In order to be able to use more than 4GB of RAM when the LPAE is
activated, the dts must be converted in 64 bits.
Signed-off-by: Tao Huang <huangtao@rock-chips.com>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
We deprecated the "num-slots" property now and plan to get
rid of it finally. Just move a step to cleanup it from DT.
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Use macros to describe gpios will make the dts easier to
read and write.
All the modifications done with sed:
sed -i -e 's/ 0 GPIO_ACTIVE_/ RK_PA0 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 1 GPIO_ACTIVE_/ RK_PA1 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 2 GPIO_ACTIVE_/ RK_PA2 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 30 GPIO_ACTIVE_/ RK_PD6 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 31 GPIO_ACTIVE_/ RK_PD7 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
Tested with:
for i in dts-old/*dtb; do scripts/dtc/dtx_diff $i dts-new/$(basename $i); done
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
[also adapted the gpio interrupts]
Use definition in rockchip pinctrl header to describe
gpios, this will make it more clear.
Enable these two modes to speed up the booting and improve
the performance.
PopMetal-RK3288 board could enable SD3.0 card but need vccio_sd
to support the voltage range from 1V8 to 3V3 and we also need to
add more UHS mode here.
This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Add power supply reference for L3G3200D and the 3-axis Electronic
Compass AK8963.
The i2c address of the three-axis digital gyroscope L3G4200D should be
0x69 according to hardware design.
Enable USB OTG port on RK3288 Popmetal board, So we can run
some usb gadget functions like Android adb on this board.
io-voltage control is actually part of the grf, so move the node under the
newly available grf simple-mfd.
To minimize duplicate code, the core node and compatible property
gets placed in the core rk3288.dtsi while the individual boards
now only need to enable it and add the necessary supply properties.
Drop superfluous #address-cells and #size-cells, rename
key-nodes to individual names and also use the key constants
intead of numbers.
Reported-by: Julien Chauveau <chauveau.julien@gmail.com>
Acked-by: Rob Herring <robh@kernel.org>
Only one of "broken-cd" and "non-removable" should be supplied
according to Documentation/devicetree/bindings/mmc/mmc.txt.
Obviously emmc and sdio-wifi are non-removable devices, while
broken-cd is for removable device whose card detect pin is broken.
Keyboard driver for GPIO buttons(gpio-keys) checks for the legacy
"gpio-key,wakeup" boolean property to enable gpio buttons as wakeup
source.
Few dts files assign value "1" to gpio-key,wakeup and in one instance a
value "0" is assigned probably assuming it won't be enabled as a wakeup
source. Since the presence of the boolean property indicates it is
enabled, value of "0" have no value.
This patch replaces the legacy "gpio-key,wakeup" with the unified
"wakeup-source" property which inturn fixes the above mentioned issue.
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Add the iodomains node and reference the correct regulator for each
domain. This also includes adding the currently unused dvp regulators
and fixing up two regulators to follow the naming in the schematics.
Add missing regulators and supply properties to emmc and sdmmc nodes.
The memory node is supposed to contain a device_type property marking
it as memory. The currently included boards miss this property.
The tsadc is used to read cpu and gpu temperatures. Also enable it on the
other rk3288 boards beside the evb using the cru reset settings.
PopMetal is a rockchip rk3288 based board made by ChipSpark,
which has many interface such as VGA,HDMI,usb,ir,sdcad and lots of
sensors such as gyroscope(L3G4200D),accelerometer(mma8452),
compass(AK8963C).
This patch add a basic support for this board, which make the board
boot into a initramfs shell with sdcard,hdmi and all sensors enabled
