Rockchip platform use a SYSCON mapped register store
the reboot mode magic value for bootloader to use when
system reboot. So add syscon-reboot-mode driver DT node
for rk3xxx/rk3036/rk3288 based platform
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
Reviewed-by: Matthias Brugger <matthias.bgg@gmail.com>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
The amount of available memory is clearly a board-specific value, so
the core per-soc dtsi should not define a default of any sort.
Therefore move the memory-nodes to the two board files.
Also fix the amount of memory on Kylin (512MB instead of 1GB).
While in most cases the bootloader will override this with the
actual amount of memory, there is no need to keep known wrong values
in the board-dts.
Only one of "broken-cd" and "non-removable" should be supplied
according to Documentation/devicetree/bindings/mmc/mmc.txt.
Obviously emmc and sdio-wifi are non-removable devices, while
broken-cd is for removable device whose card detect pin is broken.
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
Add the Innosilicon hdmi node for HDMI display.
Signed-off-by: Caesar Wang <wxt@rock-chips.com>
The rk3036 support two overlay plane and one hwc plane,
it supports IOMMU, and its IOMMU same as rk3288's.
Pull ARM DT updates from Arnd Bergmann:
"These are all the updates to device tree files for 32-bit platforms,
plus a couple of related 64-bit updates:
New SoC support:
- Allwinner A83T
- Axis Artpec-6 SoC
- Mediatek MT7623 SoC
- TI Keystone K2G SoC
- ST Microelectronics stm32f469
New board or machine support:
- ARM Juno R2
- Buffalo Linkstation LS-QVL and LS-GL
- Cubietruck plus
- D-Link DIR-885L
- DT support for ARM RealView PB1176 and PB11MPCore
- Google Nexus 7
- Homlet v2
- Itead Ibox
- Lamobo R1
- LG Optimus Black
- Logicpd dm3730
- Raspberry Pi Model A
Other changes include
- Lots of updates for Qualcomm APQ8064, MSM8974 and others
- Improved support for Nokia N900 and other OMAP machines
- Common clk support for lpc32xx
- HDLCD display on ARM
- Improved stm32f429 support
- Improved Renesas device support, r8a779x and others
- Lots of Rockchip updates
- Samsung cleanups
- ADC support for Atmel SAMA5D2
- BCM2835 (Raspberry Pi) improvements
- Broadcom Northstar Plus enhancements
- OMAP GPMC rework
- Several improvements for Atmel SAMA5D2 / Xplained
- Global change to remove inofficial "arm,amba-bus" compatible
string"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (350 commits)
ARM, ARM64: dts: drop "arm,amba-bus" in favor of "simple-bus"
ARM: dts: artpec: dual-license on artpec6.dtsi
ARM: dts: ux500: add synaptics RMI4 for Ux500 TVK DT
arm64: dts: juno/vexpress: fix node name unit-address presence warnings
arm64: dts: foundation-v8: add SBSA Generic Watchdog device node
ARM: dts: at91: sama5d2 Xplained: add leds node
ARM: dts: at91: sama5d2 Xplained: add user push button
ARM: dts: at91: sama5d2 Xplained: set pin muxing for usb gadget and usb host
ARM: dts: stm32f429: Enable Ethernet on Eval board
ARM: dts: omap3-sniper: TWL4030 keypad support
Revert "ARM: dts: DRA7: Add dt nodes for PWMSS"
ARM: dts: dm814x: dra62x: Disable wait pin monitoring for NAND
ARM: dts: dm814x: dra62x: Fix NAND device nodes
ARM: dts: stm32f429: Add Ethernet support
ARM: dts: stm32f429: Add system config bank node
ARM: dts: at91: sama5d2: add nand0 and nfc0 nodes
ARM: dts: at91: sama5d2: add dma properties to UART nodes
ARM: dts: at91: sama5d2 Xplained: Correct the macb irq pinctrl node
ARM: dts: exynos: Don't overheat the Odroid XU3-Lite on high load
ARM: dts: exynos: Add cooling levels for Exynos5422/5800 CPUs
This patch adds the emac device node for rk3036 SoCs.
We need to let mac clock under the DPLL which is able to provide
the accurate 50MHz what mac_ref need, since that will cause some
unstable things if the cpufreq is working.
Signed-off-by: Xing Zheng <zhengxing@rock-chips.com>
Cc: linux-rockchip@lists.infradead.org
Cc: Xing Zheng <zhengxing@rock-chips.com>
Cc: Heiko Stuebner <heiko@sntech.de>
The compatible string "simple-bus" is well defined in ePAPR, while
I see no documentation for the "arm,amba-bus" arnywhere in ePAPR or
Documentation/devicetree/.
DT is also used by other projects than Linux kernel. It is not a
good idea to rely on such an unofficial binding.
This commit
- replaces "arm,amba-bus" with "simple-bus"
- drops "arm,amba-bus" where it is used along with "simple-bus"
Pl330 integrated in rk3036 platform that doesn't support
DMAFLUSHP function. So we add 'arm,pl330-broken-no-flushp' quirk
for rk3036.
This patch adds the needed spi node for rk3036 dts.
We have to use the 4 bus emmc to work if someone want to support
the spi devices, since the pins are re-used by emmc data[5-8] and spi.
In some caseswe need to support the spi devices, that will waste the
emmc performance.
Moment, the kylin/evb hasn't the spi devices to work, so maybe we need wait
the new required to enable in kylin/evb board.
Anyway, the spi should be needed land in rk3036 dts.
While drivers will bind to the generic compatible values, this enables
the use of more specialized drivers in the future, if the need arises.
For sound setups using the simple-card mechanism, the main clock
(sysclk) is expected to be the first element. For the i2s-driver
itself it doesn't matter, as it uses named clocks, so we can just
swap them.
Reported-by: Caesar Wang <wxt@rock-chips.com>
Sometime will hang if you set the i2s pinctrl as the none setting.
Let's set the pinctrl as the default setting to enable the gpio bias.
In general, the sdio/sdmmc is used by the wifi module
and sd card.
let's add the node for these function.
The pinctrl gpio pull up/down is incorrect since the rk3036 SoCs
can't set the status in the internal.
We should keep the default status for enable the gpio status,
In fact, the pull_none is the disable the gpio pull up/down.
Initial release for rk3036 shared dtsi.
