[ Upstream commit a2df0984e73fd9e1dad5fc3f1c307ec3de395e30 ]
It is good practice to make the setting of gpio-pinctrls explicitly in the
devicetree, and in this case even necessary.
Rockchip boards start with iomux settings set to gpio for most pins and
while the linux pinctrl driver also implicitly sets the gpio function if
a pin is requested as gpio that is not necessarily true for other drivers.
The issue in question stems from uboot, where the sdmmc_pwr pin is set
to function 1 (sdmmc-power) by the bootrom when reading the 1st-stage
loader. The regulator controlled by the pin is active-low though, so
when the dwmmc hw-block sets its enabled bit, it actually disables the
regulator. By changing the pin back to gpio we fix that behaviour.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
We deprecated the "num-slots" property now and plan to get
rid of it finally. Just move a step to cleanup it from DT.
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Use macros to describe gpios will make the dts easier to
read and write.
All the modifications done with sed:
sed -i -e 's/ 0 GPIO_ACTIVE_/ RK_PA0 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 1 GPIO_ACTIVE_/ RK_PA1 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 2 GPIO_ACTIVE_/ RK_PA2 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 30 GPIO_ACTIVE_/ RK_PD6 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 31 GPIO_ACTIVE_/ RK_PD7 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
Tested with:
for i in dts-old/*dtb; do scripts/dtc/dtx_diff $i dts-new/$(basename $i); done
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
[also adapted the gpio interrupts]
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Drop superfluous #address-cells and #size-cells, rename
key-nodes to individual names and also use the key constants
intead of numbers.
Reported-by: Julien Chauveau <chauveau.julien@gmail.com>
Acked-by: Rob Herring <robh@kernel.org>
Keyboard driver for GPIO buttons(gpio-keys) checks for the legacy
"gpio-key,wakeup" boolean property to enable gpio buttons as wakeup
source.
Few dts files assign value "1" to gpio-key,wakeup and in one instance a
value "0" is assigned probably assuming it won't be enabled as a wakeup
source. Since the presence of the boolean property indicates it is
enabled, value of "0" have no value.
This patch replaces the legacy "gpio-key,wakeup" with the unified
"wakeup-source" property which inturn fixes the above mentioned issue.
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
This enables the SPDIF optical audio output on the Radxa Rock
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Add cap-sd-highspeed and cap-mmc-highspeed for rk3188-radxarock
board to make sd cards running faster.
This adds the usbphy nodes to rk3066 and rk3188, which share the usb hosts
in rk3xxx.dtsi and also enables it on boards based around these socs.
The usb-phy itself is the same as used on the rk3288 already.
The memory node is supposed to contain a device_type property marking
it as memory. The currently included boards miss this property.
GPLv2-only devicetrees make reuse difficult for software components licensed
under a different license.
The consensus is that a GPL/X11 dual-license should allow all necessary uses,
so relicense the rk3188-radxarock.dts to this combination.
CCs were aquired by git shortlog -sne so it should've hopefully catched
every contributor.
Acked-by: Beniamino Galvani <b.galvani@gmail.com>
Acked-by: Romain Perier <romain.perier@gmail.com>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Acked-by: Julien Chauveau <chauveau.julien@gmail.com>
The act8846 is the main pmic and system-power-controller on radxarock boards,
so add the necessary property.
Signed-off-by: Michael Niewoehner <mniewoeh@stud.hs-offenburg.de>
On the Radxa Rock board most supplies come from the static 5v vsys supply, but
the inl1-supply comes from the REG4 of the act8846 itself. Model this dependency
using the added supply-handling to make sure the supplying regulator gets handled
correctly and not accidentially turned off.
The leds-gpio driver recently switched to the device property API. The device_node
name is no longer retrieved if the "label" devicetree property is not found.
In this case the driver tries to create entries with (null) name in
/sys/class/leds, which is wrong and generates backtrace as several gpio_leds have
the same name. Also renamed subnode "yellow" to "blue" to match the last
schematics updates.
Signed-off-by: Romain Perier <romain.perier@gmail.com>
This enables user space access to the 3 PWM available on the Radxa Rock headers.
Signed-off-by: Julien CHAUVEAU <julien.chauveau@neo-technologies.fr>
This adds the cpu-supplies to the curie2, radxarock and rk3288-evb-rk808 boards.
The rk3288-evb-act8846 variant cannot provide the cpu-regulator at the moment
so will get its supply later.
