In order to be able to use more than 4GB of RAM when the LPAE is
activated, the dts must be converted in 64 bits.
Signed-off-by: Tao Huang <huangtao@rock-chips.com>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
We deprecated the "num-slots" property now and plan to get
rid of it finally. Just move a step to cleanup it from DT.
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Add reference to the Mali GPU device tree node on rk3288-fennec
Tested on Fennec board.
Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com>
Use macros to describe gpios will make the dts easier to
read and write.
All the modifications done with sed:
sed -i -e 's/ 0 GPIO_ACTIVE_/ RK_PA0 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 1 GPIO_ACTIVE_/ RK_PA1 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 2 GPIO_ACTIVE_/ RK_PA2 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 30 GPIO_ACTIVE_/ RK_PD6 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 31 GPIO_ACTIVE_/ RK_PD7 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
Tested with:
for i in dts-old/*dtb; do scripts/dtc/dtx_diff $i dts-new/$(basename $i); done
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
[also adapted the gpio interrupts]
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
This adds support for RK3288-Fennec boards. Currently supported
are serial console, wired networking, hdmi output and USB.
Signed-off-by: Xing Zheng <zhengxing@rock-chips.com>
