Use macros to describe gpios will make the dts easier to
read and write.
All the modifications done with sed:
sed -i -e 's/ 0 GPIO_ACTIVE_/ RK_PA0 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 1 GPIO_ACTIVE_/ RK_PA1 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 2 GPIO_ACTIVE_/ RK_PA2 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 30 GPIO_ACTIVE_/ RK_PD6 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 31 GPIO_ACTIVE_/ RK_PD7 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
Tested with:
for i in dts-old/*dtb; do scripts/dtc/dtx_diff $i dts-new/$(basename $i); done
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
[also adapted the gpio interrupts]
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
The amount of available memory is clearly a board-specific value, so
the core per-soc dtsi should not define a default of any sort.
Therefore move the memory-nodes to the two board files.
Also fix the amount of memory on Kylin (512MB instead of 1GB).
While in most cases the bootloader will override this with the
actual amount of memory, there is no need to keep known wrong values
in the board-dts.
This patch adds the emac device node for rk3036 SoCs.
We need to let mac clock under the DPLL which is able to provide
the accurate 50MHz what mac_ref need, since that will cause some
unstable things if the cpufreq is working.
Signed-off-by: Xing Zheng <zhengxing@rock-chips.com>
Signed-off-by: Caesar Wang <wxt@rock-chips.com>
Cc: linux-rockchip@lists.infradead.org
Cc: Xing Zheng <zhengxing@rock-chips.com>
Cc: Heiko Stuebner <heiko@sntech.de>
Initial release for rk3036 sdk board.