Pull networking updates from David Miller:
"Most notable changes in here:
1) By far the biggest accomplishment, thanks to a large range of
contributors, is the addition of multi-send for transmit. This is
the result of discussions back in Chicago, and the hard work of
several individuals.
Now, when the ->ndo_start_xmit() method of a driver sees
skb->xmit_more as true, it can choose to defer the doorbell
telling the driver to start processing the new TX queue entires.
skb->xmit_more means that the generic networking is guaranteed to
call the driver immediately with another SKB to send.
There is logic added to the qdisc layer to dequeue multiple
packets at a time, and the handling mis-predicted offloads in
software is now done with no locks held.
Finally, pktgen is extended to have a "burst" parameter that can
be used to test a multi-send implementation.
Several drivers have xmit_more support: i40e, igb, ixgbe, mlx4,
virtio_net
Adding support is almost trivial, so export more drivers to
support this optimization soon.
I want to thank, in no particular or implied order, Jesper
Dangaard Brouer, Eric Dumazet, Alexander Duyck, Tom Herbert, Jamal
Hadi Salim, John Fastabend, Florian Westphal, Daniel Borkmann,
David Tat, Hannes Frederic Sowa, and Rusty Russell.
2) PTP and timestamping support in bnx2x, from Michal Kalderon.
3) Allow adjusting the rx_copybreak threshold for a driver via
ethtool, and add rx_copybreak support to enic driver. From
Govindarajulu Varadarajan.
4) Significant enhancements to the generic PHY layer and the bcm7xxx
driver in particular (EEE support, auto power down, etc.) from
Florian Fainelli.
5) Allow raw buffers to be used for flow dissection, allowing drivers
to determine the optimal "linear pull" size for devices that DMA
into pools of pages. The objective is to get exactly the
necessary amount of headers into the linear SKB area pre-pulled,
but no more. The new interface drivers use is eth_get_headlen().
From WANG Cong, with driver conversions (several had their own
by-hand duplicated implementations) by Alexander Duyck and Eric
Dumazet.
6) Support checksumming more smoothly and efficiently for
encapsulations, and add "foo over UDP" facility. From Tom
Herbert.
7) Add Broadcom SF2 switch driver to DSA layer, from Florian
Fainelli.
8) eBPF now can load programs via a system call and has an extensive
testsuite. Alexei Starovoitov and Daniel Borkmann.
9) Major overhaul of the packet scheduler to use RCU in several major
areas such as the classifiers and rate estimators. From John
Fastabend.
10) Add driver for Intel FM10000 Ethernet Switch, from Alexander
Duyck.
11) Rearrange TCP_SKB_CB() to reduce cache line misses, from Eric
Dumazet.
12) Add Datacenter TCP congestion control algorithm support, From
Florian Westphal.
13) Reorganize sk_buff so that __copy_skb_header() is significantly
faster. From Eric Dumazet"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1558 commits)
netlabel: directly return netlbl_unlabel_genl_init()
net: add netdev_txq_bql_{enqueue, complete}_prefetchw() helpers
net: description of dma_cookie cause make xmldocs warning
cxgb4: clean up a type issue
cxgb4: potential shift wrapping bug
i40e: skb->xmit_more support
net: fs_enet: Add NAPI TX
net: fs_enet: Remove non NAPI RX
r8169:add support for RTL8168EP
net_sched: copy exts->type in tcf_exts_change()
wimax: convert printk to pr_foo()
af_unix: remove 0 assignment on static
ipv6: Do not warn for informational ICMP messages, regardless of type.
