This patch solves the following error:
arch/arm/boot/dts/rk3228-evb.dtb: ERROR (phandle_references): Reference to non-existent node or label "phy0"
Fixess db40f15b53e4 ("ARM: dts: rk3228-evb: Enable the integrated PHY for gmac")
Signed-off-by: David Wu <david.wu@rock-chips.com>
This patch enables the integrated PHY for rk3228 evb board
by default.
To use the external 1000M PHY on evb board, need to make
some switch of evb board to be on.
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
We have the brother chipset that RK3228 and RK3229, they share most
of dts configuration, but there are a number of different features.
In order to develop the future when they are easy to distinguish,
we need them to be independent.
Signed-off-by: Xing Zheng <zhengxing@rock-chips.com>
Only one of "broken-cd" and "non-removable" should be supplied
according to Documentation/devicetree/bindings/mmc/mmc.txt.
Obviously emmc and sdio-wifi are non-removable devices, while
broken-cd is for removable device whose card detect pin is broken.
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
This patch enables the tsadc for rk3228 evb board.
The rk3228 evb board uses the CRU to reset the chip since it hasn't the
PMIC to connect it, and TSHUT is low active on evb board.
Signed-off-by: Caesar Wang <wxt@rock-chips.com>
Initial release for rk3228 sdk board.
Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com>
