Rayeager/Bqcurie2/Marsboard use pwm3 modulate the vdd_logic voltage,
so enable it.
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
This enables SDMMC0 on the board and gives a basic support for SD cards.
Signed-off-by: Romain Perier <romain.perier@gmail.com>
This enables the previously disabled usb controllers on the marsboard
and makes it possible to for example mount usb mass storage devices.
This adds the usbphy nodes to rk3066 and rk3188, which share the usb hosts
in rk3xxx.dtsi and also enables it on boards based around these socs.
The usb-phy itself is the same as used on the rk3288 already.
The memory node is supposed to contain a device_type property marking
it as memory. The currently included boards miss this property.
vsys is the core always-on supply of the Marsboard.
This patch adds initial support for the Marsboard RK3066. It enables
EMAC Rockchip which is the ethernet support on the board and registers
it as a supported rockchip platform.