Update Intel Ethernet Driver maintainers list
bridge: Save frag_max_size between PRE_ROUTING and POST_ROUTING
tipc: fix bug in multicast congestion handling
net: better IFF_XMIT_DST_RELEASE support
net/mlx4_en: remove NETDEV_TX_BUSY
3c59x: fix bad split of cpu_to_le32(pci_map_single())
net: bcmgenet: fix Tx ring priority programming
git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into next/dt
Merge "second bunch of dts changes for 3.18" from Heiko Stubner:
More peripheral support for Rockchip SoCs
- dwc2 usb controllers
- spi controllers
- emmc controller
* tag 'v3.18-rockchip-dts2-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip:
ARM: dts: rockchip: Remove "regulator-always-on" in vcc_rmii for Radxa Rock
ARM: dts: rockchip: fix rk3188 emmc pull references
ARM: dts: rockchip: fix swapped Radxa Rock pinctrl references
ARM: dts: rockchip: clean up rk3xxx mmc nodes
ARM: dts: rockchip: add emmc nodes for rk3066 and rk3188
ARM: dts: rockchip: add Cortex-A9 SPI controller nodes
ARM: dts: rockchip: enable usb ports on Radxa Rock
ARM: dts: rockchip: add dwc2 controllers for rk3066 and rk3188
ARM: dts: rockchip: remove rockchip,bus-index from rk3xxx i2c0
ARM: dts: Switch i2c0 to 400kHz on rk3288-evb-rk808
ARM: dts: Add rk808 PMIC to rk3288-evb-rk808
ARM: dts: Add mshc aliases for rk3288
ARM: dts: Add SPI nodes to rk3288
ARM: dts: Enable USB host1(dwc) on rk3288-evb
ARM: dts: add rk3288 dwc2 controller support
ARM: dts: Add sdio0 and sdio1 to the rk3288
On Rockchip RK3188 SoCs the platform driver emac_rockchip is used. This variant driver
enables this regulator when the device driver is loaded. The phy no longer needs
to be always on.
The host and otg regulator pinctrl settings got swapped, making the host
reference the otg pinctrl and the other way round. The actual pins are
correct (gpio0-3 for host and gpio2-31 for otg).
Reported-by: Naoki FUKAUMI <naobsd@gmail.com>
This enables both the otg and host port and adds the vbus regulators
on the Radxa Rock board. As we don't have phy support yet, the vbus
regulators are added in always-on mode.
This enables EMAC Rockchip support on radxa rock boards.
git://git.rocketboards.org/linux-socfpga-next into next/dt
Pull "arm: dts: Add Altera SDRAM EDAC bindings & devicetree entries" From Dinh Nguyen:
5 of the 6 patches are DTS updates and the 1 patch is updating
the MAINTAINERS entry with my new email address.
* tag 'socfpga_update_for_v3.18' of git://git.rocketboards.org/linux-socfpga-next:
arm: dts: Add Altera SDRAM EDAC bindings & devicetree entries.
ARM: dts: socfpga: memreserve first 4KB for future system use
ARM: dts: socfpga: Add SD card detect
ARM: dts: socfpga: remove extra alias in the ArriaV devkit
ARM: dts: socfpga: unuse the slot-node and deprecate the supports-highspeed for dw-mmc
MAINTAINERS: update entries for ARM/SOCFPGA platform
The Radxa Rock uses a hym8563 as rtc. Add the i2c device and necessary
pinconfig for the interrupt pin - labeled rtc_int in the schematics.
During the restructuring of the Rockchip Cortex-A9 dtsi files it seems
like the pinctrl settings vanished at some point from the mmc0 support.
This of course renders them unusable, so readd the necessary pinctrl
properties.
for dw-mmc
dw-mmc controller can support multiple slots.
But, there are no use-cases anywhere. So we don't need to support the
slot-node for dw-mmc controller.
And "supports-highspeed" property in dw-mmc is deprecated.
"supports-highspeed" property can be replaced with "cap-sd/mmc-highspeed".
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Reviewed-by: Tushar Behera <trblinux@gmail.com>
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Reviewed-by: Heiko Stuebner <heiko@sntech.de>
Acked-by: Seungwon Jeon <tgih.jun@samsung.com>
This adds the Designware compatible watchdog found on RK3xxx Cortex-A9 SoCs.
We set default pinctrl settings for the uarts in rk3188.dtsi already,
so remove forgotten duplicate.
This adds a device tree node for the infrared receiver connected to a
GPIO pin on the Radxa Rock.
Signed-off-by: Beniamino Galvani <b.galvani@gmail.com>
The Radxa Rock contains one sd-card slot. Add the supplying regulator
and enable its dw_mmc node.
This enables the 2nd i2c bus and adds the act8846 pmic as device.
Use the handles for subsequent changes to nodes, similar to like the rk3288
submission does it.
Comments received from the rk3288 submission indicated that a generic subnode
to group soc components should not be used.
So to keep all rockchip devicetree files similar, remove it from rk3066 and rk3188.
Add the missing 'compatible' property to device tree root node of
- rk3066a-bqcurie2.dts
- rk3188-radxarock.dts
and document the new values.
Basic devicetree files for the rk3188 SoC. Also provided is a board
dts file for the upcoming Radxa Rock board using this SoC.
