to sdhc clock node on qcom platforms
ARM: dts: r8a7794: Add device node for PRR
ARM: dts: r8a7793: Add device node for PRR
ARM: dts: r8a7792: Add device node for PRR
ARM: dts: r8a7791: Add device node for PRR
ARM: dts: r8a7790: Add device node for PRR
ARM: dts: r8a7779: Add device node for PRR
ARM: dts: r8a73a4: Add device node for PRR
ARM: dts: sk-rzg1e: add Ether support
ARM: dts: sk-rzg1e: initial device tree
Add a device node for the Product Register, which provides SoC product
and revision information.
Hook up the Audio-DMAC and sound device nodes to the SYSC "always-on" PM
Domain, for a more consistent device-power-area description in DT.
Cfr. commit 0761ff2ad0c581f3 ("ARM: dts: r8a7794: Add SYSC PM Domains").
Fixes: 320d6c5a08a4abd3 ("ARM: dts: r8a7794: add sound support")
Fixes: 298e4ee3d213a076 ("ARM: dts: r8a7794: add Audio-DMAC support")
The parent clock of the HSUSB clock is the HP clock, not the MP clock.
Fixes: c7bab9f929e51761 ("ARM: shmobile: r8a7794: Add USB clocks to device tree")
Acked-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
R8A7794 doesn't have Cortex-A15 CPUs, thus there's no Z clock...
Fixes: 0dce5454d5c2 ("ARM: shmobile: Initial r8a7794 SoC device tree")
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,dvc/dvc@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,dvc/dvc@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,mix/mix@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,mix/mix@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@2 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@3 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@4 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@5 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@6 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ctu/ctu@7 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@2 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@3 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@4 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@5 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,src/src@6 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@2 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@3 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@4 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@5 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@6 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@7 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@8 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /sound@ec500000/rcar_sound,ssi/ssi@9 has a unit name, but no reg property
Several SCIFB registers reside outside the reported register ranges.
Fortunately this works (on Linux), due to the PAGE_SIZE granularity of
ioremap().
Extend the sizes from 64 to 0x100 bytes to fix this, like is done on
SH/R-Mobile SoCs.
Define the upper limit otherwise the driver cannot utilize max speeds.
Reviewed-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Add a device node for the RST module, which provides a.o. reset control
and mode pin monitoring.
Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
When removing the non-existing thermal clock I forgot to remove its
parent from the node's "clocks" property -- this led to a wrong PWM
clock's parent clock.
Fixes: 2a29f9d6fea8 ("ARM: dts: r8a7794: add MSTP5 clocks")
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Describe two instances (VSPS and VSPD0) of the VSP1 in the R8A7794 device
tree.
Define the generic R8A7794 part of the sound device node.
This sound device is a complex one and comprises the Audio Clock Generator
(ADG), Sampling Rate Converter Unit (SCU), Serial Sound Interface [Unit]
(SSI[U]), and Audio DMAC-Peripheral-Peripheral.
It is up to the board file to enable the device.
This patch is based on the R8A7791 sound work by Kuninori Morimoto.
Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Describe Audio-DMAC in the R8A7794 device tree.
This patch is loosely based on the commit 8994fff67761 ("ARM: shmobile:
r8a7791: Add Audio DMAC devices to DT").
Add MSTP10 clocks to the R8A7794 device tree.
This patch is based on the commit ee9141522dcf ("ARM: shmobile: r8a7791:
add MSTP10 support on DTSI").
Add some MSTP5 clocks to the R8A7794 device tree.
Describe the external audio clocks (signals AUDIO_CLK[ABC]) required by
the sound driver. Boards that provide audio clocks need to override the
clock frequencies.
This patch is based on the commit 0d3dbde84a45 ("ARM: shmobile: r8a7791:
add audio clock on DTSI").
r8a7794 SDHI ch0 has SD_DMACR which is located in 0x324.
This patch updates register size
Based on work for the r8a7790 by Kuninori Morimoto.
Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Warning (unit_address_vs_reg): Node /cache-controller@1 has a unit name, but no reg property
Move the cache-controller node under the cpus node, and make its unit
name and reg property match the MPIDR value.
R-Car Gen2 have two DMA controllers, which are equivalent. Add
references to both dmac0 and dmac1 so the driver can choose which one to
use.
Signed-off-by: Niklas Söderlund <niklas.soderlund+renesas@ragnatech.se>
Pull ARM SoC late DT updates from Arnd Bergmann:
"This is a collection of a few late fixes and other misc stuff that had
dependencies on things being merged from other trees.
