We deprecated the "num-slots" property now and plan to get
rid of it finally. Just move a step to cleanup it from DT.
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Use macros to describe gpios will make the dts easier to
read and write.
All the modifications done with sed:
sed -i -e 's/ 0 GPIO_ACTIVE_/ RK_PA0 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 1 GPIO_ACTIVE_/ RK_PA1 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 2 GPIO_ACTIVE_/ RK_PA2 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 30 GPIO_ACTIVE_/ RK_PD6 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 31 GPIO_ACTIVE_/ RK_PD7 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
Tested with:
for i in dts-old/*dtb; do scripts/dtc/dtx_diff $i dts-new/$(basename $i); done
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
[also adapted the gpio interrupts]
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Drop superfluous #address-cells and #size-cells, rename
key-nodes to individual names and also use the key constants
intead of numbers.
Reported-by: Julien Chauveau <chauveau.julien@gmail.com>
Acked-by: Rob Herring <robh@kernel.org>
Only one of "broken-cd" and "non-removable" should be supplied
according to Documentation/devicetree/bindings/mmc/mmc.txt.
Obviously emmc and sdio-wifi are non-removable devices, while
broken-cd is for removable device whose card detect pin is broken.
Keyboard driver for GPIO buttons(gpio-keys) checks for the legacy
"gpio-key,wakeup" boolean property to enable gpio buttons as wakeup
source.
Few dts files assign value "1" to gpio-key,wakeup and in one instance a
value "0" is assigned probably assuming it won't be enabled as a wakeup
source. Since the presence of the boolean property indicates it is
enabled, value of "0" have no value.
This patch replaces the legacy "gpio-key,wakeup" with the unified
"wakeup-source" property which inturn fixes the above mentioned issue.
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Rayeager/Bqcurie2/Marsboard use pwm3 modulate the vdd_logic voltage,
so enable it.
Add cap-sd-highspeed and cap-mmc-highspeed for rk3066a-bqcurie2
and rk3066a-rayeager boards to make sd cards run faster.
This adds the usbphy nodes to rk3066 and rk3188, which share the usb hosts
in rk3xxx.dtsi and also enables it on boards based around these socs.
The usb-phy itself is the same as used on the rk3288 already.
The memory node is supposed to contain a device_type property marking
it as memory. The currently included boards miss this property.
This add support for Rayeager PX2, Rockchip PX2 based development board
made by ChipSPARK.
Signed-off-by: FUKAUMI Naoki <naobsd@gmail.com>
Tested-by: Andy Yan <andy.yan@rock-chips.com>