The Renesas R-Car power domain handling, and the Nvidia Tegra USB
support both hand notable changes that required changing the DT
binding in a way that only provides compatibility with old DT blobs on
new kernels but not vice versa. As a consequence, the DT changes are
based on top of the driver changes and are now in this branch.
For NXP i.MX and Samsung Exynos, the changes in here depend on other
changes that got merged through the clk maintainer tree"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (35 commits)
ARM: dts: exynos: Add support of Bus frequency using VDD_INT for exynos5422-odroidxu3
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos542x SoC
ARM: dts: exynos: Add NoC Probe dt node for Exynos542x SoC
ARM: dts: exynos: Add support of bus frequency for exynos4412-trats/odroidu3
ARM: dts: exynos: Expand the voltage range of buck1/3 regulator for exynos4412-odroidu3
ARM: dts: exynos: Add support of bus frequency using VDD_INT for exynos3250-rinato
ARM: dts: exynos: Add exynos4412-ppmu-common dtsi to delete duplicate PPMU nodes
ARM: dts: exynos: Add bus nodes using VDD_MIF for Exynos4210
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos4x12
ARM: dts: exynos: Add bus nodes using VDD_MIF for Exynos4x12
ARM: dts: exynos: Add bus nodes using VDD_INT for Exynos3250
ARM: dts: exynos: Add DMC bus frequency for exynos3250-rinato/monk
ARM: dts: exynos: Add DMC bus node for Exynos3250
ARM: tegra: Enable XUSB on Nyan
ARM: tegra: Enable XUSB on Jetson TK1
ARM: tegra: Enable XUSB on Venice2
ARM: tegra: Add Tegra124 XUSB controller
ARM: tegra: Move Tegra124 to the new XUSB pad controller binding
ARM: dts: r8a7794: Use SYSC "always-on" PM Domain
ARM: dts: r8a7793: Use SYSC "always-on" PM Domain
Hook up all devices that are part of the CPG/MSTP Clock Domain to the
SYSC "always-on" PM Domain, for a more consistent device-power-area
description in DT.
Add a device node for the System Controller.
Hook up the Cortex-A7 CPU cores and the Cortex-A7 L2 cache/SCU to their
respective PM Domains.
clk_get() on a disabled clock node will return -EPROBE_DEFER, which can
cause drivers to be deferred forever if such clocks are referenced in
their devices' clocks properties.
Update the various disabled external clock nodes to default to a
frequency of 0, but don't disable them, to prevent this.
Add IIC nodes to r8a7794 device tree.
Based on similar work for the r8a7793 by Laurent Pinchart.
Add IIC clocks to r8a7794 device tree.
Based on similar work for the r8a7790 by Wolfram Sang.
Add CAN nodes to r8a7794 device tree.
Based on work by Sergei Shtylyov for the r8a7791 SoC.
Acked-by: Ramesh Shanmugasundaram <ramesh.shanmugasundaram@bp.renesas.com>
* Fixed rate and fixed factor clocks do not require an
clock-output-names property.
* Since 07705583e920fef6 ("clk: shmobile: div6: Make clock-output-names
optional") Renesas div6 clocks do not require a clock-output-names
property.
In the above cases there is only one clock output and its name is taken
from that of the clock node. Accordingly, remove the unnecessary
clock-output-names properties and as necessary update the node names.
Define the generic R8A7794 part of the EtherAVB device node.
Based on the commit 46ece349aa54 ("ARM: shmobile: r8a7791: add EtherAVB DT
support").
Add the EtherAVB clock to the R8A7794 device tree.
Based on the commit eaa870b30553 ("ARM: shmobile: r8a7791: add EtherAVB
clock").
Add a device node for the L2 cache, and link the CPU nodes to it.
The L2 cache for the Cortex-A7 CPU cores is 512 KiB large (organized as
64 KiB x 8 ways).
Use recently added fallback compatibility string in r8a7794 device tree.
Add the device node for the external SCIF_CLK.
The presence of the SCIF_CLK crystal and its clock frequency depends on
the actual board.
Add the two optional clock sources (ZS_CLK and SCIF_CLK for the internal
resp. external clock) for the Baud Rate Generator for External Clock
(BRG) to all SCIF and HSCIF device nodes.
This increases the range and accuracy of supported baud rates on
(H)SCIF.
The clock is really the device functional clock, not the interface
clock. Rename it.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Use GIC_* defines for GIC interrupt cells in r8a7794 device tree.
